Results 1 to 12 of 12
    Oct 26 2015
    South Dakota
    Switching maf sensors
    I know this is probably quite the noob question and I am a noob, my maf sensor is going out, threw a check engine light for misfires and running lean on both banks after I pulled the y pipe looking for a power steering leak. Ran fine before I did this and I did hit the maf sensor a few times in the process. My car is a stage 3 and I was wondering if it would matter if I switched from whatever sensor is in it to a hitachi one, the one thats in it looks like it might even be stock but I know its not a hitachi. While searching I read a little bit about hitachi reading different compared to bosch etc. I do have the epl fueling kit with their maf housing. Any information helps! Thank you!
    Veteran Member Four Rings FlyboyS4's Avatar
    Jan 06 2007
    Mk7 Golf R
    FL
    I think it would be quite the coincidence that the MAF sensor went bad in conjunction with pulling the y-pipe. You sure you don't just have a leak?
    If you have the EPL MAF housing then I would be very surprised if the sensor were anything other than Hitachi.
    Veteran Member Three Rings Corradovolksb's Avatar
    Aug 29 2013
    2018 VW Atlas
    Phoenix AZ
    My vote is on a leak somewhere. Double check all of your connections and vacuum lines and oneway valves. They can get brittle over time and brake when they are touched. A lean condition will cause misfires if it's lean enough.
    Oct 26 2015
    South Dakota
    I'm not the most experienced working on cars and my first thought was vacuum leak too however after the car readjusted my boost gauge was reading 18-20 hg in vacuum at idle. I might have hit the maf sensor a few times because I found some traces of oil in the ypipe and maf housing so I was wiping it off. Could be a hitachi and I'm just stupid, I searched the part number from the maf sensor and it came up with some b7 maf sensor so I was assuming in might be the factory maf sensor. Thanks again for all reply's!
    Jan 06 2007
    Mk7 Golf R
    FL
    The boost gauge will be reading from the intake manifold or fuel pressure regulator line, the location of your leak is most probably prior to the turbocharger, so the boost gauge reading is irrelevant.
    Aug 23 2016
    richmond VA
    Even if you change MAF from Bosch to Hitachi , gotta have pigtail adapter , gotta have diffrent tune , you have to some changes to your cluster change codes
    Easy way just dowble check you MAF , you my drop it or something now it's acting up
    Oct 26 2015
    South Dakota
    Quote Originally Posted by tasinb5s4 View Post
    Thank you, that's what I was wondering.
    Oct 26 2015
    South Dakota
    Quote Originally Posted by FlyboyS4 View Post
    Any common places to look for a vacuum leak? I only pulled the air box and the y pipe, never disconnected the maf housing and accordion just set them to the side.
    Veteran Member Four Rings erykv1's Avatar
    Jul 01 2014
    'murca
    your best bet is to build a boost leak tester. theres only so much you can visually check.
    http://www.vaglinks.com/Docs/Audi/C5...ure_Tester.pdf
    Feb 27 2011
    Winnipeg
    what kind of changes do you have to make to the cluster coding? just curious
    Oct 26 2015
    South Dakota
    Quote Originally Posted by erykv1 View Post
    Will do, thank you!
    Aug 23 2016
    richmond VA
    you have to change values ,
    Google it it will come up on Wikipedia
