Sorry to bug you
How do you change oil on 1.8T?
Here is how I do it on my 3L, but IDK if the same procedure applies.
On other cars, the dealership sells me crush washers cheap or even free.
But for Audi they'd always have a whole plug and say that's the way it's done.
Why? The plug does not wear. It doesn't seal. It helps seal, with threads.
The crush washer is what seals. That's why it's called a crush washer. It crushes and is sacrificed. Some people re-use them. Some people even rub soap on it and heat it gently with a propane torch to swell it. The soap turns black when it's done.
I skipped that and went straight to MAP(P?) gas which is hotter, and no soap.
Let's just say it melted into a puddle before I even blinked.
So once I did go to dealer, and parts dept guy said "hold on, let me have a tech snip the washer off and put a new one, we've been having problems sealing with these lately".
I thought that was the whole point.
Why spend $3 on a whole plug which is what ETKA says to do (N 908 132 01), when you can just slap on a new washer for $0.10.
Cost savings add up over time.
You can buy crush washers anywhere. Dealerships. Online. Hardware stores.
I also heard aluminum is better than copper but IDK.
I actually bought a MetalNerd magnetic plug in hopes of reducing wear but maybe it was a waste of money, IDK. I mean yes, it DOES come out with metal shavings, but don't we have good Mann filters with magnets inside anyway?
You can see it when I wipe it with a towel and clean with brake cleaner.
__________________________________________
The reason the stock crush washer doesn't just come off is because the tolerance fit is tight. It has to be cut off. Dremel, bolt cutters, wire cutter, take your pick.
I might've even bent mine to yield/give but I forget.
(sorta like how when u bend a paper clip too many times, it breaks)
Which is why my aftermarket washers slide on. They're JUST oversized enough to slide on. So when I finish threading in the plug by hand (into the oil pan), I make sure the washer is lined up all around before I do the final tighten.
So do I order a pack of those?
IDK what size/dimensions.
Sorry for the blabbing I just wanna go in knowing what I'm doing and make this quick n easy... figured I'd ask the experts (you)
Other than that I guess I'll be doing the usual, pre-fill the filter, Mann 940/25 + Motul 8100, cut-open 1gal Milk Jug to catch filter oil drips
Lube the filter seal with my finger. Wipe up the cooler face. Tighten the filter with sandpaper.
This worked great for my 3L Mann 930/21 filter removal.
I think I had a stuck filter once, dunno which car it was.
Poked a big flathead screwdriver through it with a hammer, so I could turn it/break it loose.
Wonder if any pans need re-gasketing. Maybe drop it to inspect pickup tube mesh screen. The VCG stinks.
I will search...
