Results 1 to 29 of 29
    Oct 24 2016
    1997 Miata
    Dallas
    Akebono Euro vs Stoptech Sport
    I know this has been beat to death but I'm having trouble finding a direct comparison between the two. I think I tried the Stoptech Streets (they were Street or Sport) on a different car and they weren't aggressive enough for my taste.
    I just crested 33k and have to replace the front pads and rotors. At least that's what Firestone and Audi have told me. Just looking at them through the wheel it seems like they have plenty of pad material, but I digress.
    I've seen a number of things about the Akebono (in no particular order):
    1. Low dust.
    2. Less initial bite.
    3. Linear.
    I haven't seen nearly as much about the Stoptech Sport pads. Has anyone used both and can comment? I assume the Stoptech Sports have better fade resistance but how much better? How does the torque compare between them? I'm also interested in overall pedal feel. I was running Ferodo DS2500 on my previous car and liked everything but the dust, even though I wasn't getting them up to temp often enough. Plus, the dust seemed a bit corrosive. I have little doubt the Akebono's are sufficient for everyday driving but are they up to the occasional autocross (which I intend on doing after sway bar(s) and possibly front UCAs)? Track use isn't a consideration for these. I'd get different pads for that.
    Apr 10 2016
    Reading/PA
    IMO, the akebonos are not good for spirited driving. Mine start to fade badly after 3 or 4 aggressive brakes.
    If you want to autoX, I'd suggest something else.
    2011 S4 P+
    Unitronic Stage 2+ ECU / Stage 2 TCU | JHM 179 Crank Pulley | Vogtland Coilovers | CR-15 | Eurocode Intake Pipe | Drilled Airbox | ECS X-Pipe | ECS Rotors | VMR 710 19x9.5 ET45 | 265/35 Pilot A/S 3
    IG: b8_s4thewin
    Junior Member Two Rings windowguy's Avatar
    Jan 08 2015
    I like EBC reds. They do dust a bit but I like them a lot. I did a few laps on a track and they got smoking hot but did not fade.
    Rob.
    Sent from my SM-N920W8 using Tapatalk
    Veteran Member Three Rings sirsycott's Avatar
    Sep 20 2013
    Orange County/CA
    Stoptech sports weren't so bad, loss maybe 5-10% bite when compared to stock , i'd say the akebonos are like losing 25-30% bite
    and yes i've driven both pads including a few track days
    I don't trust the ceramics when heated, doesn't give me the confidence after a quick session and lighting them up multiple times
    Stoptechs held up but they did begin to rumble after heating them up ,
    the compound is very soft too, as i noticed the edges and corners were starting to crumble
    akebono low dust, meh bite , ok for daily and some spirted driving, but not to be pushed when canyon driving or heavy tracking
    stoptech, lots of dust, decent bite , somewhat noisy from driving cold weather and will occasionally squeel when stopping, can take a beating but make sure to inspect the pads since the compound seems to be on the softer side
    maybe go pagids or porterfield r4? if your looking for more performance
    if ur after dust and don't mind losing brake bite go akebonos
    everyone likes them, i'm personally not a fan but that's only because i prefer not clenching my cheeks when braking
    Jun 18 2009
    Phoenix, AZ
    Carbotech all the way. Had them on my RS4, loved them, and I like that you can swap in different pads and not worry about cross-contamination.
    2017 Camaro SS 1LE
    Oct 24 2016
    1997 Miata
    Dallas
    Thanks guys; this is exactly what I needed to know. Akebono's are out.
    Quote Originally Posted by sirsycott View Post
    More performance than the Stoptech Sports? As I understand, Pagid makes the OEM compound correct? Which compound do you mean, exactly for the Pagids? You mean the R4-S (street)? Have you run either of them? If so, how do they compare to the Stoptech Sports or Ferodo DS2500s?
    Quote Originally Posted by FWP! View Post
    Which compound? I've used the AX6 compound on my Miata and liked them well enough. Very different car, though.
    2013 S4 MT
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by MadCoder View Post
    1. Low dust.
    3. Linear.
    I have Stoptech Streets and i hate them.. the lack of bite vs stock caught me off guard and scared me shitless .. i've now adjusted my braking habbits
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Nov 28 2015
    Montreal, QC
    the more i read about pad, the less i want to switch to aftermarket.. will simply deal with dust. Seems like OEM did a VERY GOOD job at offering awesome performance. Also, after a full year of ownership, i never heard my brake squeal once, even in -20celcius winter day.. I know the pad were replaced so maybe it has to do with the installer using anti-squeal paste or something like that to reduce sound. So for me, the only downside is dust.. I prefer performance over dust tho.
    S4 B8.5 no track, just enjoying spirited driving.
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by waxxonMTL View Post
    lol i just now noticed after you said this that my squeal is gone.. now i feel a little better about them. my Stock pads would squeal ALL the time.. even 75 degrees .. i don't mind dust either .. i have unlimited car washes at my local hand wash place
    Present:
    Veteran Member Four Rings SDV325's Avatar
    Jan 20 2014
    Calgary, AB
    Quote Originally Posted by doug97gxe View Post
    Second. I know some hate that initial bite, but I loved it. Definitely saved me once or twice in stop and go traffic.
    I will add the Stoptechs have very little dust in comparison to OEM brakes. The rears I never notice getting too dirty (OEM) but the fronts I can go for days or weeks and have minimal dust on the wheels, where OEM would be dirty after 1 drive. This is on the OEM rotors, hard to see on the darker wheels.
    OP, if you didn't like the aggressiveness on the stoptechs the ceramics will be much worse for that.
    Id like something similar to the OEM bite but without the dust as well, but I think if you want bite you'll get dust. Just a fact of life haha
    2016 Audi SQ5 | Technik | Glacier White | Magma | Black Optics | Beaufort Inlays | Roc-Euro | Revivify Graphene Pro | EPL Stg 2 | Eurocode USS | MOOG Endlinks |
    2014 Audi SQ5 Estoril- STOLEN / RIP
    2015 Toyota Rav4 - Family Wagon
    Oct 24 2016
    1997 Miata
    Dallas
    To clarify, I think and hope I was using Stoptech Street pads and they weren't aggressive enough. Those are not in consideration. The Stoptech Sport pads are.
    2013 S4 MT
    Jan 09 2008
    Winnipeg
    I have the StopTech Sport pads (used to be called Street Performance pads I believe). I like them fine although they do not have the initial bite of OEM pads. I think they dust less than OEM but I can't speak to the squealing yet as temps are just starting to drop and I only really had squeal in winter.
    I think I prefer the StopTech pads for autocross though. The OEM are great on the street but after switching to these pads and adjusting my braking, in autocross it allows me to upset the car less if I have to stab the brake in a transition. In street driving you need to press a bit harder to get the OEM level of braking. The hard initial bite is gone but I have not had a pucker inducing incident like Doug though.
    Oct 24 2016
    1997 Miata
    Dallas
    Quote Originally Posted by eurotic View Post
    Now you have me wondering if I used them before. Street Performance sounds familiar. IIRC the torque didn't compare to the Ferodo DS2500s and they started to smell without much heat. I probably shouldn't be comparing to those since they're kind of in another class.
    2013 S4 MT
    Mar 05 2015
    2009 A4 Cab: S-Line / 1996 Camaro Z28
    East Granby CT
    I love the R4-S on my Subaru LGT and will be switching the S4 over.... They are actually designed for heavy Street abuse (with fade and low dust requirements) and can be used during AutoCross/HPDE Events!
    PorterField R4-S Pad Description
    If looking for a track specific pad - I would think R4 would be excellent based on my experience with the R4-S - But have no qualms about the R4-S as a street pad!!
    2012 Moonlight Blue Metallic S4 | Premium + | DSG | 19" Peelers |Sports Diff | MMI w/Nav | B&O Audio | Advanced Key |
    After-Market Add-Ons: Rallitek Aluminum Paddles | USP LED Interior Lighting | Phillips Xtreme +50% Headlight Bulbs
    Performance Upgrades: 034 Stage 1 ECU & TCU | | APR I/C |
    Stoptech Cryo Slotted Rotors with Porterfield R4-S Pads |
    034 Springs / Koni Yellow shocks | Tires = Michelin Pilot 4S (255/35/19)
    Oct 24 2016
    1997 Miata
    Dallas
    I'm starting to get sold on trying the R4-S pads. Seems like people either really love or really hate them.
    Is there a go-to store for S4 brakes and/or suspension? Guess I can get the R4-S pads direct from Porterfield.
    2013 S4 MT
    Mar 05 2015
    East Granby CT
    I got them for my Subaru from KNS-Brakes.com - they are at least a one stop shop for pads/rotors/stainless lines/fluid if needed. They don't actually list the pads for the S4 - but if you check on Porterfield they do list part #s - so probably just a matter of calling KNS...
    Or just go through Porterfield directly - but their options for anything other than Pads seem limited and expensive...
    Edit: You could also call ECS Performance and see if they carry or can order them - ECS has quite the selection of Brake Products for the S4 - but I've never seen Porterfield on their site.
    Nov 10 2014
    Apex, NC
    I have always had a pleasant experience from ECS
    Present:
    Oct 24 2016
    1997 Miata
    Dallas
    Pulled the trigger on some R4S pads. Forgot to ask about the brake pad sensor. Are they reusable if I haven't had the warning pop up yet?
    2013 S4 MT
    Jan 20 2014
    Calgary, AB
    I believe so, I ordered and replaced mine even though the sensor hadn't been triggered yet either.
    I'm sure someone can confirm this
    Veteran Member Three Rings kobrian85's Avatar
    Oct 23 2012
    I believe the sensor is built into the pad material, it's not something you can add to the pads. That's how it was on my VW... Someone educate me if the S4's work differently...
    2019 RS5 \ Sonoma Green
    IG: kobrian85
    Oct 24 2016
    1997 Miata
    Dallas
    Quote Originally Posted by kobrian85 View Post
    I've seen where you can buy the sensor separately.
    Also: http://www.audizine.com/forum/showth...or-Replacement
    Does anyone know if the R4S pads come with the sensor?
    2013 S4 MT
    Jan 20 2014
    Calgary, AB
    The sensor clips into the top of the pad, definitely does not come with them
    I would assume no as no pads I ever looked at came with a sensor. I considered the porterfields as well at one point, no mention of a sensor
    Oct 24 2016
    1997 Miata
    Dallas
    The Akebono's seemed to come with the sensor. Oh well. I'll re-use them and if something goes wrong/bad I'll deal with it. Can't imagine anything terrible happening from reusing it unless the thing disintegrates on me on removal.
    2013 S4 MT
    Oct 23 2012
    Quote Originally Posted by SDV325 View Post
    I see. Thanks, fellas.
    IG: kobrian85
    Nov 10 2014
    Apex, NC
    Audi charges $79 for each sensor
    Present:
    Dec 07 2014
    Mn
    Just bought it from ecs for $34 I believe. Looks like you only need the one sensor.
    Sent from my LG-H901 using Tapatalk
    2014 S4 DSG///Unitronic Stage 2+.
    Veteran Member Four Rings jlaudio's Avatar
    Mar 26 2009
    SLC, UT
    I bought a set of Akebono euro ceramics from amazon a week ago. They came with the sensor.
    '21 SQ5
    Previous: '10 B8 S4 6MT, 09 B8 A4, 06 S4 6MT, 07 A4 6MT, 02 A4 QM, 99 A4 QM
    Senior Member Two Rings mjames's Avatar
    Dec 21 2012
    2019 Audi Q7
    Lake Wylie, SC
    Been very happy with Akebonos and lack of dust for my daily driver. Like the linear feel vs. stock. Held up fine in spirited driving.
    Jun 18 2009
    Phoenix, AZ
    I use the Bobcat's (1521's) on the street, and XP10 for the front and XP8 for the back for track duty. Really, really great pads. The bobcat's produce very little dust, and I liked the pedal feel on my RS4. The 1521's are known for having less initial bite than an OEM pad, but I will WELCOME that on my S4 seeing as I sort of can't stand how touchy the brakes are all the time.
    2017 Camaro SS 1LE
