Results 1 to 6 of 6
    Feb 24 2004
    Pittsburgh, PA
    Broken Fog Light
    So I was driving on the PA turnpike and something flew off a truck and I ended up hitting it, turns out it shattered the glass on my driver side fog light. Where is the best place to find a replacement light. I have looked around but these seem hard to track down
    Junior Member Two Rings pezdoctor's Avatar
    Nov 26 2015
    R.I.
    FYI---I was recently considering replacing my scratched fog glass---using the helpful info from this thread:
    http://www.audizine.com/forum/showth...w-for-about-30
    NOTE: This is the DIY / low-cost solution (if you are averse to the high full-part-replacement cost]
    Senior Member Two Rings M0ve0ver's Avatar
    Jul 18 2010
    Ft. Hood, Texas
    I had the same issue, and when I replaced the lens/housing I used Lamin-x to provide some more protection.
    there's got to be enough people parting out their cars that can sell you a used housing.
    05 B6 S4: JHM 93 Tune, Trex DP, JHM 2.5" CB, JHM LWCP, Apikol snub, Bilstein PSS9, 034 Adj Control Arms, 034 Rear Sway + Endlinks, 034 front Endlinks, Team Dynamics Pro Race 1.2's, 034 wheel studs, 034 Strut Bushings, 034 Lower Control Arms, tyrolsport caliper bushings, ECS braided brake lines, Hawk HPS pads, Evo skid plate
    13 8P A3 TDI: Malone Stage 3 Tune, CR170 turbo, Rawtek DP, Malone DSG tune, Darkside Race Pipe/EGR delete, CP3 fuel pump, Panzer skid plate
    Nov 30 2014
    Dallas, TX
    Quote Originally Posted by pezdoctor View Post
    I did this too! Chinese ones took some time to get here, the oven trick took some time but eventually managed to swap the glass. Used this to add extra protection:
    https://www.ecstuning.com/ES1867162/
    Best of luck with the fix!
    Feb 24 2004
    Pittsburgh, PA
    I am going to have to try this, thanks for the replies.
    Veteran Member Four Rings Silver Streakin's Avatar
    Mar 05 2004
    B8 S4, 17 Expedition EL, 2009 328ix coupe
    NoVA
    www.car-part.com for salvage yards.
    2011 S4, 6M, BB/panda, Sport diff, ADS, B&O | UniTronic stage 3 Dual Pulley | MercRacing HX | RocEuro intake | AWE Track & DPs resonated | H&R c/o w/Bilstein B8 rears| 19" VMR 710 & 19" Peelers | 034 trans insert | AK brace | CR15 bar | DEVAL CF Diffuser
    SOLD 2007 S4 DTM, Phantom Black Pearl, manual | JHM | FI | H&R | VMR | 034
    RIP 2001.5 A4 1.8TQMS, Silver/Ebony | APR stage 3 | STaSIS Tracksports | StopTechs
    SOLD 1995 90
