And wow, that sound is pure sex. I was concerned about the other half and the new found harmony. I think it's actually quieter than the Soundaktor, which I turned down to 0℅ after the install.
Installation was relatively easy. Took about two and a half hours, with 30 minutes wasted removing the valve controls. I undid the three bolts, not knowing which style electrical connector they used and couldn't see how to release while installed. It was super simple, pull the tab, then slide off. Wish I had known that.
Then the next problem:
Yes. It was bought new, there was no shipping damage, haven't reached out to the guys at TAG yet, or if I should go straight to AWE. I managed to get it round enough to slide the pipe in, I wasn't putting the stock exhaust back on. I don't even know if it's an issue or not??
I was able to put PB on about two hours prior, which helped removing the four OE brackets. Grab an exhaust hanger remover and the install is simple. I spent too much time working on the tips, it dropped after a short drive about half an inch.
Armed with that info, you can do this in your driveway in two hours.
