Results 1 to 3 of 3
    Veteran Member Four Rings vailshred's Avatar
    Aug 20 2011
    Arizona/Colorado
    Burning oil once warmed up... Your opinion please Post Hydro lock
    So I just experienced Hydro lock in cylinder 8 on my 05.5 S4. The injector was bad and dumped a un imaginable amount of fuel into the cylinder. The car initially started stalling out at highway speed. I pulled into the shoulder and was able to sputter off the highway. It finally stalled out and I thought it ran out of gas. When I tried to restart it I heard a loud bang. I assumed it was timing related. When I yanked the engine I noticed the starter was broken and a tooth on flywheel was missing. When I removed intake mani I then noticed about 2" of fuel on top of the closed valves. I then saw that all the timing components were ok. I reinstalled the engine after timing service and another starter broke. After being stumped for a hour I remembered the fuel in the intake port. I replaced injector on cyl 8 and the car started perfectly and idling great. After about 3 minutes of running I started to notice bank 2 was blowing bluish smoke. I turned off engine and unplugged cyl 8 coil. restarted it and smoke stopped. There is also a rapid clicking sound coming from cylinder 8 valves.
    Whats your opinion on the damage and where do you think oil is coming from? No matter what the engine has to be pulled again. Im just hoping its valve damage and not piston/rod.... Has anyone ever experience this?
    Thanks
    Established Member Two Rings bwizard's Avatar
    Oct 10 2016
    Colorado Springs, Colorado
    Did you pour a cap full of oil onto #8 ? The fuel more than likely washed out the rings. Pour a cap full of oil in the hole put the plug Back in crank with no spark or injector pulse so pull Ecu fuse let compression force oil back into your rings. After 6-10 cycles pit Ecu fuse back in fire it up. It will smoke while it burns excess oil off after should be good.
    Sent from my S4's talk to text @ a buck thirty
    weekly driver 02 S4 2.7t auto stock
    Wife's 04 A4 1.8t auto stock
    Daughter's 97 A4 AEB Bored to 2.0t K04 sport cams
    My role family tech.
    Oct 10 2016
    I have had to do this many times inn engine that have hydro locked with fuel don't pull it again test compression/ leak down test before and after adding oil. My guess is fuel just washed out the rings.
