Results 1 to 7 of 7
    Apr 03 2016
    Folsom CA
    2003 RS6 valve cover gasket replacement
    Greetings to all. Does anyone know the cost/time to replace valve cover gaskets on a 03 RS6 ?
    Any and all help appreciated. Be safe.
    Senior Member Two Rings mr_dave's Avatar
    Apr 20 2013
    C5 RS6
    MN
    Cost of parts to DIY? <$100 http://www.blauparts.com/proddetail....od=GF21011%2DG
    Probably takes around 3-4hrs for the RS6.
    Veteran Member Three Rings carmudgeon's Avatar
    Oct 23 2012
    1995.5 S6 Avant
    Kansas City
    The gaskets can be a PITA to clean up. The gasket material tends to become rock hard with age and if you're too aggressive trying to remove it you'll damage the soft magnesium alloy that's used for the valve cover. Look through some of the threads for tips on how best to clean/remove them.
    Previous vehicles: 2012 TTS Roadster - 2017 Golf R - 2002 S6 Avant - 2013 S4 - 2008 Subaru STi - 2007 Mazdaspeed3
    Veteran Member Four Rings Kruat's Avatar
    Nov 10 2004
    01 S4, 03 RS6, 15 A8L, 16 PSD F350
    Longview, WA
    Pull motor.
    J/k....it can be done in car. Dealerships will tell you motor has to be pulled, according to Audi. Its not a bad job, just time consuming.
    --Mike--
    01 Casa S4
    03 Mugello RS6
    15 Moonlight A8L TDI
    01 Aviator TT (sold)
    99.5 Santorin A4 (sold)
    04 Cobalt Allroad (sold)
    Apr 03 2016
    Folsom CA
    Thank U to all who replied !!!
    Established Member Two Rings Bigglezworth's Avatar
    Jul 16 2012
    Pair of '03 RS6 Saloons, '02 S6 Avant, '91 NSX, & '87 GNX
    Calgary,AB
    Quote Originally Posted by 2013 rick View Post
    1.0-1.5hrs for drivers side and 2.0-2.5 for passenger side. Time for each includes removal of all coils, wiring, hoses/pipes, cleaning /degreasing, and general shop clean-up. Passenger side is hindered by a fuel line and a coolant pipe that make removal more difficult. Audi states you need to pull the motor so that you can remove the coolant pipe which snakes up over the front side of the cover, but it has been proven by many over the years that you can simply remove the front fastener and "flex" the coolant pipe out of the way.
    02 S6 Avant w/ no stuff - Pokey
    03 RS6 Saloon w/ stuff - quick
    03 RS6 Saloon w/ MORE stuff - super quick
    91 NSX CDN issue w/ 6spd & BBSC - quicker yet
    87 Buick OEM GNX clone w/ LOTS of go fast goodies- quickest
    Veteran Member Three Rings nistah's Avatar
    Jan 20 2014
    2004 AUDI C5 RS6
    Washington DC
    Anyone can point me in the direction of a shop in Florida that can do the 4 hour version of VCG replacement as described by bigglezeworth above🫢 thanks!
