A couple of things. Some B8.5 cars will stick in Individual mode when you cut the car off if that's what you were in and then when you start it back up, it'll still be in that mode. Some will not do this and flip back to Auto. Has to do with software revision on it and/or model year. Additionally, if the car was used when you bought it, the previous owner could have coded it via VCDS and those don't always get reset even if the car is CPO'd by the dealership before sale to you, so some of you that start in Dynamic all the time or whatever, something other than Auto or Individual, are most likely coded like that.
Now, if those with B8.5's are saying that even when you set ADS to full Dynamic or you set your Individual mode to have engine/trans on Dynamic and you move the shifter from Park to Drive, the DIN shows "D" as opposed to "S", I can tell tell you that you're no longer in Dynamic (which is the same as Sport or "S"). I don't know why for the life of me Audi would do something like that, but since the Engine AND Trans are bound to the same ADS mode, there is NO WAY that you could be in Dynamic and have the DIN shift indicator show "D" and have the engine/trans in Dynamic... no way... Seems stupid for Audi to allow ADS to be flipped and engaged to Dynamic and then force the user to put it in Drive and then flip it again down just to put it back in Dynamic. Seems stupid and counterintuitive to the idea of them having a flipdown for D/S, which was their solution to give the user a quick way to flip the car into Dynamic mode since the B8.5 does not have ADS controls on the dash anymore which would arrow to each mode with just a single press or two of a single button. In the new models it's all via MMI and that's time consuming when in traffic and you need a quick way to flip to Dynamic, hence the shifter option of a quick pull and you're there. Hope all of this is clear to you guys.
