Results 1 to 13 of 13
    Veteran Member Four Rings c@@kieMonsta's Avatar
    May 17 2009
    Idaho
    Ugh... Coolant leak
    Alright it's not that bad, but I'm not going to ignore it. Recently, I noticed that after the car has a chance to fully cool off(cooler weather is aiding this too), a nice little puddle of coolant appears near the extreme edge(corner where the edge of the splash pan meets the wheel well liner) of the drivers side engine compartment. Coolant is clean so at least that's a good sign. If I stand over my engine bay with the hood open, I can catch a good whiff of the smell coming from somewhere in between the front of the expansion tank and the radiator. Now, before I go ahead and do a pressure test, I was wondering if there was a common cause for something like this? My initial assumption is a seal on one of the hoses maybe? It can't be a crack because it would be sending coolant out all the time. Anyways, thanks for your tips in advance!
    Current:
    2019 Ford Expedition
    2009 3.0T A6 Avant w/Prestige package, Side Assist, and Cold Weather package
    2016 2.7 EcoBoost Ford F-150 XLT SCREW
    2007 3.2 A4 Deep Sea Blue Avant
    2006 A6 Arctic White Avant
    2002 1.8t A4 Sedan
    Established Member Two Rings pgraham76's Avatar
    Aug 27 2016
    Malvern, PA
    I just had a small leak at the bottom of the line at one of the rubber hose fittings. Looked like the rubber heat cycled too many times and got some dry rot cracking in it causing a drip that sounds similar to your situation. Hope that's it as its cheaper to replace that rubber line than anything else.
    Sent from my SM-G935V using Audizine mobile app
    May 17 2009
    Idaho
    Quote Originally Posted by pgraham76 View Post
    I'm guessing its easily accessible from underneath the car? I'm planning on pulling off the belly pan and starting the car to see where the leak is from.
    Current:
    2002 1.8t A4 Sedan
    Jul 17 2011
    Sin City, USA
    I had a small coolant leak which turned out to be a small crack in the aluminum supercharger cooler (in front of the radiator). It was cracked at the cooling line inlet and traveled down the line before dropping to the belly pan. Had to replace the cooler since it was not something that can be repaired.
    '09 C6.5 A6
    Aug 27 2016
    Malvern, PA
    I did it by pulling the Driver side headlight and plastic fog light cover off to look in and get to it but if you access to a lift I'm sure you could at it from under it.
    May 17 2009
    Idaho
    How much was the part and how hard was it to replace(please say you DIY'd it!)?
    Yeah I was just planning on driving up on some ramps. Should be adequate access.
    Current:
    2002 1.8t A4 Sedan
    May 17 2009
    Idaho
    I found it. Leaking from hose connection at the top. Wiggled it around and it started dripping. It's running back down the hose onto other hoses where it's pooling up in the front of the belly pan, then down and out from there. I spoke with my BIN and he says that it's probably the o-ring at the connection with that hose.
    Sent from my ONEPLUS A3000 using Tapatalk
    Current:
    2002 1.8t A4 Sedan
    Jul 17 2011
    Sin City, USA
    Quote Originally Posted by c@@kieMonsta View Post
    Super charger radiator was $253.
    '09 C6.5 A6
    May 17 2009
    Idaho
    Ight, good news! $3 hose gasket is all that was needed. Replaced in 5 minutes. No leaks since Saturday. Thanks for all help all.
    Current:
    2002 1.8t A4 Sedan
    Veteran Member Four Rings maga4's Avatar
    Aug 12 2011
    Olathe, Kansas
    Interestingly, I've been having a leak for a while, but the local indie shop said that the leak was right under the supercharger and would be 6 hours to fix due to having to take the front end out, etc. He recommended not doing and just replacing the coolant. It drops from max to below min about every two weeks, and no residue anywhere on the ground or belly pan. No clue where it's really going, but it does drive me nuts. Open to any thoughts! Thanks!
    2010 A6 3.0T Prestige, Quartz/Black
    35% Tint, VCDS, Hardwired V1, LED Interior/License Plate, Chipwerke Pro, WeatherTech
    Previous: 2011 A4 P+, APR Stage 2, 35% Tint, Eibach Pro-Kit, VCDS, Gloss Black Grille, Fogs,
    LED Interior/License Plate Lights, Short Shifter, BFI Catch Can, V1, Rieger Lip Replica, FRT's FMIC, aFe Filter
    May 17 2009
    Idaho
    Quote Originally Posted by maga4 View Post
    Did you figure out what the problem was?
    Current:
    2002 1.8t A4 Sedan
    Senior Member Two Rings juniorcruzer's Avatar
    Sep 28 2014
    2007 Suburban
    Center City Minnesota
    Mine has been doing the same thing, and I took the supercharger off today, can't find the leak, but it spewed coolant all over yesterday after getting home. So now trying to figure out what the hell is going on.
    Jon
    2010 S4 3.0T, chipwerks stage I
    2010 A6 3.0T, APR Stage 2+, Roc Euro Intake, VMR V710 18x9.5 HyperSilver, 30% tint, A3 clear marker lights, LED Reverse lights, RS6 Grill
    Junior Member One Ring BillBoost37's Avatar
    Jun 06 2015
    West Springfield MA
    Could that be the thermostat housing or gasket leaking? I know they are both right there under the charger. Seems that the charger intercoolers are fairly well built and don't appear to be an typical leak area
    2010 A6 Prestige in Phantom Black
