urs4/urs6 partout leftovers/EVERYTHING OBO & MUST GO!!!
Every part is OBO and everything must go but please keep
you offers reasonable, thank you. Also all agreed upon prices
must add %3.5 for paypal fees. There are no exceptions.
New build parts:
1. AAN block- hot tanked, black engine paint, bored .5mm over,
machine honed, decked/resurfaced. Comes with main caps,
main bolts, oil squirters & hardware, polished AAN crankshaft
with a good condition stock dampener.
Price will be $1,250 shipped in the lower 48 states. $250-$450
of that will be for shipping depending on location.
2. JE pistons- specs -- Price is $550 shipped
bore: 81.5mm
stroke:86.4mm
compression ratio: 9.5:1
Coatings: None
Wrist pins: Standard JE - no tool steel
3. New black leather urS e-brake boot- $45 shipped
4. New air leather urS e-brake handle- $60 shipped
5. EFI express/jwis aan cam chain- $26.45 shipped
6. AAN cylinder head with a crack where the valve cover
mates. Moron pried the valve cover off. $400 shipped- make offers
7. 034 5 cyl billet cylinder head freeze plug- $26.45 shipped
8. (Used) 2bennett A-pillar gauge pod in black & Autometer boost gauge (30 psi, white face, red needle, backlight)-
$125 Shipped
9. (NEW) ACL non coated stock AAN main bearings & thrust bearings- $100 shipped OBO
10. urS 034 snub mount & bracket- $57 shipped
11. USCAR to EV14 injector adapters- $25 shipped
12. Dealer/factory serpentine belt for urS cars without A/C.
Perfect for those doing an a/c delete. Price is $100 shipped
13. Custom made -6an turbo block
coolant return port- $50 shipped
All of the used parts:
1. AAN water manifold- $65 shipped
2. AAN fuel rail with braided line, FPR still on it and a newer bosch fuel filter- $100 shipped
3. Good Bosch starter- $57 shipped
4. Good Alternator- $64 shipped
5. AAN motor mount bracket set- $65 shipped
6. Good factory upper radiator hose- $40 shipped
7. Mint urs4 orange corner lights- $35 shipped
9. Good 5 speed CBD 01E with wide 1st gear. Serial number 94,798 from a 95.5 urs6
will include it complete. $750 shipped
Another good 5 speed 01E- $250 + freight
10. Good urS locking rear end- $150 + shipping via greyhound
11. Set of OEM GKN urS axle cores- $250 + shipping for all 4 or $75 + shipping per axle
12. x2 OEM driveshaft cores- $65 + shipping via greyhound
13. OEM front brake calipers, carriers, hardware and brand new pads- $150 shipped within CONUS
14. Stock AAN flywheel- $100 shipped
15. Stock AAN K24 turbo very minor shaft play and one broken exhaust stud- $125 shipped
16. Stock AAN exhaust manifold- $100 shipped
17. ECRU rear seat back in good condition- $150 shipped via greyhound
18. Stock AAN wastegate & flexpipe- $100 shipped
20. Nice ECRU rear deck with good speaker grills- $150 shipped via greyhound
includes adapters for aftermarket 6x9 speakers
21. Old style 4 spoke black steering wheel with airbag- $25 + shipping
24. Box with every relay, fuse, and module from a 95.5 urs6- $125 shipped
25. Good 95.5 ABS pump- $125 shipped within CONUS
26. Good 95.5 ABS computer- $57 shipped within CONUS
Also have a 94 s4 abs computer- $57 shipped
31. AAN intake manifold- $150 shipped within CONUS
33. AAN throttle body with TPS- $57 shipped 1 left
34. AAN oil cooler assembly- $100 + shipping
35. AAN air box assembly- $75 + shipping
37. urs4 doors, no trims, (some rust)- $100 + shipping per door or $750 shipped for all 4 via greyhound
Very minor rust but overall in very good shape. Great for replacements
38. urs4 rear bumper in good shape, trims intact, just needs to be resprayed- $250 + shipping via greyhound-- includes all 3 trims and bumper shocks
40. Good set of ECRU door cards- $200 shipped via greyhound
41. Good set of 94' urS window motors- $125 shipped within CONUS
42. Mint brake master cylinder (Factory Genuine)- $107 shipped within CONUS
One is a 95.5 unit and another an early 94. I found out they are different.
44. USED 94' urs4 factory brake booster- $115 shipped
45. USED 94' urs4 clutch master & slave
List Date: 10/25/2016
For more info, click here to view the original listing: urs4/urs6 partout leftovers/EVERYTHING OBO & MUST GO!!!
This item is no longer available.
