Results 1 to 4 of 4
Thread: Overheating?
    Sep 29 2016
    Kansas City, Missouri
    Overheating?
    So I just picked up a 2.7t C5 allroad and the car has some strange cooling/temperature issues. First of all the gauge when you start the car already is almost at half way, Even from a cold start. So, you can proceed to drive the car and it will increase past the usual halfway on the gauge. Have never driven it for very long. The radiator feels boiling hot but the engine itself still feels cold during quick drives. The fan also never turns on unless manually done so from the HVAC cobtrols. Another thing to maybe note is the floor on the drivers side is sometimes wet, but there never appears to be any coolant missing from the reservoir.
    So, what is most likely my issue/issues? Bad gauge? Kinked/blocked hose? Bad sensor? Heater core issues?
    Veteran Member Three Rings carmudgeon's Avatar
    Oct 23 2012
    1995.5 S6 Avant
    Kansas City
    If the gauge is already reading warm on a cold start its probably a bad sensor. It's a cheap and easy "might as well try it" fix. Being a 15-20 year old German car don't discount the possibility you have more than one issue.
    Previous vehicles: 2012 TTS Roadster - 2017 Golf R - 2002 S6 Avant - 2013 S4 - 2008 Subaru STi - 2007 Mazdaspeed3
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Sep 29 2016
    This would not explain no heat in the car and the motor staying cool though. I will agree that there may be multiple issues and the senor could be why the car
    Gauge is off. The other issues?
