Thread: Gear shift knob
    Sep 22 2013
    Norway
    Gear shift knob
    Hi all, according to this it should be easy to install, can anyone confirm what prosedure to use ?
    https://goo.gl/VTS7Sl
    |A7|3.0|TFSI|B&O|NightVision|HeadsUp|Led Headlights|
    Established Member Three Rings fatherdeath's Avatar
    Jul 20 2016
    2016 Honda CRV EXL, 2006 Dodge 2500 laramie mega cab, 1974 Buick apollo
    Tampa, FL
    I want one from the new q7 and s8
    SOLD:2017 S6 Mythos Black Arras Red interior all the Wayne tech gadgets, RocEuro, EPL stage 1, 15mm front/20mm rear spacers, Eurocode Sways, end links, billet mounts ALL
    American enjoying the autobahn
    Feb 11 2013
    C7 S6
    North San Diego
    you pull the button out of the gear knob, stick something in-between the knob and the button to have it stay in place, then pull everything up. it'll probably take you 10mins max.
    JOEY | '10.5 STi | '13 S6
    Cete | EuroCode | HRE | AWE | Deval | BFI | 034 Motorsports
    Sep 22 2013
    Norway
    Quote Originally Posted by JoeGie View Post
    Tnx, that seems to be an easy thing to do then :-)
    Agree on the S8 version, but I doubt it's doable:-)
    Veteran Member Four Rings PKmode's Avatar
    Sep 19 2005
    Milwaukee, WI USA
    I have a block on eBay at work but note, if the button moves from the side to the front or vice-versa, the you need to the the "heat & twist" mod. I swapped from the C7 to the C7.5 knob and it required this mod.
    Do it right, or don't bother.
