Results 1 to 40 of 43
    Veteran Member Four Rings DBFL's Avatar
    Jan 01 2016
    2016 S4, 2018 Ford F-150, 2022 Audi SQ5, 1982 Audi Coupe
    Tampa Bay
    Lightweight 19" wheels
    Hi everyone,
    I'm in need of some help.
    I am looking to get a set of lightweight 19" wheels for track use. I know I saw a post a while back that had a 19" wheel that weighed just over 19lbs. I can't seem to find that post now. I have searched the wheel thread as well as the track drivers thread and nothing. I did a search of the S4 forum and couldn't find it. I'll be using these wheels as dedicated track wheels. I'm looking for a 19x8.5 et35-38 (I need to clean a BBK setup but avoid rubbing the fenders).
    Any help would be greatly appreciated.
    Thanks in advance.
    -Daniel
    Edit: I would also like the wheels to be hubcentric. I don't want to have to mess around with hub rings while at the track.
    2016 S4 P+ | 6MT | Sports Diff. | Tech. Package
    S4 Build Thread
    Veteran Member Four Rings stereojorge's Avatar
    Oct 15 2013
    2014 Audi S4 P+ DSG, 2015 Audi SQ5 Prestige
    Tampa, Florida
    TSW Nurburgring's will fit that exact need sir!
    '14 Misano Red S4/APR Stage II+ DP ECU+TCU & UC/187mm Crank & AWE 57.55mm SC Pulleys/CMD Charge Chamber Intake/KW V1 Coilovers/EuroCode Sway Bars & AluKreuz/CR-15/034 Trans Mount/Apikol Rear Diff Mount/ECS Rear Diff Carrier Mounts/CMD Test Pipes/AWE Reso.Downpipes/AWE Track Exhaust 102mm Tips/Vossen HF-3 19" x 9.5"/Michelin PS4S'/StopTech Drilled Rotors/Akebono Euro Ceramic Pads/StopTech SS Lines
    Also: 2015 SQ5 Prestige | 2003 A4 Avant Quattro 6MT
    Previous: 2010 S4 P+ | 2008 A4 S-Line
    Nov 12 2015
    Here
    I think the TSWs are actually > 21lbs.
    But OP on a car that weighs 2 tons, I wouldn't sweat a couple of pounds, rotating or not.
    Mein ist grau
    Jan 01 2016
    Tampa Bay
    Thanks. I'll look into those.
    If anyone has other wheels they can recommend that would be great. I'd like to have a few different options to choose from.
    S4 Build Thread
    Veteran Member Four Rings AudBoost's Avatar
    Apr 05 2005
    Tampa, FL
    There is a good list of flow forged wheels on the market which should fit your requirements.
    Renn motorsports
    Vorsteiner
    HRE
    TSW
    Avan Garde
    Enkei
    Rohana
    Veteran Member Three Rings Jv218's Avatar
    Jun 10 2015
    15 S4, 2012 civic
    Boston
    My hre ff01 came in at 22lb I believe
    15 Ibis white, Dsg, P+, magma interior, F1 35% pinnacle tint, ECS RS4 grill, AWE Track 90mm tip, 19x9.5inch HRE FF01, ECS Carbon Intake
    Account Terminated Four Rings Pyromatic177's Avatar
    Aug 02 2015
    Corning NY
    I believe it's the Renn Motorsports wheels that are 19lbs
    Edit: they're actually 20lbs a piece
    http://www.audizine.com/forum/showth...highlight=Renn
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    VMR 803 in your specs is 21.8lbs
    I have them but in 19 x 9.5 really like them because I wanted some dish to the wheel.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Veteran Member Four Rings B18b1ex's Avatar
    Jul 02 2004
    FL
    Forgestar maybe.
    Jan 01 2016
    Tampa Bay
    Quote Originally Posted by Pyromatic177 View Post
    I saw that thread. I'm waiting for a response from the vendor as to price and availability.
    S4 Build Thread
    Jan 01 2016
    Tampa Bay
    Quote Originally Posted by AudBoost View Post
    Renn motorsports
    Vorsteiner
    HRE
    TSW
    Avan Garde
    Enkei
    Rohana
    Unfortunately these brands don't list weights on their websites. HRE is probably going to be more than I want to spend. The Avant Gardes that I have now are 29lbs apiece and I think their flow formed wheels are around 23lbs.
    I'm hoping that someone here has a set of wheels that they use and know for sure that they are 20lbs or less. This way I know where to start. I don't want to contact a bunch of vendors and waste their time if they don't carry what I want.
    S4 Build Thread
    Mar 21 2015
    Quote Originally Posted by DBFL View Post
    It would be a waste of your time not thiers, they will answer any question to get a sale.
    Jan 01 2016
    Tampa Bay
    Well, hopefully a few will see my post and chime in here. That would save me a lot of time PMing everyone.
    S4 Build Thread
    Apr 14 2016
    Austin Texas
    Bathurst
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    Veteran Member Four Rings mrmomo313's Avatar
    Oct 27 2010
    Audi RS3, Redeye Hellcat
    Michigan
    Maybe look at the renn rs51. 19 inch and around 20lb each. priced well. Have had them for 2 years now. Great wheels. They were 21lb on the scale I used in 19x9.5 et35
    Jan 01 2016
    Tampa Bay
    Quote Originally Posted by mrmomo313 View Post
    Thanks. It looks like it's going to be between the RS51s and a set of TSWs. I just need to get a price one the TSWs.
    S4 Build Thread
    Jan 26 2015
    2017 XC90, a workbench
    CO
    Vmr v710ff are pretty light especially for the price
    2018 S6 - stock for now
    2014 S6 - Stage 3 - Gone
    2013 S4 - Dual Pulley e85 - Gone
    Feb 01 2008
    How is the fitment with 19x9.5 et 35? Do you get rubbing? What size tire?
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    Forgestar is what I went with. 19.5 per wheel in 19x9.5 fitment
    Oct 27 2010
    Michigan
    Quote Originally Posted by 2000S4 View Post
    I rub in the rear on the fender liner when I hit big bumps in the road. I also have my car pretty low on the coilovers so that probably doesn't help lol. 255/35 tire. But I like the way it looks with et35 as it sits pretty flush to the arches.
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    Which front lip do you have? I like.
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Oct 27 2010
    Michigan
    Quote Originally Posted by DannyDeez View Post
    It's this one. The finish hasn't scratched at all after 2 years of having it. I drove it a bit in the winter as well. Very happy with it
    http://www.jl-motoring.com/Audi_B8_A...p/aufsb803.htm
    Sep 11 2004
    16 Q5
    Westchester, NY
    Cool thanks!
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Have you looked at Konigs Flow Formed wheels? They are made with DST (enkei's technology), hub-centric, light, and inexpensive. I got a set of Rennforms for the track, 19x9.5 et 45, 20.8 lbs, can be had for ~$225/each, i love them.
    http://konigwheels.com/wheels/flow-f...eels/rennform/
    Stage 1 more than you RS3
    Jan 01 2016
    Tampa Bay
    Quote Originally Posted by o1turbo30v View Post
    I hadn't, but I will now. Thanks.
    S4 Build Thread
    Veteran Member Four Rings KRp220's Avatar
    Aug 23 2011
    NH
    all of the wheels i've had have been flow formed in attempt to keep the wight as close to 20# as i can, so i've done a fair amount of research and have owned a few sets of wheels that might suit your needs.
    correct on AG's FF's weighing in around 23#. I have a set in 19x8.5 and thats what they weigh. nice wheels though!
    i had a set of vorsteiner vff 103's sent to me (instead of the vff 102's) and they weighed 21.X in 20x10, so a 19" setup should be 20# or less
    the TSW Bathurst and Interlagos should both be very close to <20 in a 8.5" width, same with VMR's 803's. the 9.5" - 803's i had were around 23#
    hope that helps
    2013 S4 // ESTORIL BLUE // 6MT// RS BUMPER // GIAC STG 2 // FORGE CC // AWE+SCORPION // ECS INTAKE // BILSTEIN+H&R // VOSSEN VFS5 // PSS 265/30/20 // AK // 034 MOUNTS // SB STAGE 3 CLUTCH // CR 15
    + ECS Diffuser, BFI shift knob, tints, sports diff, j-codes, Akebono pads, SS clutch line, Ceramic Pro...
    GONE 2010 S4 // QUARTZ GREY // 6MT // GIAC STG2 // AWE TRACK // ROC EURO // 034 TRANS MOUNT // H&R OE's // AG M610 FF 19x8.5 // + random stuff
    Veteran Member Four Rings FulhamFTW's Avatar
    Jul 11 2010
    STL, MO
    Do you have pics of them on the car? These look a like a great option.
    Jan 01 2016
    Tampa Bay
    Quote Originally Posted by KRp220 View Post
    hope that helps
    Thank you. This is very helpful. It's exactly the kind of feedback I was looking for.
    I'd like to support an Audizine vendor, so now I just need to figure out who sells what brands.
    S4 Build Thread
    Feb 06 2012
    Allentown, PA
    Quote Originally Posted by FulhamFTW View Post
    Quick crappy picture from when i was putting them on:
    Aug 23 2011
    NH
    glad that helped
    Jason @ Get your wheels is always active on the forum and has always been pleasant to deal with when i've inquired
    James @ https://www.wheellab.us/ is an AZ member who i have bought a couple sets from
    Jul 11 2010
    STL, MO
    Sweet Jesus, those look fantastic! Thanks! I just made my wheel choice. Where did you get them?
    Feb 06 2012
    Allentown, PA
    Wait until you see them in person, so awesome. I special ordered them from discount tire direct, i saw them cheaper on Ebay so discount tire matched the price. I got them about a week and a half after i ordered them.
    Veteran Member Four Rings Thurston's Avatar
    Apr 27 2015
    canada
    Quote Originally Posted by chet.rowles View Post
    Bathurst
    yep yep . . . any idea what the weight is of the 19's and 20's?
    Nov 12 2015
    Here
    If you can go 19x9 ET40, the Neuspeed RSe102 is right around 20lbs and has the proper bore. Also takes OEM center caps!
    Mein ist grau
    Jan 01 2016
    Tampa Bay
    Quote Originally Posted by SportVier View Post
    Thanks, but I want to stick with an 8.5" wide wheel. I don't think I can get away with anything larger than a 255 tire, so a wider wheel will only add more weight.
    S4 Build Thread
    Established Member Two Rings spy963's Avatar
    Jul 30 2014
    B8.5 S4 & 997.2 Turbo S
    Montreal
    Fast Wheels FC04 : 19x9.5 : 20,2lbs
    1100$ for a set.
    2013 Monsoon Grey /S4 : 6MT : Unitronic Stage 2++ : 58.3mm/186mm : PLM Heat Exchanger : Sachs XTend Clutch kit : Eurocode TRUfit Intake System : Bilstein B8 Shocks / H&R OE Sport Springs : Custom X-Pipe w/ AWE 102mm Exhaust tips : 034 Transmission Mount : CR-15 Strut Tower Brace : AG black M510 19x9.5 : ECS CF Decklid Spoiler : CF Mirrors
    Nov 12 2015
    Here
    Well, if you really want to save weight then you should think about going down to 18s!
    Looks like the Bathurst comes in just over 20lbs in 19x8.5.
    Mein ist grau
    Jan 01 2016
    Tampa Bay
    I'm going to be buying either an Alcon or AP Racing BBK at the same time. They are both 370mm rotors with 6 piston calipers. It doesn't look like an 18" wheel will clear either of those setups.
    S4 Build Thread
    Nov 12 2015
    Here
    Definitely worth confirming if you are a real "weight weenie". You could save some $ too.
    Mein ist grau
    Active Member Two Rings s4ved's Avatar
    Oct 17 2016
    2013 SL63 AMG, 2016 Range Rover Autobiography, 2011 G55 AMG, 2010 X5, 2008 rs4, glk 350
    Iowa
    I have been running the TSW Bathurst for a few months now and love them. Great looking durable light weight wheel! Or go with the Rohana rf1's put them on my sl63 and not disappointed!
