Results 1 to 17 of 17
    Veteran Member Three Rings B. Rock's Avatar
    Jul 27 2008
    09 3.0T A6 Avant
    A6 3.0T Tune MPG
    Anyone on here have a 3.0T with a tune and stock pulley? How did it effect your mpg? Yes, this is easily searched in the B8 S4 group but the driving style between the 2 groups is a bit different as are final drive ratios, aerodynamics, and vehicle weights. I'm also looking at the earlier 3.0Ts, not the later ones with valvelift. I'm not as concerned with HP/TQ gains as I am gas mileage - I've seen some motors do well with highway mileage on tunes as it leans it out a bit more, but it seemed tuner and platform dependent.
    Thanks folks.
    09 A6 Avant 3.0t
    06 E350 4x4 Cummins swapped
    01 WJ rock toy
    Veteran Member Four Rings 2010A6's Avatar
    Mar 10 2015
    2017 Jeep Cherokee; 2018 S3 Nano Gray
    Albany, NY
    Sub'd as I am interested too. And who did the tune? Looking mostly for the classic apr vs giac debate.
    Current: 2018 Audi S3 2.0T Nano Gray / Magma Red
    Past: 2010 Audi A6 3.0T Midmight Blue / Pistachio Beige
    Jul 27 2008
    09 3.0T A6 Avant
    There's others too...autospeed and malone come to mind as well. I may just have to bite the bullet and pick one and go, but it's worth asking first.
    09 A6 Avant 3.0t
    01 WJ rock toy
    Mar 10 2015
    Albany, NY
    Wasn't aware of those two yet. I'm only 2 years into my first Audi so everything is still on that learning curve
    Established Member Two Rings jstarr427's Avatar
    Dec 01 2013
    '05 BMW E46 330i ZHP, '91 3000GT VR4
    Newington, CT
    Dont forget Revo! they've got one for the 3.0T as well. when I go stage 1 I'm probably going Revo because I work for a Revo dealer.
    Veteran Member Four Rings denis silva's Avatar
    Apr 14 2009
    2007 passat,subaru outback
    san mateo
    Good subject!
    From what I heard it will mostly depend on the type driving style,if u nice and easy it will be only the normal gas consumption and if you WOT it will suck more gas!
    Mar 10 2015
    Albany, NY
    I don't think getting a tune that increases horsepower and torque produces a gentle driving style
    Veteran Member Three Rings KBRUCE23's Avatar
    Dec 15 2014
    B8 Q5/C6 A6 Avant/F-150
    MD
    Quote Originally Posted by 2010A6 View Post
    Haha yea I was gonna say, I have the GIAC tune, and AWE pulley and since they were installed, I generally have a hard time driving gently. That being said, I can't really say I've ever noticed a change in mpg though, good, bad, or otherwise.
    2017 S6 P+
    Mar 10 2015
    Albany, NY
    Quote Originally Posted by KBRUCE23 View Post
    What are you personally getting for power do you know?
    Dec 15 2014
    MD
    I'm not sure, I'm curious too! Unfortunately I've never been on a dyno or a track
    OP, Sorry for the thread detour. FYI it seems like most guys in here who do have a tune, have the GIAC tune, but I could be wrong
    2017 S6 P+
    Jul 27 2008
    09 3.0T A6 Avant
    Fair enough. I was just wondering if there was any benefit for sustained highway driving, which tends to be where tunes pick up extra efficiency by going a little leaner than stock. Might try out a chipwerke and see what that gets us before spending the $1200 on a tune.
    09 A6 Avant 3.0t
    01 WJ rock toy
    Jul 17 2011
    Sin City, USA
    A6 3.0T Tune MPG
    I have the stage II GIAC tune with AWE pulley. As stated above, having the tune makes your right foot a little heavier, but I will say that I have seen the best gas mileage when taking long freeway trips. Last time I drove from Sedona AZ to Las Vegas (approx 275 miles) I averaged 28mpg. That was running 80-85 mph with a couple of "passing" stints into triple digits.
    If you are conservative with the go peddle, you will experience an increase in mpg because the motor is running more efficiently.
    '09 C6.5 A6
    Veteran Member Four Rings ichi d's Avatar
    May 10 2013
    Toronto,ON
    i agree with this and im with apr on stage 2.
    C7 S6 / AWE Touring / -14mm / EuroTails /
    Apr 14 2009
    san mateo
    Quote Originally Posted by ichi d View Post
    So ichi d how do u like your stage 2 APR? Stage2 comes w pulley right?do u have jhm crank pulley also?
    Established Member Two Rings Bklynjay's Avatar
    Jul 10 2012
    Brooklyn, NY
    I got GIAC Stage 1. Cruising on highway i've been getting around 28.7mpg - 29.5mpg. Pretty damn happy about it with more power too.
    2010 A6.5 Quattro | G.I.A.C Stage I | Ibis white | Prestige Package | Side assist and cold weather package | 10% tint all around | Tinted tails | Debadged - only rear Audi Black rings | 7" TV headrest OEM bolt on with MMI | 2013 S4 19" Peelers | K6 Eyelids | Quad Rear Diffuser with Porsche 911 Exhaust Tips | Aluminum Pedals | DRL Fog LED Strip with on/off switch
    Jul 27 2008
    09 3.0T A6 Avant
    Great, that info is very helpful. As is the stage 2 getting the same as I'm getting stock now (27-28 hwy) - thanks folks.
    09 A6 Avant 3.0t
    01 WJ rock toy
    May 10 2013
    Toronto,ON
    Quote Originally Posted by denis silva View Post
    i started off at stage 1 and got bored of it real quick and upgraded to stage 2 6 months after when apr had their spring sale. i love it! the extra mid range power does wonders for this car. i believe i have the apr pulley kit or whichever one apr uses for their tune. now all i need is to get it dyno to see if the numbers that apr claim are accurate.
