Results 1 to 2 of 2
    Junior Member Two Rings
    Oct 25 2016
    Audi A4 B5 2.8 Quattro, Smart fortwo
    UK
    A4 2.8 starting issues
    Hi All,
    I need help please, my A4 B5 2,8 has been running sweet with only 73k for a 98 model, but a few months ago after a run on the motorway I parked her up no problem, the next day trying to start her was an epic and when she did go the engine was spluttering and could not hold a decent idle speed. I also noticed the accelerator had a delay when pressed.
    At the time I did not have my Vagcom tool, and reading the forums and similar experiences i thought I would look into a few possibilities, so I changed the starter relay, fuel filter and the fuel pump. when I did the diagnostic it showed and intermittent fault on the MAP, so I changed this.
    After this she will start on the first attempt and then run smoothish, but as soon as she is switched off then she does not want to know.
    I have considered whether it could be the temp sensor as that has been mentioned about causing starting issues.
    I did another diagnostic and now it is giving me different readings as below, it is racking my brain now and I cannot drive her as I know she may not start when stopped.
    Help as I miss driving her.
    Address 01: Engine Labels: 078-907-551-ACK.lbl
    Part No: 4D0 907 551 R
    Component: 2.8L V6/5V MOTR AT D02
    Coding: 04251
    Shop #: WSC 00353
    VCID: 3566B9FB0F52D196BE-4A3A
    2 Faults Found:
    17967 - Throttle Body (J338)
    P1559 - 35-10 - Fault in basic settings - Intermittent
    17973 - Throttle Actuator (J338)
    P1565 - 35-10 - Lower Stop not Reached - Intermittent
    Readiness: N/A
    Address 02: Auto Trans Labels: 01V-927-156.lbl
    Part No: 8D0 927 156 BE
    Component: AG5 01V 2.8l5V RdW 7803
    Coding: 00000
    Shop #: WSC 00000
    VCID: 71EE4DEB3BBABDB6A2-4A3A
    2 Faults Found:
    18265 - Load Signal
    P1857 - 35-10 - Error Message from ECU - Intermittent
    00526 - Brake Light Switch (F)
    27-00 - Implausible Signal
    Address 15: Airbags Labels: 8D0-959-655-AI7.lbl
    Part No: 8D0 959 655 L
    Component: Airbag 7 Audi 0503
    Coding: 00104
    Shop #: WSC 06435
    VCID: 3F8ADBD33D6E1BC664-5000
    1 Fault Found:
    00532 - Supply Voltage B+
    07-10 - Signal too Low - Intermittent
    Address 17: Instruments Labels: 8D0-919-xxx-17.lbl
    Part No: 8D0 919 930 J
    Component: B5-KOMBIINSTR. VDO D03
    Coding: 20462
    Shop #: WSC 00353
    VCID: 3566B9FB0F52D196BE-50E6
    Subsystem 1 - Part No: IMMO
    Component: IDENTNR: AUZ7Z0W0345814
    IMMO-IDENTNR: AUZ7Z0W0345814
    1 Fault Found:
    00771 - Fuel Level Sensor (G)
    30-10 - Open or Short to Plus - Intermittent
    Jan 25 2016
    This sounds like a classic temp sensor issue, but this:
    Sounds like it just needs a throttle body adaptation - which I believe only takes a minute or two with vag-com and costs nothing. Start with that and if there's no change get a new coolant temp sensor?
