Results 1 to 10 of 10
    Active Member Two Rings jcundy2's Avatar
    Jul 29 2014
    Tampa, FL
    Question Where does this bolt go?
    I found this bolt on the road right where I park my car every day. No oil or fluids on the road. I checked rear diff and the plug is in there. Any ideas what this could go to?
    2011 Audi A4 2.0T Premium
    Established Member Two Rings JesssMooo's Avatar
    Mar 31 2015
    Have you ever replaced your oil drain plug? That's what comes to mind from your pictures.
    2013 A5 | Prestige | Ibis White
    Veteran Member Four Rings jfo's Avatar
    Nov 17 2010
    Courtenay, BC, Canada
    It certainly looks like a drain/fill plug that is used on the rear and the fill on the front differential. Perhaps not from your car.
    2011 A4 Avant
    Jul 29 2014
    Tampa, FL
    Okay so i have yet to check the fill plug for the rear diff, just the drain plug on the rear side. Is this located on the differential side facing the front of the car?
    Nov 17 2010
    Quote Originally Posted by jcundy2 View Post
    It's on the drivers side, about in the middle of the housing.
    2011 A4 Avant
    Active Member Two Rings GTRAFF's Avatar
    Aug 22 2004
    3 Acuras - 1 TSX, 1 TL, 1 RDX and 1 Audi A4Q
    Lawrenceville, GA
    Looks like the bolt holding the heat shield above the turbo. It is one of three and the only one with a large flat head. Look above the turbo to cat connection and under the heat shield. Should see a missing bolt.
    Veteran Member Four Rings poweredbyaudi7's Avatar
    Dec 19 2006
    996TT
    San Antonio, TX
    Quote Originally Posted by GTRAFF View Post
    This is what I thought it was as well...
    '14 A4 Q6MT / APR KO4 / AWE / HRE / H&R / 034 Motorsports / P3cars / JHM
    Jul 29 2014
    Tampa, FL
    wow good call! Just checked. This is what I found. not sure if it was the same area you mentioned. Bolt still looks a bit big to fit but I'm obviously missing a bolt there. FYI I also had a new create engine put in at the dealer after the oil consumption repair failed. so idk if its a newer motor that would have blank thread for newer adaptations or if the bolt just slowly jiggled out of that spot over 10k miles. After it cools ill see it she fits. you guys think this is where it belongs?
    Jul 29 2014
    Tampa, FL
    Nov 17 2010
    No, that's not it. Mine is also empty at that hole. The screw referred to on the heat shield is up underneath the shield and is hard to see without a mirror. Based on your pic, it also seems to be smaller than the one you found.
    2011 A4 Avant
