Results 1 to 40 of 67
    Senior Member Two Rings soptic425's Avatar
    Apr 18 2016
    Macan GTS, G82 M3 CS
    Giac smoke out exhaust
    Not sure if the pic loaded properly. Had my tune for a couple of days. 2016 s4, Giac stage 2. Saw tons of smoke coming out and when I got home my pipes went from black to white. Any ideas?
    Apr 05 2016
    Portland, OR
    How are your coolant levels?
    Did you add in any additives to the tank? (Sea foam or something?)
    Geoff
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    Saw this on a Lexus forum ... White residue can mean a few things. You can have some abnormal combustion going on and running lean, possibly from misfiring, but may not be enough to throw a code. It can be due to the precat o2 sensors, even if they are working. A good scanning tool can show the waveforms of the O2 sensors. That's the only way to really tell if they are performing correctly, or not.
    Gas that has some lead content would also give you white oxidation on your exhaust tip. You may want to try other gas stations, if you don't already. Some lead content in the gas is a killer for precats. So, as mentioned, it can be a result of them failing.
    The last thing that is true is that one cause is antifreeze from a possible blown headgasket. The only way to be sure and rule that out is to so a leak-down and compression test. Since you're not sure about the coolant level dropping, I would consider doing those tests.
    So agree with the previous post that coolant could be the culprit. Check those levels, and also scan for codes for issues. Let us know what you find. Oh yeah, also heard race gas can cause white residue, but I suspect that's not it here.
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    I can say from personal experience that the GIAC file likes to run on the rich side. I would lean towards coolant (since its not pure white and looks pinkish...similar in color to our coolant fluid...)
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Apr 18 2016
    Coolant levels are good. I haven't added anything. It was running fine then all of a sudden a raspy exhaust note and billows of smoke
    Apr 18 2016
    Yea I definitely read that they run rich. I will try another gas station, but I've been using the same for some time now with no issue.
    Jun 20 2015
    NC
    Quote Originally Posted by soptic425 View Post
    Cats burnt up and that's the residue. Although a 16' I think that would be unlikely.
    Apr 18 2016
    I'm really hoping it's not the cats. The cars 7 months old. I'm going to my shop Wednesday. Will keep everyone posted. Thanks for the responses
    Aug 02 2016
    Yes I have Giac tune and it sure runs on the rich side. I have it now for about a month and all I use is BP/Sunoco 93. I have not seen the white stuff though just small smoke when starting cold. Mine is not a daily driver though. good luck
    USP CLUB MEMBER #213
    |2005 A4 1.8T Quattro- Ultrasport S-Line Package | Brilliant Black | Stage 3|
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    Quote Originally Posted by Sceanzo View Post
    That's what it looks like also, very odd it would happen so soon.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Oct 20 2014
    United States
    Yeah I second that this is most likely the cats. I wonder what would cause them to go so quick though :-/
    Current: 2013 Audi A4
    Sold:
    2015 F83 BMW M4 OEM + (Lots done but not too much lol)
    2014 Phatom Black S4
    Mods:| Unitronic Stage 2 | 19x10 Rotiform Ind-T Chrome stepped lip with brushed Aluminum faces | Avery "Dark Grey Gloss" vinyl | Airlift Performance Bags | Autopilot v2 | 5% tint, APR Stage I + II Intake | Carbon Fiber J-Codes | AK | USS system | Miesterwerk SS | Deval Front Lip | AWE Non-Res DP's | AWE Track Exhaust |
    Apr 18 2016
    Shop just called. They're going to run compression tests and also check the cats. My p3 said code 0420 today, so let's see. GIAC is trying to blame my old APR which ran flawlessly for 7 months prior to this.....
    Apr 18 2016
    What my shop sent. No idea where to go from here.
    Apr 05 2016
    Portland, OR
    Replacing the cats is expensive and they should not have failed on a car that new yet.
    Have GIAC flash it back to stock, drive it around until you get the P0420 code again then take it into the dealership.
    Geoff
    Apr 18 2016
    I think that's the route I'm going. Hopefully I don't get a td1.
    Jun 28 2016
    US
    Flash it back like the other say. But, I bet since it's a B8.5, you'll take it to Audi and they'll probably do the CAT Efficiency TSB flash on it and call it a day. Doubt they'll replace the CATs, but I could be wrong... now, if they flash that update, go ahead and drive around with that some more and hopefully you'll get the code again if the CATs are truly failing and if that happens, then they have to replace them. Also, BTW, the CATs have a higher warranty (or should) than the warranty on the car since they are an emissions component, so don't let Audi give you shit about replacing them outside of warranty (if you're out). I forget what milage they should be covered under but it may be like 80k or so. I know I saw it documented somewhere, so be aware of that.
    Jul 18 2010
    NE Ohio
    Quote Originally Posted by SwankP3RF3ct10n View Post
    Here's that TSB ...
    Apr 18 2016
    Thank you both for this information. Greatly appreciated
    Veteran Member Four Rings RWD2quattro's Avatar
    Dec 29 2011
    Lexus IS250, Volvo 850R, Ford tractor
    The Bay
    What my shop sent. No idea where to go from here. Sent from my iPhone using Audizine mobile app
    Looks like some of the honeycomb on catalyst are plugged? What about the front section of catalyst, I'm guessing that's the rear in photo?
    Also, if you have 551G software version like most late 2015/16 S4's, the flash won't apply to your car. Flash back to stock and go from there.
    BMW M4CS, Frozen Blue, Full XPEL, CCB, DCT. Dinan HAS kit, Fall Line end links, Hotchkis sway bars, K&N filters, CF interior goodies. More goods are coming...
    Gone: 2014 S4, Audi Exclusive DRM, 6MT.
    Gone: 2012 S4, Brilliant Black, Prestige, S-tragic.
    Apr 18 2016
    Just a heads up. Cars been at the dealership for over a week. They did an update. Had to get the CEL to come again then ordered the part from Germany because apparently there are no Cats in the U.S. Part came Thursday and was the wrong part. Hooray. Another 7-10 days since it's back ordered. Yet when I called back for a loaner I was told it'll be done this week. Utter nightmare.
    Jul 18 2010
    NE Ohio
    Hopefully they're going to cover it under warranty. Keep us posted!
    Apr 18 2016
    Covered under warranty! Best news to get on my birthday. Car is at my shop getting retuned and I can pick it up tomorrow. Thanks everyone for your responses.
    Apr 05 2016
    Portland, OR
    Great news for you!
    Happy birthday man!
    Geoff
    Jul 18 2010
    NE Ohio
    Great Birthday Gift! Congrats!
    Apr 18 2016
    Code 0089 - fuel pressure. Back at it again with the CELLLLL. Time to return my GIAC
    Aug 09 2015
    Sarasota, FL
    it may be a 2016-related file. There are two others who received similar codes and theres are 2016 model years.
    Apr 18 2016
    Interesting. I'll have to ask my shop. I believe they put in the refund already
    Jul 21 2004
    South Florida
    The only issue with getting the latest model year. Most of the tuners out there do not test each model year ECU but rather attempt to use calibrations from prior years...and sometimes that doesnt work well. Same thing happened to the 2014 and 2015 MY people. Performance was crap until updates came out for both GIAC and APR. I'm sure theyll get it sorted but doesnt hurt to get the refund now while you can and then repurchase it again once the bugs are confirmed to be worked out. Interesting we pay $1200 for off the shelf tunes because of the "extensive R&D" that goes into them.
    Mike
    2018 Audi S5
    Gone-
    Apr 18 2016
    I hear ya. Yea I definitely don't want to be dealing with any issues. Ever since the tune I had this nightmare of my car in the shop for 3 weeks and then another CEL due to software. No thanks.
    Apr 18 2016
    2.5 weeks and no word on the refund. Hmmm. And radio silence when I email seth
    Apr 18 2016
    Closing in on over a month with no confirmation on the refund. I've had two people mention that they went APR due to this issue and my wait time. I'd be hesitant to recommend this tune as good as it pulled when it worked. Stay tuned
    Jul 21 2004
    South Florida
    Your shop flashed you back to stock but didnt process a refund? Interesting. The shop collects the money I wonder whey they dont issue the refund?
    Mike
    2018 Audi S5
    Gone-
    Apr 18 2016
    This is true. They do collect the money, but they processed the refund through GIAC/AWE. I will be forced to do a charge back eventually but have a good relationship with my shop so have been holding my breath.
    Apr 18 2016
    Bump. Got my refund!
    Just kidding
    Senior Member Three Rings protogeoff's Avatar
    Nov 12 2016
    Port Moody
    Serious question... Do all GIAC tunes eventually burn out the cats?
    V1Rotate
    Apr 18 2016
    Other GIAC users could chime in. With any product there's people that are fine, some who aren't. I will say I ran APR flawlessly for 7 months and 2 days after going GIAC. Fried
    Veteran Member Three Rings eightamrock's Avatar
    Jan 21 2016
    I have a 16 with the APR tune and this makes me nervous. 2 questions: 1. Why did you switch to GIAC? 2. How much was the cat replacement? I know it was warranty work, but curious how much it would have cost OOP.
    '19 Daytona Gray RS5 Sportback
    Options: B&O Sound, Dynamic, Navigation, Black Optic, RS Driver Assist, RS Stitching
    Mods: Suntek PPF wrap
    Apr 18 2016
    I honestly was just curious as a buddy had GIAC and it seemed to pull stronger up top. There was nothing wrong with the APR at all. I will say the GIAC felt torquier, for the one day it worked. And the replacement was about $1500 for ONE cat. I have to double check the paperwork.
    Also I ran APR on my vdubs back in the day. No issues
    Veteran Member Four Rings miztahsparklez's Avatar
    Dec 19 2010
    North CA
    That's definitely cats lol. I've blown 4.
    Aug 09 2015
    Sarasota, FL
    I've blown a set myself, but that was due to misfires and me running the car and not shutting it off when I should have.
    In reality, cats don't just blow like that within a few days, its a gradual thing, so anything that happened during a tune switch was par for the course. Glad you got it figured out and covered under warranty!
