Results 1 to 8 of 8
    Sep 28 2011
    Michigan
    Thumbs up 2009 Audi A4 Quattro 93k miles for $9k
    Selling my 2009 Audi A4 quattro with 93,000 miles. This car is fully loaded with every option except the S-line package. It has the sought after Xenon headlights with LED daytime running lights (beautiful). It also has the rare navigation option which not only gives you a better multi-media interface but also gives you the color info display in the instrument cluster. It has the premium sound package with advance DSP settings in the MMI and a great subwoofer. It has 6-stage heated seats.
    Mechanically, this car drives perfect. Had recent suspension work and brake pads all around, as well as some fresh tires. The quattro all wheel drive is great in the winter. The engine starts up and runs strong every time and the car shift like butter, its hard to believe this car has 93,000 miles as it drives like a new car, not to mention still looks modern like the newest audi's coming out. 2009 was the first body style this B8 chassis came in, and was produced until 2012 until audi face-lifted it in 2013-2016 which were called B8.5(same chassis and interior) so you are getting a car that is the same as a 2016 on the inside for the price of a 7 year old car.
    The one negative I could say about this car is that it does hold a rebuit title, this is not because of a major front end collision(which could hurt the drivetrain) or flood damage. It had a drivers side collision which needed both drivers side door replaced and the curtain airbags only. the doors line up perfectly and close and open as it should without any problems. No important components were damaged only body which was repaired flawlessly. I have pictures of the original damage I can send.
    This is why im selling the car for this price, and if you're looking for a A4 that drives good and still modern for a great price then this is your car. You're getting a great deal because of the title, but still driving a car that drives and looks new and much more expensive. For this price most A4s on the market are 2004-2008 B6 or B7 chassis. This is your chance to get a loaded B8 for a bargain.
    Price is $9,000
    Call or text 810-399-3998
    Aug 19 2016
    Newport Beach/CA/USA
    Price?
    Aug 19 2016
    Have the piston rings been replaced from Audi?
    Sep 28 2011
    Michigan
    Price is 9,000. I am not sure if the piston rings have been replaced, I honestly got this car quite recently but decided I want to get one with the 6-speed.
    Aug 19 2016
    Ok thanks. I would only be interested if the piston rings were replaced by Audi. Do you have all the maintenance records?
    Aug 19 2016
    That model burns tremendous amounts of oil unless the rings were replaced.
    Aug 19 2016
    Does it have the Audi side assist?
    Sep 28 2011
    Michigan
    Quote Originally Posted by prkieffer View Post
    It does not have audi side assist, I will contact the local dealer and obtain maintenance information.
