Results 1 to 3 of 3
    Established Member Two Rings TVP125's Avatar
    Dec 14 2015
    Palm Beach, FL
    under the hood ECU / Fuse Box diagram (no start / no crank)
    Do any of you guys know which relay / fuse under the hood is for the starter, When I press the start button all the lights, Radio and AC come on but it does not crank or do anything for that matter the motor is totally silent, When I open the door the fuel pump still primes and when I check for codes it comes up with 0. The battery is less then 2 months old and reads at close to 100% still. any help would be appreciated.
    12 Audi A4 S-Line
    EURODYNE FrankenTurbo F23L
    K&N Typhoon Intake
    Magnaflow Sport Series 3" Turbo Back Exhaust
    Treadstone TR8L Intercooler
    ST Coilovers
    Jun 26 2009
    Bremerton WA
    Auto or manual? If manual the hall sensor on the clutch cylinder may be faulty. If an auto try starting in neutral vs park to see if a safety override may acting up. For the manual guys does the start button work when in neutral and the clutch not depressed?
    VMR 710's, APR software, Eurocode HFC
    Dec 14 2015
    Palm Beach, FL
    Thank for the reply. I solved the problem after checking multiple fuses I discovered it was a 5amp fuse that went out. popped a new one in and it started right up.
    12 Audi A4 S-Line
    K&N Typhoon Intake
    ST Coilovers
