Interestingly enough, not to drag this back up.
I had my hose replaced about 6 months ago under Audi Certified Warranty.
It was fine up until about 1 month ago. Started doing it again,
Took it in, they said not a safety issue and they couldn't duplicate.
I took it back 2 days later and had a discussion, they agreed to look again.
here is the response:
The A4 inspection is now complete. My shop foreman did all of the re-inspect work and rechecking. I was in the vehicle this morning for the cold start recheck when the vehicle was started up and driven. I have attached a copy of the repair order with all of the notes and findings. I was also in the two vehicles that were used for like comparison testing. The feeling you are concerned about is quite normal for this model and can be duplicated rather easily on like Audi vehicles. The information I received from Audi was good, however the boot seal is not at fault on this vehicle and does not need replacement.
I do want to assure you that the vehicle steering operation is safe and is not showing any signs of component failure.
I did have the vehicle washed up just now and I will be handing over the repair order to Robert Spah for completion.
If you would like, I will gladly take you in a similar vehicle to compare when you come in to pick up your vehicle. There were three here yesterday – I will check the lot today. Usually have one or two on the lot.
Sincerely,
I call bulls**t on this deal.
Here are the notes on the work order
,,,67433 NORMAL OPERATION CHARACTERISTIC PERFORM STEERING SYSTEMS
,,,,RECHECK. RECHECK AUDI KNOWN CONCERN BULLETIN DATA BASE. CHECKED VEHICLE
,,,,PER BULLETIN# 2034351/6 FOR CREAKING OR SQUEAKING NOISES FROM STEERING
,,,,COLUMN. PER BULLETIN INSPECTED THE COLUMN SHAFT SEALING BOOT (FOUND IN
,,,,GOOD CONDITION). INSPECTED POWER STEERING FLUID SYSTEM AND FOUND ALL IN
,,,,PROPER WORKING ORDER WITH FLUID AT PROPER LEVEL. PERFORM PARKING LOT
,,,,MANEUVERS IN ATTEMPT TO DUPLICATE THE CONCERN. ALLOWED VEHICLE TO SIT
,,,,OVERNIGHT AND THEN PERFORM A COLD START TEST OF STEERING OPERATION.
,,,,FOUND VEHICLE TO EXHIBIT A MINOR STEERING "STUDDER" FEELING AT IDLE
,,,,WHILE VEHICLE SPEED IS AT A CRAWL (FOOT OFF BRAKE AND VEHICLE ONLY
,,,,MOVING UNDER POWER OF THE IDLE SPEED). COMPARED WITH TWO OTHER LIKE
,,,,MODEL A4 ON THE LOT AND ALL HAVE SIMILAR IF NOT EXACT SAME FEELING WHEN
,,,,TURNING STEERING WHEEL AT A CRAWL MANEUVER. SHOP FOREMAN INSPECTED
,,,,VEHICLE DURING ALL STAGES AND CONFIRMED (WITH HIS 30 YEARS OF AUDI
,,,,EXPERIENCE) THAT THIS IS A NORMAL CHARACTERISTIC OF THIS MODEL WITH A
,,,,FLUID PUMP STEERING SYSTEM. THERE IS NO DETRIMENT TO THE VEHICLE DUE TO
,,,,THIS FEELING THAT IS PRODUCED UNDER THE ONLY CONDITION THAT IT OCCURS
,,,,(CRAWL SPEED WHILE TURING WHEEL). NOTE: VEHICLE EQUIPPED WITH NEAR NEW
,,,,BRIDGESTONE SNOW TIRES / SNOW TIRES HAVE ENHANCED GRIP AND DO NOT
,,,,'SLIDE' AS EASILY WHEN TURNING WHEEL AT CRAWL SPEEDS ON DRY GROUND. **
,,,,CARS TESTED FOR COMPARISON HAD ALL SEASON TIRES AND DID HAVE LIKE
,,,,'STUDDER' WHEN TESTING. CONCLUSION IS THAT BASED ON OUR EXPERIENCE,
,,,,THIS IS A CHARACTERISTIC OF THIS VEHICLES OPERATION
I'm not happy at all...I believe they are avoiding this because it is a warranty item hoping I'll go away
Anyone else have any thoughts?
Thanks in advance
