Results 1 to 16 of 16
    Aug 17 2015
    San Francisco
    Coolant light came on
    Hey guys is topping the coolant just putting antifreeze in? I've heard some people mixing water with it? My light came on saying it was low. Maybe a leakage who knows but I'd like to top it off to determined that. Thanks
    Established Member Two Rings bwizard's Avatar
    Oct 10 2016
    Colorado Springs, Colorado
    G12 full strength yes mix it with water
    Sent from my S4's talk to text @ a buck thirty
    weekly driver 02 S4 2.7t auto stock
    Wife's 04 A4 1.8t auto stock
    Daughter's 97 A4 AEB Bored to 2.0t K04 sport cams
    My role family tech.
    Nov 13 2009
    the OC, SOCAL
    my car has had coolant burning off once in a while. I can smell it. I have taken it into the dealer for a look see and they said nothing is wrong and they just topped it off.
    Veteran Member Four Rings Arclight's Avatar
    Dec 20 2006
    8VS3
    I have topped my coolant at least 2x since I purchased the car a year ago (S3). It seems to be weeping from somewhere associated with the AC system. I only see it on the ground and smell it on hot days when the AC is running. Last time I took it to the dealer they said it was fine - nothing leaking. I suspect we will see a TSB before it's all said and done
    For Sale: HRE 501s, 19 X 8.5 and 19 X 9.5
    Apr 01 2014
    Madison WI
    Funny this popped up, I was headed home on a 2+ hour drive and about half at through my light popped on. I immediately pulled over, shut off the car and popped the hood.
    I found mine was well below the min line and I very carefully unscrewed the cap to the overflow. There was an air bubble caught in my coolant system and once that was "burped" it leveled to where it should be.
    I turned it back on and let it run for a minute and it stayed. I kicked on the a/c to put a little draw on it and it still stayed. Continued the rest of my trip for over an hour with a single issue. I currently have about 12,500 miles on my 2016. Hope this helps!
    Nov 13 2009
    the OC, SOCAL
    the dealership said there was a tsb about some sort of air pocket that needs to be burped. but since then (6-7 months ago) I have continued to smell coolant on random times. I know that's not normal no matter how they put it. my car is stock so it shouldn't be doing anything like that.
    May 03 2016
    Champaign, IL
    Interestingly enough, when I dropped my car off at the shop this morning to get my downpipe installed, the tech told me he smelled some burnt coolant in the engine bay. We checked the levels and it was actually a little above max (overfilled?). Kind of relieved to see that other people are experiencing it also, and interested in finding out what's the cause/fix.
    EDIT: how exactly does one "burp" the system? Could an air bubble trapped in there cause the overfill (like the coolant isn't flowing)? I never got a light and everything seems to be working fine otherwise. Thanks!
    Veteran Member Three Rings Baggio's Avatar
    Aug 28 2013
    University Heights, OH
    Quote Originally Posted by IronMan-Mark2 View Post
    Mix 50-50 with distilled water.
    2015 Daytona Gray Pearl Effect Audi S3 Quattro | Daytona 1 PKG | USP Motorsports interior LEDs |
    | APR Stage 2 ECU 93 HT & TCU tune | K&N | rain tray delete from airbox | REVO CF intake scoop | Spulen turbo inlet hose | APR turbo muffler delete |
    | APR IC | CTS Turbo inlet, outlet, and throttle pipes | Neuspeed 3" catted downpipe | 034 dogbone mount insert | 034 rear subframe inserts | Spulen intake coolant hose | ECS SS brake lines |
    Nov 13 2009
    the OC, SOCAL
    I feel that the headgasket is bad on our cars. I'm currently working on anther car that has a bad headgasket and the symptoms are similar to these listed by everyone but in a much faster rate. originally it was a slow leak in the h.g. but now all it takes is some stress on the engine and it starts to push coolant out the reservoir and overheat at a stop light.
    symptoms that are similar:
    smelling of coolant, in hot form.
    coolant levels will rise in the reservoir right after you smell it. the cause; well when coolant is being pushed out from the block it will normally goto the reservoir in turn making it look like there is more coolant than there should be originally. eventually it will over flow out and youll need to refill it because the engine will cool down when parked and the coolant will be pulled back into the block, but most of the coolant isn't there anymore in the reservoir. (like how we all are doing now)
    heavy stress will cause the symptoms to show up more such as A/C running, hot days, long drives, or hard accelerations.
    burping, the dealership should be taking care of the burping on your car as it should be under warranty still. its just a small pocket of air that is trapped in the hoses somewhere. what that should only do to our cars is throw off the temp gauge and thermostat but the dealership is convincing us that its causing the coolant smell and needed refills.
    as for now I'm with everyone here and going with the flow of information that the dealership is telling me and not with my personal experience. as long as they cover any future damages.
    Aug 28 2013
    Quote Originally Posted by 949 View Post
    If the head gasket was bad or going bad, you would see milky looking oil when you check your oil. Check your oil and get back to us.
    If it is backing up and overflowing the reservoir, it possible could be a bad thermostat and it isn't opening properly.
    Oct 10 2016
    Quote Originally Posted by Baggio View Post
    Not always my wife's b6 a4 amb engine had a bad head gasket and was just burning coolant. It is possible for a way into combustion chamber with out mixing with the oil
    Veteran Member Three Rings 1S32K16's Avatar
    Jul 07 2016
    Just checked my coolant level after reading this thread, seems to be nearing the low marker. Car has roughly 2,200 miles on odo. Running a jb1 for maybe 500 miles. Cant decide to take it to the dealer for a top off and take jb1 off
    2019 Quantum Gray SQ5 with black optic package, 20% Rayno Ceramic tint, TAG Motorsports Painted Front Reflectors, BMC Air Filter, JB4, 034 Trans Mount, OEM Black Badges, 21’ BC Forged RZ39, Redstar 200cel DP, ODIS factory lowering
    2016 Monsoon Gray S3 with black optic package, Emmanuele design springs, rear sway bar and endlinks, 19' Forgestar CF5's
    Nov 13 2009
    the OC, SOCAL
    Quote Originally Posted by bwizard View Post
    I agree with you. +1
    there doesn't always need to be mixing like you said.
    Aug 28 2013
    Well, he needs to make up his mind. In one sentence it's the head gasket, the next he says it is backing up into the overflow and expelling coolant out that way. IMO, if it it is the head gasket there would be a lot of coolant loss. Just my opinion from years of of experience with a lot of cars. I tend to think it it is "weeping" out by the water pump more than the head gasket based on most people's responses here. But who knows it could be anything as no one, including dealers have figured it out.
    Oct 10 2016
    He needs to do leak down test. Turbo engines obviously have pressure in intake and combustion chamber. Which if leak in gasket is big enough not only will coolant expand from overheating but also the pressure from boost will force coolant out overflow tank
    Jan 17 2012
    '14 S4, '15 Subaru Forester
    Los Angeles, CA
    Quote Originally Posted by 1S32K16 View Post
    The D plug makes the decision so, so difficult. Ugh.
