Okay I will try to make a long story short I have a 07 Audi s6 5.2L v10. I purchased this car because the dealership I work out sent it wholesale due to supposed carbon build up that caused misfires at cold start up. I drove the car for probably a week before I fixed anything. The misfire was pretty prominent at cold start up and would then go away after it warmed up. So I did multiple carbon cleans (sucked through the intake) and it improved a lot. So I dug a little bit more on the internet and found that the pcv valve can cause my issue and are pretty common. Well my lower oil pan was leaking and I was slow at work so I figured I would knock that out. Resealed my oil pan and the check engine light went out by itself! Awesome im thinking as im waiting for my pcv valve to get here. Drove the car for a couple days and then my check engine light came back on and I started to leak some oil. Im assuming the oil pan go a hole sucked in it due to the bad pcv valve but I could be wrong. Replaced the oil pan gasket again and the pcv valve. Car ran great, probably the smoothest it has ever ran. This morning it was a little chilly and the car was missing for some reason. I pulled the codes. I will try to upload pictures. I have secondary air injection codes, mass air flow and 4 misfire codes, cylinder 7,3,4,9. Does anyone have any ideas or experience with a similar situation?
