Results 1 to 6 of 6
    Senior Member Two Rings Phray's Avatar
    Oct 19 2014
    2011 S-Line A3
    Passenger Door Won't Lock
    Hello- been having some trouble getting my front passenger door to lock. Every other door works fine but this one just won't work sometimes. Won't lock with the keyfob, won't lock with the interior buttons, won't lock with a key in the door.
    Other times it's fine and I get the audible "beep" and I'm on my way.
    Any ideas?
    Sent from my SM-J700P using Tapatalk
    2009 A4 Avant Premium+ 2.0T Quattro
    | APR Stage 2 + R8 Coil Packs + Spullen HFC + AWE DP + AWE Touring Dual Exit (Black Tips) | Rebuilt Engine | Bilstein B12 Pro-Kit | VMR v701 19x9.5 | RS4 Grilles + RS4 Spoiler + Carbon Lip | Tint: 35% Sides + 20% Rear |
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    Quote Originally Posted by Phray View Post
    Any ideas?
    Common reason:
    http://www.audizine.com/forum/showth...ch-not-working
    You may find that Porsche part is cheaper!
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
    Oct 27 2009
    Miami, FL | Boone, NC
    Any ideas?
    Only the driver's side front door has a keyhole...
    So, I'm guessing the actuator is failing. I had one fail on my A4, and now another is failing. There are less than 40k miles on the car too.
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Oct 19 2014
    2011 S-Line A3
    Damn. Will replacing the door latch assembly as stated above fix that?
    Oct 21 2012
    Earth...
    Oct 19 2014
    2011 S-Line A3
    Quote Originally Posted by Gunnark100 View Post
    Thank you!
