Results 1 to 19 of 19
    Deactivated Four Rings derek2079's Avatar
    Aug 02 2004
    UT
    Coolant mist/smoke coming from engine bay after I turn off my car
    After a drive in my car and shutting it off my engine starts to make a coolant smoke. It would also sometimes leak what I believe is coolant because it smelled like it and looked like it but I'm not absolutely sure. It did this the time I overfilled the oil by a few quarts but stopped after I changed the oil and now it's back again. It has 147k miles. I am doubting that anyone here can diagnose it without actually seeing it but I figured I'd give it a shot. Also my engine isn't overheating at all.
    Veteran Member Four Rings jaychen's Avatar
    Feb 19 2011
    Earth
    probably oil dripping from vc onto manifolds
    2000 Achat S4
    Established Member Two Rings bwizard's Avatar
    Oct 10 2016
    Colorado Springs, Colorado
    Quote Originally Posted by jaychen View Post
    I agree
    Sent from my S4's talk to text @ a buck thirty
    weekly driver 02 S4 2.7t auto stock
    Wife's 04 A4 1.8t auto stock
    Daughter's 97 A4 AEB Bored to 2.0t K04 sport cams
    My role family tech.
    Aug 02 2004
    UT
    Is it still safe to drive? I check my oil frequently including today and levels were good.
    Oct 10 2016
    As long as levels are good mine mists when it's cold oil drops from vc onto turbos after is warm no problem
    Aug 02 2004
    UT
    What's a vc?
    Oct 10 2016
    Valve cover gaskets leak common problem
    Aug 02 2004
    UT
    Oh it's probably that. When I bought the car the previous owner said they were bad I think.
    Feb 19 2011
    Earth
    just look at them..
    2000 Achat S4
    Aug 02 2004
    UT
    just look at them..
    Haha you assume way to much of me.
    Feb 19 2011
    Earth
    what have you been doing the past 12 years
    2000 Achat S4
    Aug 02 2004
    UT
    Actually sold my car in 07 and didn't buy another til 2015 which was a BMW. Got tired of that car then just bought this S4 in August of 16. However I digress. I don't believe you would be satisfied with a single answer I give you. So were past that now. Thanks for your input. I'm going to try to find a video on how to change my valve covers.
    Feb 19 2011
    Earth
    just rip everything out till you can take the vc's off. pretty simple really
    2000 Achat S4
    Dec 05 2007
    It's just bolts and nuts. Then parts that scare the crap out of people...held on by nuts and bolts. Look past the part and that mind trip hurdle can be jumped. Makes things easier after that.
    Aug 02 2004
    UT
    I have a bad back so it would be kind of a hard Job for me. If I hired someone off craigslist to fix it can anyone say how many hours it would take? Because a lot of craigslist mechanics are crooks.
    Oct 10 2016
    It took me 1.0 hr to do both of mine but I have been wrenching for 30 years search for your year/make/model book time
    Aug 02 2004
    UT
    Ok thats good to know. Thank you
    Jul 04 2012
    Woodbridge, VA
    When I did mine first time it took me maybe 3 hours both sides.
    Veteran Member Four Rings 88ninety9's Avatar
    Nov 02 2012
    Four rings and a long roof
    Indianapolis, in
    Only 16 10mm nuts, literally an hour job tops if your back can take it. Best advice I can give you is NOT to have some random off craigslist wrench on your s4. Biggest mistake you could make IMHO
    2002 Pearl/onyx S4 Avant
