Results 1 to 18 of 18
    Senior Member Three Rings DrZEUS's Avatar
    Aug 18 2011
    B8.5 S4
    Mississauga
    Removing Heat Core
    Is there a DIY to remove the heater core? I understand it's located under the driver's side dash. Just wondering what is involved in pulling it. Would like to flush it out as it keeps getting clogged and it's costing me big bucks each time I take it to the shop.
    Feb 27 2011
    Winnipeg
    there is a DIY in the B6 section, its pretty easy, I'd remove it and replace it, I find flushing it only helps for a short time and it plugs again.
    Aug 18 2011
    B8.5 S4
    Mississauga
    Bumping my own thread. Had my heater core removed and flushed out 4 times over the past year. Keeps plugging up. The material that comes out is like sand. Literally. It's baffling and even my trusty mechanic can't explain it. His theory is that this is sand leftover in the crevices of the block from the casting process. Why after 8 years and 160,000 km later though? I'll snap of pic of the sandy stuff. Hopefully someone can chime in.
    Established Member Two Rings Cobra351's Avatar
    Feb 22 2013
    NY\C
    Maybe try flushing the entire system also(except the heater core)? And then do ONLY the heater core on it's own- using bypass hoses.
    Aug 18 2011
    B8.5 S4
    Mississauga
    Quote Originally Posted by Cobra351 View Post
    My coolant and coolant tank looks clean but it doesn't hurt to try that. Do you mean flush the heater core while on the car and on my own? If so, what's the best way? I don't have a compressor.
    Mar 24 2013
    Oakdale, CT
    Do a good coolant flush of the block to clear it out. You can also flush your heater core without removing it. Just hook some long hoses onto the nipples and flush that way like I did in the picture below.
    -Adam
    Aug 18 2011
    B8.5 S4
    Mississauga
    Are you hooking up a regular water hose to those black hoses for the flush? What diameter (inside) are those black hoses?
    Aug 18 2011
    B8.5 S4
    Mississauga
    Here's what keeps coming out with each flush (removing heater core and flushing it with a garden hose).
    Mar 24 2013
    Oakdale, CT
    Yes, i used a garden hose to flush it. The hose is 3/4" heater core hose from napa.
    It looks like someone may have put some of that stop leak shit in your coolant system at some point.
    -Adam
    Veteran Member Four Rings vvenom800tt's Avatar
    Dec 04 2011
    Kansas City, KS
    Stop leak ruins coolant systems.
    I flushed mine last winter. Tooke the hoses off in the engine bay and blasted in with a garden hose and had the other side hosed into a bucked to catch the debris.
    Worked like a charm. A lot of white flaky calcium stuff came out
    2005.5 Audi A4 Quattro 2.0T 6MT - APR - 034 - Custom 3" single exhaust - 17z Brembo - GFB - Alzor - Kumho - ST - Injen - Swift - Hyperco - ECS - Saikou Michi - PowerFlex - Podi
    Feb 24 2004
    Minneapolis
    ^^^My thought^^^^ Someone put some stop-leak in there. That should outlaw that crap. For cooling systems and AC systems, it's just awful. Meanwhile you'll be at some holiday party and someone will be bragging about how he fixed his sister's car with a can of stop-leak, blah, blah, blah.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Oct 30 2006
    B8 A4 Avant 6spd
    Quote Originally Posted by seanf86 View Post
    Removing and installing it is the easy part, getting those fucking metal vband coolant lines back on is the hard part. If you go through with it, make sure you get a fresh clamp / seal kit.
    -18 718 GTS
    Aug 18 2011
    B8.5 S4
    Mississauga
    RE: the stop leak, maybe the previous owner put that crap in. I bought it CPO, 3 years old with 60k km on the dial. I've since put on 110k and it's taken that long for the problem to rear it's ugly head.
    I am going to try and flush the heater core without removing it by using aluthman and Cobra351's suggestion to use bypass hoses.
    Just curious, after running regular water via garden hose and bypass hose through the core, how do i flush out any remaining water in the core? I don't have an air compressor.
    Aug 18 2011
    B8.5 S4
    Mississauga
    ....btw, which hose is the outlet and which is the inlet?
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by DrZEUS View Post
    I do it their way too, with some extra heater hose I've got around. I just blow on one of the hoses. As long as you have clean water in there, you don't need to get it bone dry. I'll even pour some 50%/50% in there to help avoid a bubble.
    Feb 15 2016
    Cambridge,Ontario
    don't worry about the water it will just intermix with coolant as soon as it gets up to temp , its a small amount so wont change it to much .. or do what I did whan I was a kid. I had a large balloon a blew up , put it over the hose then let it go
    lol
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Mar 24 2013
    Oakdale, CT
    IIRC, the top hose is the outlet.
    -Adam
    Oct 24 2015
    Perth, WA
    You want to do it in reverse. Ie reverse flush with some CLR Clear and warm water. Leave it over night. Then flush with clean water and replace.
    My respray thread
