So I have an AWM with about 189k on it. It runs beautifully and strong. No CEL or stored codes in vagcom. However, the temp gauge takes forever to come up to the middle. Like after 25-35 minutes of highway driving, it's only at the second or third mark between halfway and Cold. On shorter trips, it doesn't even move. Heat and AC works all the time (idle and cruising). Coolant level is always fine in the reservoir. Like I said no drivability issues nor is my gas mileage bad. Do I have a bad thermostat or coolant temperature sensor? I'd rather not just throw parts at something and hope it fixes it. Thanks
