Results 1 to 12 of 12
    Mar 01 2012
    Brisbane Australia
    Adding memory seat function to B8.5 A4 with elect seats
    Hi All,
    I just purchased a 2013 A4 facelift with elect seats but no memory function (no buttons).
    Is there anyone here that knows a list of parts required to undertake a retrofit.
    I don't think I have a module under the drivers seat and the interior is leather / alcantara and can has convenience keys.
    I don't mind if I can set it up so that each key 'remembers' last position so that I don't need to add buttons.
    Thanks
    Lemi
    Jun 04 2016
    A
    Quote Originally Posted by lemi View Post
    Hi All,
    Thanks
    Lemi
    I assume that would be a pretty expensive mod.
    perhaps ask your local AUDI dealer?
    I bought my used car specifically due to it having that option/function.
    even though I have it, im kinda interested to know as I have wondered if I ever upgrade to better seats.. (S4 or even S-Line) seats whats involved.
    Veteran Member Four Rings kwbdc's Avatar
    Mar 29 2012
    2006 Mazdaspeed6 RIP
    Seattle/WA/United States
    You would need the modules under each seat and the switches in the door cards but the wiring necessary might be part of the canbus which would be more difficult
    2012 Audi A4 Premium +MT, Quattro, Xpel bra, SLine BBS CI-R 20x8.5 ET 32
    Mods: APR HFC/DP, APR K04, Bilstein PSS10 Coilovers, Okada Coilpacks, AWE Boost Gauge, Eurocode SSK, OSIR CF Spoiler, APR Carbonio Intake, AWE Exhaust, OSIR CF valence, ÜSS Adjustable Stabilizer set, Alu Kreuz, RS4 grille, Fluidampr,Apikol differential, folding mirrors,Brembo GT BBK, Deval CF splitter,ECS skid plate, RS4 rear brakes, Snow performance Stage3
    Mar 01 2012
    Brisbane Australia
    I would be happy just to do drivers seat.
    I did see that it has been done to A5 and I am wondering if parts (apart from the buttons) are the same.
    I guess I will contact audi themselves.
    Cheers
    Veteran Member Three Rings B8_Dude97's Avatar
    Sep 05 2016
    Antioch, California
    Cheers
    Audi probably will be of little help.
    This retrofit is very doable and don't let anyone discourage you if you really want it.
    This is a planned retrofit for me when I retrofit the 3 zone hvac into my 09 b8
    There's a pdf online somewhere that is pretty detailed about doing this on a b8
    But for sure you will need this part no:
    8K0 959 760
    That's the seat module
    You will then need door modules with the cutouts
    Oh and this is the part number for the bracket for the control module above
    8T0 959 729
    Once u have those plus the memory switch ur next hurdle is cabling
    U have a few options.
    You can either make the cabling yourself or strip another b8 for its wiring loom or contact kufdatec to see for they will make you one
    But this retrofit is 100% doable
    Oh and you'll need vagcom and the right coding to adapt it all
    Mar 01 2012
    Brisbane Australia
    Thanks for info :) I really appreciate it.
    I have a friend who used to work at VW and is now at Porsche so he will be doing the coding with vagcom. Its just that he has never done memory seats.
    Where else can I get info about what cables I need or is there any thread about someone having it done.
    Cheers
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    If you cant find this pdf online, shoot me pm!
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
    Sep 05 2016
    Antioch, California
    Cheers
    Quote Originally Posted by Gunnark100 View Post
    Took me a min as I had dug into this way before purchasing my Audi and saved the link
    This was written by Danikas
    http://flataudi.webs.com/downloads/P...20FUNCTION.pdf
    He also has a thread on Audi forums that covers some questions
    Sep 05 2016
    Antioch, California
    Cheers
    In the thread it's stated there's 3 cables
    8T0971 366 F
    8T0971 369 N
    8T0 971366 AL
    However these wiring looms are pretty pricey so unless u got some change laying around I'd use the schematics in the pdf along with etka diagrams to find the wires and rip them out of a donor car or contact kufdatec
    Oct 21 2012
    Earth...
    Quote Originally Posted by B8_Dude97 View Post
    Mar 01 2012
    Brisbane Australia
    Bingo!
    Thank you so much.
    Really looking forward to this. I will add info as i go along.
    Cheers
    Sent from my SM-G935F using Tapatalk
    Sep 05 2016
    Antioch, California
    Good luck in ur fit. Report back so others can prosper. I plan to retrofit 3 zone climate into my 1zonw and same time I'll be doing this too so in a few months I'll do a diy from scratch
