Results 1 to 13 of 13
    Senior Member Two Rings AFAndrew's Avatar
    Nov 15 2015
    St George Utah
    High miles engine ticking
    Hey guys I attached a video of a ticking I'm hearing from the engine. Is this normal for the 2.0 engines? I have not done the timing chain tensioner yet because it doesn't seem that it needs it yet I will soon. My car is at 121k miles.
    Veteran Member Four Rings CONative's Avatar
    May 06 2015
    B8 A4 Avant / B7 S4 Avant 6MT / Subaru Outback Limited
    IMO our engines sort of sound like diesels....but what you hear around :20 doesn't sound normal to me.
    Cheers,
    Ry-man
    Established Member Two Rings bwizard's Avatar
    Oct 10 2016
    Colorado Springs, Colorado
    Quote Originally Posted by AFAndrew View Post
    My brother said the same about his timing belt next thing you know valve job.
    Sent from my S4's talk to text @ a buck thirty
    weekly driver 02 S4 2.7t auto stock
    Wife's 04 A4 1.8t auto stock
    Daughter's 97 A4 AEB Bored to 2.0t K04 sport cams
    My role family tech.
    Veteran Member Four Rings pierreb's Avatar
    2020 A4 allroad
    NH
    Do it before the misfires start. Might be too late though.
    Nov 15 2015
    St George Utah
    Quote Originally Posted by pierreb View Post
    Replaced the coil packs and spark plugs about 5k miles ago.
    2020 A4 allroad
    NH
    Ever replace the injectors before the warranty expired at 120k?
    Nov 15 2015
    St George Utah
    No didn't know there was one
    2020 A4 allroad
    NH
    Then maybe those are crapping out. It's hard to tell. If you take it in and have them do a leak down test they might goodwill you some. Depends on the dealer I guess.
    Dec 01 2011
    the ticking sounds pretty normal, mine sounds like that and i've walked past other B8's that i've heard like that, and also alot of people on here report the same i guess thats just how the 2.0TFSI sounds.
    but yea that screech sound right around the end when you see the alternator, that isn't normal i've had a similar sound and ended up having to replace my alternator for a bad bushing/bearing or something, but replaced the whole unit. and got a new belt at the same time too. but definitely get the alternator checked out. and i would do the timing tensioner and chain update as soon as you can because it can happen out of nowhere and i wouldnt risk that.
    IG @theshawon
    Jan 13 2014
    nyc
    What he said ^^^^
    Established Member Two Rings punkalex1's Avatar
    Oct 26 2015
    Orange County CA
    also the sucking sound you hear when you get to the front of the engine could be the pcv diaphragm. i remember hearing the exact sound plus i started getting loss of power out of nowhere, luckily thats only a $20 fix on amazon
    Nov 15 2015
    St George Utah
    Quote Originally Posted by punkalex1 View Post
    R u talking about the circle diaphragm where the pcv?
    Oct 26 2015
    Orange County CA
    yes that one
