Mini thread jack but feel free to ask any questions in my build thread.
The RS rack is easily one of my favorite mods. Very big change in steering characteristics. Much sharper off center and gives a lot of confidence in the corners. Feels more linear. It was immediately noticeable the first turn I took once it was installed. The ratio changes from 16.1:1 to 14.2:1. To give you an idea that's more direct than M power or AMG rivals. It has no servotronic connection and is a direct fit for all C5 chassis cars. I would not attempt it with the motor in, I would think of reasons to pull it and do a bunch of stuff at the same time.
Thanks for the compliments! I'm 100% factory suspension components, save for adjustable control arms. I don't think anything out there works as well as the actual factory continental bags and struts. Stay well clear of Arnott gen 1 or 2 or anything they ever produce. If you want a quality ride, even if you modify the height (actually especially if you modify the height) save your pennies and stick with ONLY OEM bags and struts. I've been there with the other stuff it simply does not compare. Yes it's better than oem with 180,000 miles on them but sucks compared to brand new OEM. I'm 52mm lower in front and 50mm lower in the rear and it rides just fine. Better than my friend's MKV GTI on factory suspension for example.
I had 9.5" wide with 285/35/19 on the back and it fit without any modification. Probably could have gone wide but the diameter would not have been idea with a 295 or 305. On the front I know for sure 285s do not fit. Maybe if you went with a more narrow running tire like a Michelin, but I had to modify my front flares to shove 285s under there. 275/35/19 fits perfectly though and 9.5s fit.
A dmfw can be resurfaced but apparently it's hit or miss whether or not it will be perfect or whether or not a given shop will be willing. I personally would just go with a new one like you did.
I launch like this: my daz tune has launch control set for 4,400rpm. Clutch depressed, first gear selected, throttle depressed. Then I let the clutch up to the beginning of the biting point to take the slack out of the drivetrain. Then when I launch it's not a dump, the power is fed through quickly but not immediately. Despite the clutch slip and 285 front, 325 rear r compound tires I do still get some slip on dry pavement. It feels pretty good!
I'd love it if you came up for a visit and to see the car. It'll be here when you do :)
