Results 1 to 7 of 7
    Junior Member Two Rings
    Aug 08 2016
    Bloomfield Hills, MI
    Turn signal issues
    I'm having a problem with my turn signals where they work intermittently. Can the relay go bad, or should I pick up another stalk? Not really sure where to start with this. I'd rather not take it to a shop, because this seems like such a simple problem - I've just never had the turns go bad on this car, so I am not sure what could be wrong.
    Established Member Two Rings bwizard's Avatar
    Oct 10 2016
    Colorado Springs, Colorado
    Switch hazard and blinker flashers
    Sent from my S4's talk to text @ a buck thirty
    weekly driver 02 S4 2.7t auto stock
    Wife's 04 A4 1.8t auto stock
    Daughter's 97 A4 AEB Bored to 2.0t K04 sport cams
    My role family tech.
    Senior Member Two Rings 616_S4's Avatar
    Mar 07 2016
    2001 S4
    Grand Rapids Michigan
    Stops blinking on dash too?
    Veteran Member Four Rings MikeyB3's Avatar
    May 16 2008
    It's probably NOT the stalk. When the stalk shits the bed, it's usually the cruise control that doesnt work, but it's probably the turn signal relay (located behind hazard switch on dash next to cupholder and traction control button)
    Part# 8D0941509H01C
    Aug 08 2016
    It blinks irregularly on the dash, which matches what the actual signals outside are doing. Lately it's been worse. I guess I'll pop out that trim piece with the cupholder and check out the relay. I need to replace it and fix the cupholder anyway. This is as good a reason as any to fix it. Is there a simple schematic for testing the blinker? I'm guessing the relay is similar to VW relays with numbered prongs on it - guessing a Bosch relay of some sort?
    Aug 24 2014
    Newport Beach, CA
    It's 110% the turn signal relay, ask me how I know. The contacts on the turn signal relay inside that hazard switch module corrodes and makes for intermittent turn signals. I recommend just replacing it with ONLY an OEM Audi/VW turn signal relay, but you can try and scrape the contacts like in this DIY: (only worked a while for me then the issue came back so I just replaced mine)
    http://www.dailymotion.com/video/x31i1ne
    2024 M3 Comp xDrive
    Aug 08 2016
    You guys rock! I stopped by the local Audi dealer on my way home, picked up a hazard switch, and yep, that was it! Thanks guys. Now on to replace the hazard trim (broken before I pried it off, so it needed to be replaced anyway!).
