I have a full Milltek stainless exhaust and it's not too bad, but it also is the "non-squid" version and has the resonators AND mufflers. It was on the car when I bought it, so that's the only reason it is there.
I do have an HFC (high-flow cat) and after 10 years, if you are still on the OEM cat, it's probably getting near to it's EOL (end of life) and an 034/JHM/youpick HFC is cheaper than OEM and I'd call it a maintenance item....
I have a K&N panel filter because I do a ton of miles and like the reusability. A can of MAF cleaner is cheap, and I always let it sit for 24hrs after re-oiling to let it dry.
I'm on JHM 91 octane Stage 2 because the components were there (otherwise I'd have just gone Stage 1) and CO only has 91 readily available.
I like a quick car, but it has to be comfortable, reliable, and not annoying to drive (i.e. no fart-can/ridiculous exhaust note). My truck is a older diesel, so it's LOUD in comparison, but I did NOT do stacks because of the annoying exhaust note issue. These cars are stylish, comfortable, and simply enjoyable. If you want fast, then get an RS6 and throw on a tune. You can do 185mph+ with just that 1 mod. If you really want fast and have the stones, get a sportbike. For what some guys spend just on a motor build, you can have a bike that will do 10's in the 1/4 mile and nearly 200mph.
