Results 1 to 40 of 64
    Veteran Member Four Rings Lensch09's Avatar
    Feb 20 2004
    2022 B9 RS5 SB, 21 Rav4 Hybrid, some golf clubs
    Santa Clara, California
    Running a Flex-Fuel intank pump
    Low pressure fuel regulation code is popping up pretty frequently when I'm hard into the car. Car is also bleeding boost and occasionally hitting fuel cut. Looks to be time to replace the stock pump (failing since stage 2 @ 11k miles).
    Our in-tank low-pressure fuel pump/filter/sending unit on the B8.5 is listed as part number 8K0919051AJ. This fuel pump is used in basically everything (A4/S4/A5/S5/RS5). The fact that this is the same pump that is used in the 3.2L is less than impressive. Also used in the RS5...which seems strange.
    https://parts.audiusa.com/p/Audi__/E...0919051AJ.html
    It seems as though many of us that are Stage II plus are running into issues with the stock pump.
    Some B8.5 A4 2.0T cars support E85/flex-fuel. My assumption is that the pump used in these flex-supporting vehicles may flow more than the non-flex version (for more headroom) and may also contain internals that are more corrosive resistant to alcohol-based fuels. The flex-fuel supporting pump is 8K0919051AN ; 8K0919051AM. I believe that one forum member has already successfully swapped in this pump. Has there been anyone else?
    https://parts.audiusa.com/p/Audi_201...0919051AN.html
    Audi won't officially state that this pump works in the B8.5 S4, although I don't see why it wouldn't. Does anyone in the know have specifics on the differences between our stock pump and this E85 supporting pump?
    If this flows more, this could be a great OEM upgrade for us.
    -DL
    2022 RS5 Sportback - Navarra Blue
    Previously:
    2016 Audi S4 Prestige with tons of boltons -Build Thread - http://www.audizine.com/forum/showth...016-S4-Ordered!
    2007 Audi A4 S-line Ti APR GT2871R
    1999 Audi A4 Avant (S4 replica)
    2000 Audi S4 Sedan (Stage III)
    1999.5 Audi A4 1.8TQM Sport (bolt-ons)
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    There was another thread about this a few days ago. For the price of the oem pump you can just get an aftermarket pump that you know has a good flow rate.
    The b8 e85 pump is 8k0919051AN
    Edit, found the thread http://www.audizine.com/forum/showth...?highlight=e85
    There is also the dual pump option that GIAC is releasing, but you would need a good stock pump still.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Feb 20 2004
    Quote Originally Posted by infinkc View Post
    I don't think it works that way with the B8.5.
    The B8.5 does not have the standard run of the mill in-tank/inline fuel pump. It's overly complex for what it is.
    Almost makes me wish I had a B8 pump with a more conventional design.
    I do know that GIAC sells their "booster" pump, which could be an option. But the fact that my OEM pump is failing out on me doesn't give me a good feeling.
    -DL
    Previously:
    Feb 13 2004
    S Ã C, CÃ*
    Quote Originally Posted by Lensch09 View Post
    -DL
    found the info, look at my post above.
    Feb 20 2004
    Gotcha, thank you sir. Looks like I'm gonna buy the flex one, and if things still don't work (especially after the new GIAC file gets released), looks like I'll be buying a Walbro fuel pump as well.
    -DL
    Previously:
    Veteran Member Four Rings ntsantos's Avatar
    Dec 06 2015
    San Ramon, CA
    I've been interested in running this version pump as an oem e85 solution as well. I think this flex fuel specific pump may only be a piece of the puzzle. Most flex fuel cars, if not all, use a sensor in the fuel system to read the amount of ethanol in the system and adjust fueling from that data. Upon more research I stumbled upon this page (read the 5th paragraph down):
    http://www.greencarcongress.com/2009...-20090915.html
    Sent from my SAMSUNG-SM-N915A using Tapatalk
    Veteran Member Four Rings AudBoost's Avatar
    Apr 05 2005
    Tampa, FL
    Tomorrow my car is having an inline E85 pump installed. Very similar to what Loe and Mrmomo313 are running except the pump getting installed in my car will be a Walbro 450 versus a 250 like Loe's and Mrmomo313's.
    2016 S6
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    good luck today! Evan@crown motorsports will install it perfectly! Careful with having it hooked up right away to trigger 100% if its not boost based without a supporting file, the 255lph when running 100% (like a true in-line vs. boost base) is enough to induce "rich" misfires...
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Veteran Member Four Rings shadycrew31's Avatar
    May 27 2013
    West Chester, PA
    FYI, the intank just feeds fuel to the high pressure mechanical pump which is why the intank pump is used in multiple different cars, the intank pump is under something like 80PSI, the high pressure pump attached to the engine is closer to 1700 PSI.
    Now I am not saying your intank one is not failing or failed, I am just saying that upgrading it is 100% pointless and might even damage the high pressure pump if the upgraded pump increases the PSI going to the high pressure pump. .
    2010 S4, DSG, too many random parts. 2004 Mazda RX-8, was highly modified then went back to stock.
    Apr 05 2005
    Tampa, FL
    Quote Originally Posted by Loe View Post
    Evan is the man!
    We are going to setup to be boosted based until I can work with EPL on tuning.
    2016 S6
    Apr 05 2005
    Tampa, FL
    Quote Originally Posted by shadycrew31 View Post
    The last time I logged my STFTs I saw higher numbers that I would have liked which indicate that the LPFP is pushing hard to keep up. When I switched back to the 93 file STFTs looked much better. So I am confident my LPFP is working just fine it just needs a little help when running straight E85.
    2016 S6
    Feb 20 2004
    I'm not too worried. The in-tank pump is voltage variable, and is regulated by the low-pressure potentiometer located up in the HPFP. After a bit more research, the flex-fuel version in-tank pump is OEM Audi, and generates additional head-room on the low-pressure end. Less a few hardware changes, it functions EXACTLY like the stock non-flex pump. If the additional pressure isn't needed, the ECU won't "dial it up."
    This is significantly different than running a supplemental in-line that runs balls out 100% of the time. Given that our cars do not have return lines, the balls-out supplemental is not the best solution, in my opinion.
    -DL
    Previously:
    May 27 2013
    West Chester, PA
    -DL
    Yeah that was mainly what I was referring to, changing out the fuel pump for an aftermarket inline or in tank with twice the flow seems like a bad idea to me. I like your approach, looking forward to the results!
    Jun 21 2004
    mpls, mn
    FYI I logged Dozzer's car with 189mm dual pulley running e85, and the replacement oem flex fuel LPFP didn't appear to have any trouble keeping up, and his car isn't throwing any P310B codes anymore (with his stock LPFP pump, it was).
    Next person to install one should measure flow between the stock pump when they remove it and the flex fuel pump before they put it in. That would be pretty interesting.
    Apr 05 2005
    Tampa, FL
    Our cars do have a return fuel line. As Loe stated earlier the in-line pump is boost activated at around 8 to 10lbs so it is not 100% all the time.
    2016 S6
    Feb 20 2004
    Quote Originally Posted by AudBoost View Post
    If the B8.5 has a return line, it is not routed through the pump. I just looked at it last night.
    It must go directly back to the tank?
    -DL
    Previously:
    Veteran Member Three Rings jachien's Avatar
    Nov 12 2012
    Cerritos CA
    According to the self study program, there is a fuel return line. Although I haven't exactly seen the physical pump, I'm inclined to believe the return is built into the intank pump.
    2013 B8.5 S5 - Dual Pulley 189mm/57mm. EPL E85 Dual Pulley/DSG flash. Autotech HPFP. APR B8 Heat Exchanger. Injen Intake. Deleted Mufflers. 034 Street Motor Mounts. 034 Driveline Mount Inserts. KW HAS + H&R F:20mm/R:25mm wheel spacers. S6 Brake Conversion
    May 31 2016
    Mexico
    Quote Originally Posted by jprice View Post
    Do you or dozzer mind posting logs? I'm interested in going this route but wanted to see numbers before I make the jump. Thanks
    2016 Q5 3.0T GIAC Stage 2, HP tuners TCU tune with help from P3U and BG SQ5, aFe 11-10121 Pro Dry S filter, 034 Throttle body hose, AWE Cold Front Heat Exchanger
    93 octane tune (0-60mph 3.90 seconds (1 ft rollout), 0-60mph 4.12 seconds, 1/4 12.31 secs @ 112.40, 0-60ft 1.90 seconds)
    Race 104 octane tune (0-60mph 3.70 seconds (1 ft rollout) , 0-60mph 3.89 seconds, 1/4 12.09 secs @ 115.34, 0-60ft 1.88 seconds)
    Jun 21 2004
    mpls, mn
    Quote Originally Posted by Q5OnTheMove View Post
    What exactly are you looking for? He had low pressure from the lpfp, and now he doesn't with the replacement pump. He has a high fuel demand setup with e85 and dual pulley with 189mm crank pulley.
    The only thing that would be really nice is to flow test a stock b8.5 pump vs the flex fuel one.
    Sent from my Nexus 5 using Tapatalk
    Feb 20 2004
    I'm gonna try to get the logs on my stock pump tonight, pending time. My new Flex pump shows up tomorrow. Going to SF this weekend and work all week so there will be delay. Give me "two weeks."
    Previously:
    May 27 2013
    West Chester, PA
    There is no return line in the B8's, I had the entire system apart over the past few weeks. There is a low pressure feed line to the HPFP, on the HPFP there is a high pressure hard line going to two fuel rails, which do not have a return fitting or return line.
    The lines you are seeing in the diagram heading back to the fuel tank area are most likely going to the carbon canister which catches fuel vapors.
    Senior Member Three Rings Rex Wilkinson's Avatar
    Sep 18 2015
    2016 Audi Q5
    Sellersville Pennsylvania
    I just ordered a new OEM low pressure fuel pump w/e85. Hope to have it installed in a week or two
    '2016 S4|Metallic black|cf inlays|S-tronic|Sport Diff|35% Ceramic tint|GIAC Stage 2 w/DSG tune|Tampa ported SC|AMS Alfa|Velos Solo V|Michelin PS4S|Eurocode sway bars/end links|KW HAS|Alu Kreuz|ECS intake|O34 Trans/Rear Diff inserts|Black optics grille|Deval cf lip|CR-15|AWE Touring resonated exhaust|Enlaes cf diffuser|ECS cf mirror caps|P3|E codes
    Jul 26 2014
    Do you guys know what is the difference between B8 and B8,5 units?
    The flex-fuel pump seems to be available for B8,5 only, and non flex-fuel part number is different for B8 compared to B8,5 but I thought maybe B8,5 could still be fitted or at least the pump itself could be swapped from the B8,5 flex fuel unit.
    2011 S5 Sportback
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by -leman- View Post
    i believe Audi started making the 2.0T Flex Fuel in 2014 ? that would be the B8.5
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Apr 05 2005
    Tampa, FL
    No doubting what you are saying but if that is the case than what line is my Flex Fuel sensor plugged into that comes off the HPFP? It measures ethanol content correctly, as I have verified the measurements manually, so the line that it is plugged into is seeing fuel.
    2016 S6
    Veteran Member Four Rings LittleDozer's Avatar
    Jan 21 2014
    C5 RS6, D4 S8, 2016 XC60
    Minneapolis, Minnesota
    Yeah, any time I've taken apart either pump I can't see a return line.
    Jan 21 2014
    Sure it's not hooked up to the feed line going IN to the HPFP?
    May 27 2013
    West Chester, PA
    Facebook destroyed the image quality but I highlighted the HPFP lines, there is one hardline on the HPFP which goes under the Supercharger and splits into two hard lines connecting into two sealed fuel rails.
    Comign into the HPFP is a low pressure line from the LPFP, its a single line from the pump, there is another line in the engine bay that looks similar to the fuel line but its for the carbon canister.
    Feb 20 2004
    Just so everyone can see what we're talking about...
    Here is the hardware that I would recommend replacing with the pump ("nut", washer/gasket, base unit)
    Here is the new flex pump/filter assembly (for the B8.5)
    There is a second inlet/outlet that is "plugged" from the factory. This is normal. I also opted for the "cap" that you can see in the ETKA exploded diagram
    Said "plugged" inlet/outlet
    And the cap from Audi that I installed for piece of mind (don't want fuel in the back seat)
    Previously:
    Nov 12 2012
    Cerritos CA
    Considering there are no wires going to the 'top' unit, I think that should be the fuel filter and the 'lower' unit is the actual pump, where all the wires are going. Can you tell if those 2 metal bars holding the pump to the cap are solid bars or hollow? I mentioned earlier that the fuel return should be contained in the 'in-tank pump', so I'm assuming that the casting of the plastic top cap has galleys so the fuel return is integrated. I do believe since obd2 standard came into play, fuel return was removed from all cars, but the manufacturers, didnt necessarily remove it, but rather came up with more creative solutions for fuel return. For example, 350z/g35 fuel pumps have a fuel return, albeit integrated into the plastic, rather than the traditional fuel return with a second hardline tube going up and down the length of the car to the engine.
    Nov 12 2012
    Cerritos CA
    Thanks for the pictures by the way. There don't seem to be very many pictures on the internet of the actual pump. And just for clarification, this is the flex fuel version?
    Feb 20 2004
    Quote Originally Posted by jachien View Post
    The pump is 100% in the lower portion/lower sub-assembly. To be honest, the actual pump mechanism is housed in plastic and looks VERY similar to your standard Walbro/Bosch/etc. To me, it looks like a Bosch unit (probably an 040 or something similar is my guess). I'm thinking a person could easily retrofit a higher flowing unit into the lower sub-assembly housing, run some wires/connections and have a pretty seamless seamless upgrade. One would have to verify voltage/etc. But, it definitely looks doable, most likely with minimal trimming to the housing that contains the actual pump mechanism
    This is the flex fuel version (picture of the "AN" part number is in one of the pictures above).
    I will try to get some more pictures tonight while I'm installing the new pump. I was running on my way out the door to work this morning. I definitely think that an in-tank retro fit of a larger pump into the OEM housing is doable.
    Stay tuned.
    -DL
    Previously:
    Feb 20 2004
    Thinking about it again now, the 044 Bosch pump probably couldn't work as a retrofit in the sub-assembly (it's too large from what I remember).
    There are other pump manufactures that make higher volume units in a smaller package than the Bosch 044. I'm sure one of those would work just fine.
    More pictures later.
    -DL
    Previously:
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    I'm anxious to see the results of installing this pump to gauge if there are any improvements in flow. For this going DP I'm sure the extra headroom in fueling will be more than welcomed.
    Jun 21 2004
    mpls, mn
    Quote Originally Posted by RLB6 View Post
    It's already been done on a DP e85 car, and it took care of fueling issues.
    Sep 20 2006
    MD
    Sorry, ahven;t been keeping up....BUT, that is awesome to hear. Sounds like this took the air right out of the GIAC in-line pump solution (potentially)
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    Sep 18 2015
    2016 Audi Q5
    Quote Originally Posted by Rex Wilkinson View Post
    Update, new OEM low pressure fuel pump w/flex is in. It will be installed next Wednesday. Fingers crossed that it fixes the limp mode my car goes in shifting 3-4
    Jan 21 2014
    Yep, you're looking at him :)
    No issues yet
    Veteran Member Three Rings 13ttaz's Avatar
    Apr 29 2013
    Arizona
    Quote Originally Posted by LittleDozer View Post
    No issues yet
    LD, you might have indicated this previously, but you are also running the upgraded HPFP, correct?
    Sep 20 2006
    MD
    No issues yet
    Nice.
