Results 1 to 3 of 3
    Active Member Two Rings kaclaytor's Avatar
    Sep 02 2016
    1988 BMW 528e (soon to be 5.0 swapped)
    Ohio
    allroad air suspension question
    New to the allroad/audi community. I've done some research but haven't really found what I'm looking for. I've lowered my allroad a good bit 2/3" below original height at level 1. I have a few ideas on ways to go lower, but to do so I will need to be able to drive at level 3 without the speed restriction. So my question is does anybody know how to disable or bypass the speed senor to the air management unit. Thanks in advance.
    Veteran Member Four Rings PaperToast's Avatar
    Apr 29 2009
    Quadzilla
    Longmont, CO
    only experimental way ive heard of bypassing the lvl 3 drop was to disconnect the suspension module
    there is a limit on how low you can go before components start binding/wearing out faster
    Rockin' the Rockies
    '01 allroad, 250k woot woot, still boosting on original turbos and tippy, slightly modified. . .
    Scotty@Advanced, "Push it off a cliff, when it hits the ground you should have a few thousand horsepower available for a brief second."
    Established Member Two Rings CHRISTOPHÉ's Avatar
    Apr 01 2014
    2004 All lowww'd 2.5TDI 6mt
    Plymouth,UK
    I'm sure I read something in the handbook about it years ago. I'll have a look when I get 5 mins.
    EURO FACELIFT AVANT REAR TUB - SWAP FOR YOUR NARROW US SPEC ONE, PM ME
    WANTED FRONT PLATE RECESS INFILL
    A8 4.2 QS sold
    2004 Allroad 2.5tdi Manual
