I i figured is final time to post on here after failing to figure out why my boost levels are so high. i got a stock 2010 a5 quattro with 6spd manual and according to my p3 gauge i see 20psi at low rpm and slowly tapers down. for what i have read stock i should be seeing 10-12psi and stage I 16-18 so why am i seeing 20? i just want to make sure every that everything is fine because i am about to go stageII soon and don't want to run into problems because of this. could it be that the p3 gauge can not read boost correctly?
in this video i do a 4th gear pull all with the gauge set to boost (psi) at low end it at 20 and starts tapering down and at redline it get to abut 5 i believe.
here i didnt 2nd and 3rd gear pull and same results 20psi low rpm and tapers down 5psi at redline
here doing normal drive at 3/4 throttle from 2nd-6th gear and the lowest i seen is 15psi?
at first i thought that the car might have stage I but it is limited to 130mph and from what i know any tune will unlock the limiter so i figured it is stock. does anyone has any ideas to why this is happening? and do i have anything to worry about?
