Results 1 to 22 of 22
    Veteran Member Three Rings mcbuck's Avatar
    Mar 21 2010
    '19 Jeep Wrangler Unlimited Rubicon, '16 Grand Cherokee, '12 328 cab
    Charlotte-ish
    D3S replacement bulbs
    I had the right headlight go out last night driving home through the mountains, so I am looking for replacements. Did some searching and there is some info out there, but not much.
    Leaning towards the Philips X-tremevision 4800K 42403XVC1 bulbs from HID concept. Curious what others have used as replacements, where bought, and impressions. And spare me the 8000K purple-durple bulbs or the $30/pair amazon specials.
    BUCK
    2011 A4 quattro, 2.0T, A/T, Deep Sea Blue Pearl (my son's car, but guess who gets to work on it?)
    GONE 2013 RS5 Daytona Grey Pearl, X-pipe, 20% tint, Arc Audio/Alpine, interior/backup LED, 034 RSB, H&R sport, V-FF 103, 285/30 DWS06, Girodisc, Hawk
    GONE - B7 A4 quattro, 2.0T, 6MT, 250K....dropped, tuned, and everything else
    Senior Member Two Rings meisladrs's Avatar
    Jul 14 2013
    Huffy 10 speed And rollerblades , dead hipsters
    Denver ,Co
    +1 on the Philips x-tremevision
    And non clear lens combo
    Made a big difference
    2012 a4 avant. APR STG2, Apr turbo back, O34 mounts/ braces, And skid plate for Denver crappy roads, Blue line coilover -no Bueno, 19" lm reps, Hid Clear lens swap, APR carbino intake, eurocode turbo pipe
    And slipping 8 speed trans
    So back to my tricked out huffy 10 speed
    past rides b6 a4 avant ,Mk4 Jetta - ex destroyed, 1963 bug
    Veteran Member Four Rings HazeMyth's Avatar
    Jul 17 2015
    Colorado
    I haven't had to replace bulbs on my Audi, but I've used those Phillips replacements on my Evo and STI in the past, and I was happy in both cases. I've always ordered them through Amazon Prime in the past.
    2013 Audi S5 - EPL Stg 2 E40 ECU/TCU, AWE Track 102mm, RocEuro intake, etc.
    2014 Audi Q5 S Line
    2011 Toyota Tacoma TRD Sport - Lifted, reinforced, and slow
    2003 Evolution VIII - HKS280, FBO
    2004 Subaru STI - Stg. 2 (Sold)
    IG: @MrHazeMyth
    Veteran Member Four Rings yjypm's Avatar
    Oct 08 2015
    This thread of mine has some of my thoughts on the Philips x-treme vision
    http://www.audizine.com/forum/showth...lights-Removal
    Current: '18 M3 ZCP
    Mods: | E85 | BMS Intake | MPE | BBS Fi-R | Brembo GT F+R BBK |
    Sold: '14 Estoril Blue S5 P+
    | B&O | Sports Diff | B&W Nappa | Nav |
    Mods: | EPL 179/57+DSG | P&P TB | Revo SC Cooler | Ecode Head+Tail | ECS RS5 Front BBK | Macan Ducts | Brembo GT Rear BBK | AWE Touring | IE Intake | Bilstein B12 | USP Led kit | CR-15 | 034 Rear SB+Links | AluKruez | ECS Trans+Diff Inserts | Apikol Diff Mount | VCDS | P3 |
    Jan 07 2011
    2013 C300 4Matic
    isn't there a vendor here that sells these bulbs?
    Present:
    2009 Audi S5 Phantom Black
    IG: bknewtype
    Mar 21 2015
    HID Concept
    Mar 21 2010
    Charlotte-ish
    Quote Originally Posted by yjypm View Post
    very nice, thanks! no idea how I missed this thread....
    BUCK
    Oct 08 2015
    Thats because the subject of the thread doesn't mention bulbs
    Current: '18 M3 ZCP
    Oct 27 2009
    Miami, FL | Boone, NC
    How did they break in? I've been wanting to switch mine out.
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Oct 08 2015
    I can't tell how much they have been changed after hundreds of hours but when I'm parking next to a stock b8.5 I can tell that mine is a tad brighter and a lot whiter than his. Just to be clear, they will never reach the whiteness (or blueness) of led headlights or 6000k bulbs but in terms of a balance between brightness and whiteness the x-tremeVision is by far the best you can get.
    Current: '18 M3 ZCP
    Veteran Member Three Rings NuVega's Avatar
    Feb 06 2010
    Las Vegas, NV
    Quote Originally Posted by mcbuck View Post
    I would check first to see if your ballast didn't go bad before buying new bulbs, based off of your signature you have a 2013 RS5 and OEM bulbs from the factory I'm assuming, so these bulbs are suppose to last roughly 6-7yrs before they completely become dim, but it only has been 3 years for you and you say the bulb is out all together. Do the old fashion bulb swap test, move the working bulb to the other side, and see if it turns on or not, if so, bulb issue, if not, ballast issue.
    Instagram: donomoko
    - 2014 S5 3.0T Prestige - : Plain ole S5 w/ a few cosmetic mods...
    Mar 21 2010
    Charlotte-ish
    Bulb actually lights when car is restarted but goes out as soon as it moves. But yes I will do the swap before ordering new bulbs.
    BUCK
    Jul 18 2016
    Albuquerque, NM
    That sounds like a bad ballast then to me. My old MB did that and it needed the ballast. If bulb is out it should not light at all.
    Senior Member Two Rings Tomieg's Avatar
    Aug 20 2016
    I've been running the latest PHILIPS Ultinon 6000K 42403WXX2 DS3 HID BULBS and have been very happy.
    Purchased them thru HID CONCEPT
    http://www.hidconcept.com/
    Oct 27 2009
    Thanks! I'm definitely looking for more white and greater brightness, but without it looking too aftermarket. I'd probably find 6000K too blue. So the xtreme vision sound perfect.
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Mar 21 2015
    Not sure if there is a sale going on with HID concept right now but they are frequent. Might be worth a shot to wait to buy them so you can save some coin.
    Oct 08 2015
    ^this
    They often have 15% even 20% off
    Current: '18 M3 ZCP
    Mar 21 2010
    Charlotte-ish
    Quote Originally Posted by usjwes85 View Post
    Did the bulb swap last night. Bad bulb initially lit, but went out after about 20 minutes of driving. Interesting note - when it lit, it had a noticeable pink color to it.
    So definitely bulb, not ballast. Ordering new ones today.
    Another interesting note - there was an older thread where the recommendation was to "just buy OEM, everything else is junk". What I assume to be the OEM bulbs in Greta are Philips Xenstart and seem to match up with $70/each bulbs on ECS. The bulbs they have listed as genuine Audi are $173. Going by part #s, most list these bulbs as interchangeable. Maybe there is a $100 difference, maybe not. I don't know, I'm going with the XtremeVision.
    BUCK
    Oct 27 2009
    That's the plan
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Mar 21 2015
    That's the plan
    FALL15 is the HID concept coupon code right now
    Veteran Member Three Rings ip428's Avatar
    Jan 01 2015
    B8.5 S4 6MT, B8/.5 A5 6MT, 996 C2 6MT
    ATL
    Phillips FTW. Been rocking the CBI 5000K Bulbs for the last year, amazing quality
    B8.5 S4 6MT - KW V3/JHM/Magnaflow, etc etc
    B8 A5 6MT, SR66 Widebody, Unitronic Stg II+, HPA K04, Etc etc - SOLD
    IG: @infamous_m0
    ACNA Member
    Mar 21 2010
    Charlotte-ish
    BIG to Mike at HID Concept. Had a package when I got home from vacation, but apparently shipping dropped the wrong bulbs along with the wrong packing slip into my box. Called Mike on monday and explained, he called back just a few minutes later and said it was taken care of. Called back on Wednesday just to follow up, Mike said "check your mailbox, I show them delivered about 25 minutes ago." Sure enough, in the mailbox they were.
    Original mistake occured in shipping but no big deal. It WAS a big deal that it was corrected quickly and with minimal fuss. Nice job!
    BUCK
