Banja luka? brate moj
It's TDI, maybe vacuum pump has shit itself. Is there brake assist? I'm not sure if TDI has a sensor on brake vacuum but I'd think it would be likely.
The picture is with the car running, or just ignition on? if it is running, then the instruments are claiming two brake faults and battery not charging. maybe all is well, maybe the cluster is going crazy..?!
first symbol (O) is worn brake pads
second (!) is actual problem with brake, eg fluid too low, hydraulic pressure too low on audi with hydraulic booster (old 200, eg). Maybe low vacuum on cars with vacuum pump (I don't have TDI, not sure)
