Results 1 to 12 of 12
    Established Member Two Rings Pandito bandito's Avatar
    Jul 19 2016
    Missouri
    Going stage one with a Preexisting torque converter fault
    Searching for opinions. Finally have the funds to get my stage one tune but car currently has fault code for a failing torque converter. Ugh. My question is what's the up / downside to tuning the car with the ongoing fault. Not currently experiencing any noticeable symptoms for the torque converter but when scanned it does pull up a code. My question is with a stage 1 tune am I going to tear up the rest of the torque converter should I go ahead and get the tune or hold off until I can replace the torque converter any opinions or advice would be greatly appreciated
    Sent from my XT1585 using Tapatalk
    Oct 24 2015
    Perth, WA
    A tune will put additional stress on the transmission. I wouldn't tune a failing transmission.
    My respray thread
    Senior Member Two Rings drmonkey's Avatar
    Sep 04 2015
    Clear Lake, TX
    This sounds like a no-brainer...I put a tune on my old 06 Jetta TDI and killed the flywheel in the DSG. I would use the money for the tune towards fixing the torque converter, a tune won't do you any good if you can't drive the car.
    Veteran Member Four Rings pezgoon's Avatar
    Jul 25 2016
    new hampshire
    Quote Originally Posted by drmonkey View Post
    Bingo
    Eric
    2005.5 6mt A4 2.0 94k miles
    2010 Q5 3.2L 6at 160k miles
    Veteran Member Three Rings seandon_792's Avatar
    Aug 12 2015
    Waldorf, MD, US
    Maintenance before mods always. If you have to ask it's probably a bad idea.
    Mar 01 2011
    Nanuet NY
    LOL
    Jul 25 2016
    new hampshire
    If you have to ask you probably can't handle the mods anyways lol
    Unless you do the mod to make sure you blow up the failing part and force your own hand to fix it, then you just enjoy pain, I forget what that's called lol
    Eric
    Jul 19 2016
    Missouri
    Masochism
    Jul 25 2016
    new hampshire
    That's it
    Eric
    Jun 27 2011
    Those transmissions are pieces of shit anyway. Just tune it. If you have no symptoms of a failing trans then you really have nothing to worry about.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    At the age of these cars. Tune it and enjoy while your car lasts even if it's just for a 100 miles. I'm so done with my B7. Although I don't really have issues :) just want an S6 so bad. Lol
    Sent from my SAMSUNG-SM-G925A using Tapatalk
    Jul 19 2016
    Missouri
    I haven't even seen that code in months just popped up the once after they replaced my motor an snub mounts I got it back an it showed up on a scan. Took it back to the shop and they couldn't find it. Also threw a brake fault as well but none showed up when I took it back and neither have come back up since. Almost thinking it was an erroneous code as car runs pulls and brakes like a champ.
