Results 1 to 2 of 2
    Jan 02 2016
    Pittsburgh PA
    Washer hose routing 01 Allroad
    Hey everyone, does anybody out there have a diagram of where the washer hoses run? I'm deleting my rear wiper in my 01 Allroad since I have a back up camera and I would like to block the hose that feeds washer fluid to the rear of the car. Id like to block it as close to the pump as possible. Is there a single line that feeds it straight from the reservoir? Does it branch off of the front wipers somewhere? Also deleting my headlight washers since I am running a front mount and they get in the way.
    Jun 10 2013
    United States
    the line connects to the resevoir. There are separate lines for the front and rear wipers. That being said, they use the same pump, but run in reverse. To electrically disable the rear pump action you could probably use a diode.
