Results 1 to 35 of 35
    Jan 30 2015
    2012 A6 3.0T Prestige + others
    Irvine/CA
    A6/S6 suspension "Lowered" information thread
    Just wanted to start the thread talking only about the setup and gather information for all memebers looking to lowered their car in the future, hopefully this will help, as I was looking for this information before i lower mine, but couldn't find a clear information.
    Please provide the followings and 2~3 images of side view and floor to fender measurement.
    Wheel Spec: 20x9.5 ET29
    Tire Size: 255/35/20
    Suspension setup: KW V1
    Floor to center of fender measurement: ~26.25 inch on all 4 wheels.
    Comments: Driver side wheel rubs when doing right turn (without using break, say >25mph).
    Front wheel
    Rear wheel
    - Michael
    2012 A6 3.0T Prestige:
    GIAC Dual Pulley 57.1+187 / Merc HX / Injen Intake / OEM muffler mod (Quad Tips + X-Pipe) / Eurocode drivetrain inserts / 034 Swaybar / Volk wheels / Bilstein+Eibach / RS front grill / Deval Carbon rear diffuser / Maxton Front Spoiler and Side Skirt add on / Carbon trunk spoiler / Carbon mirror / Stoptech rotors.
    Active Member Two Rings irmd's Avatar
    Aug 23 2013
    09' Audi Q7 3.6
    United States
    Hey, I'm looking to lowering my 13' A6 2.0 Quattro. How do you like the ride? Did you look at any other setups prior to picking up the KW V1's?
    I'm looking for a setup that gives me the priority of Comfort first and then Handling / Looks second and third. I know the stock suspension will give me the comfort suspension I'm looking for but I would like the best of both worlds, so please don't troll me :). I'm currently riding on the stock 20" from Audi with summer tires but I also have 18x8 TSW that I'm about to slap on because they have all-season tires for the northeast winters.
    -Pat
    13' A6 2.0 Premium Plus Quattro daily driver with APR Stage 1 ECU 93 upgrade
    09' Q7 3.6 Premium Plus Quattro family car
    Feb 25 2014
    Texas
    This is a great thread, wish there were more responses!
    Mickey (AKA: AudiS4B8)
    Instagram: ze_nardo6
    10.65 @ 129mph
    Veteran Member Three Rings Dguth's Avatar
    Dec 14 2011
    Dublin, OH
    Anybody else post your measuring height when lowered and in dynamic mode. So far I see 26.2 above on 255 tires. I just measured mine outside which were originally dialed into 265 tires and its higher at 27.2 to 27.5. I'm going back to get my height alignment on my winter wheels wheels which are back to 255 tires. Would like to see other measurements for S6s.
    2014 S6 | Glacier White | Prestige Package | B&O Sound | Tinted & Lowered | APR Stage 1.1 Tune | APR TCU Tune | XPEL Front | Flat Bottom Steering Wheel | Soon to be installed: RS7 Turbo, RS7 Intake, AMS Coolant Upgrade, AMS High Flow Downpipes, RS6 Grill and APR Stage 3 Tune
    Veteran Member Three Rings Bassler's Avatar
    Apr 17 2016
    '14 S6, '18 XC90, '19 Raptor
    North Shore, MA
    I'll get mine when it's not raining cats and dogs. Lowered 15mm via vcds. Will go lower with either links (which I have) or the cete module this spring with new wheels/tires
    Sent from my SM-G930V using Tapatalk
    2014 S6 Prestige DD/Kid Hauler | Glacier White, Lunar Silver & Aluminum/Black Wood | Black Optic | DA / Innovation / B&O
    APR DPs | Milltek resonated Valvesonic | EPL Stage 2 ECU/TCU | RocEuro | Forgeline 21s | Eurocode sways/links/AK/inserts | RS6 grill | Deval diffuser | XPEL/Opti/35% Llumar
    Jan 30 2015
    Irvine/CA
    I was told that KW is the closest to stock sports suspension (comfort level wise)
    My observation is when road condition is smooth, this is indeed very true, but if road condition is not as great you can feel every bump.
    That being said, I drive mostly local (like 90%) so I like the setup, but if I were to drive 90% on highway, I would think twice.
    Are you on stock sports or non sports?
    Is your main concern to lower it or just to get rid of the wheel to fender gap?
    Quote Originally Posted by pherbolario View Post
    - Michael
    Aug 23 2013
    09' Audi Q7 3.6
    United States
    Quote Originally Posted by yeuchau View Post
    Hey, thanks for the response. I'm not sure if I have sport suspension, is there a way to determine if I have the sport package? I picked up the car as a CPO and don't recall it mentioning "sport package" other than 20" wheels. Comfort is high on the list but I want to bridge the wheel/fender gap than lowering the car (to the floor).
    -Pat
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    I'm running my winter setup right now..
    Wheel Spec: 19x7.5 ET33
    Tire Size: 235/45/19
    Suspension setup: S6 air suspension with 10mm VCDS lowering
    Floor to center of fender measurement: ~27.25" front ~27.5" rear
    I didn't really want it dropped too much...looks perfect to me in summer with 20x9 ET35 255/35/20 but looks a bit like it's wearing a dress in the winter since the wheels are so deep set. Fine by me though keeps all the snow/salt mostly in the wheelwell.
    Also FWIW the winter tire diameter is about 0.4" taller than summer so that drops it down a bit in summer.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Jan 30 2015
    Irvine/CA
    if you just want to get rid of wheel/fender gap, you can always get bigger tire, it will minimize it slightly, obviously it's won't get rid of all the gap completely.
    also, if you have paddle shift, then you have sports package.
    - Michael
    Aug 23 2013
    09' Audi Q7 3.6
    United States
    thanks for the info on paddle shift, i definitely do not have the sports package then.
    appreciate the tip on the bigger tires but i'm not looking to go that route as it will also lift up my car as well which i'll probably hate even more :)
    -Pat
    Jan 30 2015
    Irvine/CA
    I found this pic, this is probably the smallest gap you can get without lowering, I was running 295/30/20 tire setup vs 255/35/20 lowered on KW.
    - Michael
    Aug 23 2013
    09' Audi Q7 3.6
    United States
    that's sick, it looks so aggressive! i do like your KW setup better though. appreciate the feedback and ideas.
    -Pat
    Jan 30 2015
    Irvine/CA
    Bump it up, hopefully more people who lowered their 6 will respond.
    - Michael
    Jan 30 2015
    Irvine/CA
    Current setup OEM S8 rotors. 21x9 et35.
    Sent from my ASUS_Z017DA using Audizine mobile app
    - Michael
    Sep 01 2016
    Sacramento, Ca
    Sounds like the Bilstein b12 pro kit is the best lowering option from reading around, what I don’t know is how it compares to sport suspension. I have standard suspenion, but I came from an a4 with sport suspension and I thought it was a great ride! Waaay better than my previous Gti.
    Jan 30 2015
    Irvine/CA
    I know a lot folks have lowered their A/S 6, whether it's Air, Coilover or just lowering springs, please post picture of your setup and tire/wire spec if possible.
    - Michael
    Sep 28 2009
    suburb
    if you rub a little, look under the fender and you will see a screw towards the rear of both front fenders. unscrew that screw (it's a torx 25) and you will have more lowering leeway. my s7 has this. prob s6 too
    Audi S7 stage 3 w/srm turbos
    Audi B8 S5 stage 3 w/apr supercharger
    Audi SQ7
    Audi Q5 3.0 EPL stage 2 single pulley (gone)
    Audi Allroad 2.7 stage 3 (gone)
    Audi B5 S4 stage 3 (regrettably gone)
    Audi B8 S5 (gone)
    Established Member Two Rings i8snitches's Avatar
    Mar 03 2018
    2018%20Audi%20S5
    GA
    Looking to lower my 2014 A6 with sport suspension currently at 70k. Leaning towards Kw V1. My question What impact does this have on switch between Dynamic/Comfort settings?
    I travel 100-miles round-trip each day most of which is highway so comfort mode comes into play when bone tired and looking to just cruise.
    2014 A6 3.0T
    MODs: APR Ultracharger & DP (57.75mm/187mm) | Roceuro CAI for APR Ultracharger| AWE Touring Exhaust with resonated downpipe | APR CPS | Eurocode Test Pipe | Bilstein B8 Strut | H&R Sport Springs | 036 Control Arm Kit | Eurocode Sway Bar Kit and Endlinks | Jokerz Ported Blower
    UPCOMING: Custom TCU tune
    Veteran Member Three Rings R3.'s Avatar
    Nov 03 2016
    Dallas,TX
    Sold this one Bilstein PSS10s no rub, no issues, nice ride.
    Current S6 OBD11 lowered 12mm.
    2016 S6
    2013 A6 3.0T Sold
    Established Member Two Rings BB c7's Avatar
    Jan 23 2016
    Chicago
    A6/S6 suspension "Lowered" setup thread
    C7 a6 lowered with H&R spring came from oem sport spring.
    20x9 et35 wrapped with 275/35/20.
    I didn’t have issues with oem sport suspension. Now that i have H&R springs it rubs in the front hard turns. Also rubs in the back if had 3 people in the back seats on hard bumps.
    Yes u will loose ride comfort on h&r. I feel the bumps even more now. But it looks much better than before. IMG_3210.JPGIMG_3206.JPGIMG_2996.JPG
    So i guess i will have to go with 255 tires.
    For that reason i am selling my tires it is Michelin pilot sport a/s3 plus. 275/35/20. 9/32 tread left it is almost new. If anyone interested let me know.
    I can also sell the whole set up if anyone interested.
    Oct 31 2005
    Ashburn
    For aggressive Setups or setups in general it would be a good thing to add Wheel Alignment specs, I'll add mine in later.
    HRE FF04 in Matte Midnight Blue (These wheels are not recommended fitment from HRE due to how aggressive they are) but fitment is spot on once dialed in.
    Wheel Spec: 20x9 ET25
    Suspension setup: Stock Air Ride Suspension, VCDS 17mm drop, Airmatic Lowering Links
    Floor to center of fender measurement: 26.5 inch on all 4 wheels in Dynamic mode. Haven't measure in Comfort mode.
    - Instagram: @Sinister_rs5-
    Sep 01 2016
    Sacramento, Ca
    Wheel Spec: 19” factory
    Tire Size: 255/40/19
    Suspension setup: Eibach pro kit
    Floor to center of fender measurement: 27 3/8”
    1.2” lower front, 1” lower rear from non sport.
    Comments: No regrets and no drawbacks really, car is great on highway but handles very well. Front camber is stuck at -1deg according to Les Schwab.
    Oct 20 2016
    Los Angeles/CA
    BBS CI-R 20x9 et25
    Michelin PS4s 255/35/20
    Lowered 12mm via VCDS
    Working through black optics conversion with front grill on order
    2022 RS6 Daytona Gray
    Jan 22 2017
    New York
    Quote Originally Posted by snohman View Post
    BBS CI-R 20x9 et25
    Looking good!
    Oct 20 2016
    Los Angeles/CA
    Jan 30 2015
    Irvine/CA
    Quote Originally Posted by jrp916 View Post
    Did the springs ever settle and drop a bit lower?
    Only asking because the gap on yours appears to be bigger than mine.
    - Michael
    Established Member Two Rings quillonvu's Avatar
    Feb 22 2011
    Las Vegas/Nevada
    is there a reason to have your setup lowered on both lowering links AND VCDS? is there a negative to lower it using just via lowering links OR VCDS?
    Aug 17 2015
    2003 G35, 2016 Ford Explorer, 2012 F150
    Belle Plaine, MN
    I have a 2014 Audi TDI on Lowering springs for about 85K miles. The car currently has 120k on it. It has come time to replace some control arms and struts. I would like to know if I can get lower with the H&R ultra-low coilovers or any coilovers for that matter over the lowering springs I currently have. From all the images and post Ive looked over all the coilovers do over the springs is even out the back to the front but do not offer any more low?
    123592984_390303552121626_1211293227653509489_n(1) by Joseph Cerami, on Flickr
    Mar 11 2007
    4L Q7 3.0T Stage II, D4 A8L 4.2, A5 2.0t APR stage III, MK1 TT 225 APR stage I
    Colorado Springs
    Quote Originally Posted by BazookaJoe03 View Post
    You could do the H&R race springs they are lower than the sport, by quite a bit. The H&R street coilovers are adjustable so you can dial-in your desired ride height. The lower you go the worse the ride will be, very choppy...IIRC there is also an H&R track coilover too, but the ride quality on MN roads would suck. I guess it depends on what you want as an end result.
    2012 A7Plus APR Stage II+ UC
    2012 A8L 4.2
    Still own them all...
    Veteran Member Three Rings MTV10's Avatar
    Apr 29 2020
    Montreal
    Please post alignment specs. Thanks!
    2018 /S6 | Mythos Black / Arras Red | Stage II ECU | APR TCU | ARM Downpipes | AWE Touring Exhaust | SRM Intakes | CETE Lowering Module | 034M DSG Mount Insert | HRE P43SC
    Veteran Member Three Rings prestige.phantom's Avatar
    Jul 16 2018
    Connecticut
    Wheel Spec: 20x8.5 OEM 20" sport wheels
    Suspension setup: Eibach Pro Kit w/ Bilstein B4 Sport Shocks
    Should be 1"-1.2" lower than stock non-sport
    Comments: Zero rubbing, good ride, little to no scrapping, and pictured here with 7mm front and 8mm rear spacers (I would recommend bigger spacers lol)
    Before lowering
    Post-lowering
    2013 Audi A6 3.0T Prestige
    | Phantom Black Pearl | Nougat Brown interior | LED Headlights | Cold Weather PKG | 20" Sport PKG Wheels & 3 Spoke Heated Wheel | Fine Grain Ash Natural Inlays | Michelin Pilot Sport AS3+ Y | OEM "Rings" Puddle Lights |
    | AWE Touring Exhaust | JHM Non-Res DPs | Eibach Pro Kit & Bilstein B4 Sport Shocks | Eurocode Trans Mount | JBX Carrier | S8 Front Brakes w/ EBC Red Pads | 034 ECU 93 STG 1, TCU, Rear Swaybar, and Endlinks |
    IG: @prestige.phantom @ctautoart
    Established Member Two Rings Dnice24's Avatar
    Aug 03 2020
    Boynton Beach, FL
    Quote Originally Posted by MTV10 View Post
    Nice!!!! This is how low i want to be. I know this question has probably come up so many times, but what are the codes i need to lower via VCDS? Im new to this. Here is my before and after setup after i added Airmatic Lowering Links.
    Veteran Member Four Rings Alabama's Avatar
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Quote Originally Posted by Dnice24 View Post
    Search for thread "C7 A6/A7 & S6/S& VAG COM list and help".
    2014 CPO S6, SunTek PPF (applied by CGS Vinyl), BlackVue dashcam (installed by Radio Active), Hawk Brake Pads/Zimmermann Rotors/Goodridge SS Brake Lines, H&R sway bars, Alu Kreuz, 034 Drivetrain Mount Inserts, SRM Driveshaft Carrier (mechanical/maintenance by Franklin Automotive)
    Aug 03 2020
    Boynton Beach, FL
    Quote Originally Posted by Alabama View Post
    Thank you!
    Apr 29 2020
    Montreal
    HRE P43SC
    20x9.5
    ET32 all around
    5mm front spacer for an effective ET27
    Pirelli P-Zero 255/35R20
    Fitted.
