Results 1 to 32 of 32
Thread: Fender lining
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    Fender lining
    Noticed my right front fender liner was on my tire. There are no missing clips so what the hell would cause the liner to fall on the tire?
    This is the left side, not rubbing but noticed a hole. Is it normal. It's not in the same place as the right side so that makes me think it's not the tires and wheels.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Oct 20 2008
    Denver
    definitely from the tires if you haven't changed anything with suspension. I wore through 2 sets of liners already lol
    Veteran Member Three Rings EHesh14's Avatar
    Jul 16 2010
    Colorado
    yea its your suspension. I have 3 inch holes in both sides.
    Jan 04 2013
    Phoenix, az
    Suspension is stock. Tires and wheels have been on since June. Just so odd that it's not in the same spot on both sides!
    Are they easy to change? If I am damaging them with a stock suspension can't image what happens lowered!
    Oct 20 2008
    Denver
    Quote Originally Posted by cspcrx View Post
    i saw that you were on stock suspension thats why i said it's your tires. i've noticed 255 or 265 tires on 9.5" wheels will rub from sharp turns.
    liners are easy to change, a few plastic screws and all clips. that's it
    Jan 04 2013
    Phoenix, az
    Looks like I need to order the right one for now. Nuts! Thanks guys
    Off to the ECS website I go
    Jan 04 2013
    Phoenix, az
    Ordered new right side liner, figures the left side was on sale but not the right side.
    It is so bad now that its falling on the tire. I keep pushing it back up when I stop. I guess enough has warn away the structure integrity is now lost. May have to just pull it out unit the new one arrives.
    Apr 05 2016
    Portland, OR
    If you can order ones for the B8.5 if they fit.
    B8.5 switched to a plastic liner instead of the fabric based one on the B8s. I imagine it should be more resilient to damages like that.
    Geoff
    Jun 21 2004
    mpls, mn
    Care to post the following for future fitment checks?
    Wheel Diameter:
    Wheel Offset:
    Wheel Width:
    Spacers Thickness:
    Tire Size:
    Jan 04 2013
    Phoenix, az
    Already ordered. Curious if our friends at ECS would pull a pair to compare. They are very flimsy, the B8, units for sure.
    Wheel Diameter: 19
    Wheel Offset: et45
    Wheel Width: 9.5
    Spacers Thickness: none
    Tire Size: 265-35 PSS non Porsche so they are the widest.
    It is just so odd they damage is not in the same place on both sides. My CRX has rub marks on the inner fenders from my 245x13s I run in autocross but its the same spot on both sides were it hits. Perhaps something jumped up and damaged it. It just happened because it was not this way a week ago.
    Veteran Member Three Rings Trent212's Avatar
    Sep 10 2015
    AL
    I have toasted 2 right side liners and my left is wearing now. Stock suspension.
    Wish I could prevent it from happening without changing wheels.
    2018 TT RS - Nogaro Blue | CF Inlays | Black Optic | Design Selection Interior | Red Calipers | Technology Package
    APR E85, Intercooler, Inlet, And intake
    TVS Stage 3 TCU tune
    SRM TB Inlet
    SRM GTX3582
    SRM/Eurocode fuel system
    Oct 20 2008
    Denver
    I've worn through 2 sets of liners on lowered suspension + sway bars.
    19x9.5" - et40 - 255/35/19
    19x10" - et35 - 255/35/19
    Oct 20 2008
    Denver
    forgot to mention i've worn through a set of OEM liners, then plastic liners i bought on eBay for like $30-40 each side
    Veteran Member Four Rings schirm's Avatar
    Apr 23 2009
    1999 bmw z3coup M with 5,000 miles Mint
    Forked River nj
    I wore through my liner on stock suspension with OEM rims and 255 tires.
    2004 A4 1.8t | Avant | 6MT | Stock | Atlas gray |
    2010 S4 | Ice Silver Metallic | Sport Diff | 6 speed | 19 5-Tri-Spoke Wheels | Audi Drive Select | B&O | Silver/Black Nappa Sport Seats | Navigation Pkg | Brushed Aluminum Trim | APR Stage 2+ | Hoen Xenonmatch Fogs | 034 Motor mounts | Roc Euro | black RS4 Grille |
    Past
    2007 A4 | Revo Sg 2+
    2005 Subaru Legacy GT 365WHP
    Jan 04 2013
    Phoenix, az
    This is crazy! Seems to be more common than I realized!
    ECS got back to me that they do not have a B8.5 right side in stock to compare it to. They sure look easily damaged now that I am examining mine.
    Senior Member Two Rings Pawan2013's Avatar
    May 28 2013
    mine are worm on the passenger side, 100% stock, 255 tires. Are the fender liners cheap?
    B8 S4, DSG, Sport Diff, B&O + Nav
    Many Mods
    Jan 04 2013
    Phoenix, az
    left is on sale right now for $109.55 normally $138.80
    Right is $121.58
    I also order a liner hardware kit since I do not know I will break removing the old one or if anything is missing. About $38 for that.
    Much more than I want to be shelling out every year. Liners should not be a wear item. I just got new wheels the beginning of June of this year. This is nuts!
    Jason with ECS said he will compare the B8.5 to a B8 when they get one in to see if the holes and everything else matches up. Hopefully they will and we can use those as they will probably hold up a bit better. This felt fiber crap is stupid and flimsy.
    Veteran Member Four Rings jlaudio's Avatar
    Mar 26 2009
    SLC, UT
    last time i was at the dealer they noticed that my liner is wearing/failing.
    seems to be a much larger problem than i thought. I'll admit i looked at them as if they were crazy when they said i need to replace my wheel liner. I've never heard of such a thing unless your lowered or are running different offset wheels, and i'm stock wheels and stock suspension.
    @ECS - seems like a business opportunity to make a hard plastic one.
    '21 SQ5
    Previous: '10 B8 S4 6MT, 09 B8 A4, 06 S4 6MT, 07 A4 6MT, 02 A4 QM, 99 A4 QM
    Mar 21 2015
    Jan 04 2013
    Phoenix, az
    Crap wish I saw that before ordering
    Mar 21 2015
    I always look there first.
    Jan 04 2013
    Phoenix, az
    I will keep that one on my radar for next time, since the left side has damage already. Not sure how wide it will spread. Hoping it stays as is.
    Oct 20 2008
    Denver
    gorilla tape FTW :D
    also, since i know i'll most likely wear through the liners in the near future, I won't spend over $100 each for them, even the ones I bought on eBay are the plastic ones, they still fit fine and do the same job.
    Veteran Member Three Rings skinnytirez's Avatar
    Dec 28 2007
    GSXR 1000, 2010 A4
    Hayward, CA
    I too have this same issue- stock suspension.
    ECS please come out with an aftermarket fix for AUDI's mess...
    Tried to get the dealer to warranty... they claim its from damage that I somehow am accountable for
    Jan 04 2013
    Phoenix, az
    Wish I could get plastic ones for the B8 seems they are all this felt crap! Still hoping that the 8.5s will fit the 8s. That will help right there!
    Apr 05 2016
    Portland, OR
    No joke, I am kind of surprised people are rubbing through the B8.5 ones. They are pretty thick plastic and I don't see how ECS could improve on them other than reinforcing the areas known to rub.
    I am not surprised at all that people are destroying the B8 ones. Those things are super flimsy, especially when wet!
    FWIW, back bumper on a B8 and B8.5 are slightly different, this may cause issues for the few screws that go there.
    Front bumpers are also different so there may be some slight modding needed to get a good fit.
    I think the cab section is the same so hopefully that will line up perfectly.
    Ultimately I think replacing both would be wise for those that are slammed. Maybe just the fronts for those who don't also rub in the back.
    Geoff
    Jan 04 2013
    Phoenix, az
    I hope the fronts are the same, I also hope Jason at ECS will come through on a comparison of the two.
    Sep 19 2012
    Easton, PA
    Did anyone ever confirm if the B8.5 plastic fender liners fit B8 models with the crappy felt liners?
    2012 S4 Premium Plus | Phantom Black | Black/Silver Nappa | Carbon Atlas | 6MT | Sports Diff | Advanced Key | 18" OEM Wheels | Rear Side Airbags | V1 Hardwired | Roc-Euro Intake | Borla Exhaust | CR-15 Strut Brace | Up next...BBS CH-R 18"
    Sep 19 2012
    Easton, PA
    Quote Originally Posted by AudiTFSI3o3 View Post
    gorilla tape FTW :D
    I tried using the one from Amazon for the right front fender on my 2012 but it did not fit well. The trailing edge left a gap from the fender which would have allowed crap to get inside the body void. And, the at the lower front, the liner did not line up with the clip and screw holes.
    Did these work for you?
    Jan 04 2013
    Phoenix, az
    Quote Originally Posted by Captain Tuttle View Post
    Nothing from ECS yet. Replaced mine last Thursday with the fiber one.
    Oct 20 2008
    Denver
    these fit fine. all the holes lined up, got every single clip and plastic nut to fit like they should.
    Jan 04 2013
    Phoenix, az
    It would make sense since they are made for your car. I think Captain was trying B8.5s on his B8. I am still hopeful that ECS will come back with a comparison as promised.
    But Captains findings are not promising.
