Results 1 to 34 of 34
Thread: Exhaust Options
    Established Member Two Rings drivenagain's Avatar
    Sep 05 2016
    MD
    Exhaust Options
    Im one to fab up my own exhaust, but before I dive in I'd like to know whats readily available to the Q5.
    Do the various S4 systems work or are they platform specific?
    Jason
    2013 Q5 3.0T | 57mm | 194mm | EPL DP Tune | Injen Intake
    2009 Aprilia Dorsoduro | TI Fuel Exhaust
    Senior Member Three Rings jpsjr's Avatar
    Jun 08 2016
    2018 Porsche 911 Turbo S Convertible
    Central NJ
    You have choices......
    *AWE Exhaust - Non Valved System, sounds good goes for $1,800 to $2,100. It's a Stainless Steel System. Some complaints of sagging even when you tighten the bolts big time. The AWE guys are super cool and have helped everyone with this issue. The vendors on here are super awesome and price these systems pretty aggressively. Shop around.
    *Milltek Exhaust - Valved System, sounds really nice but pricey @ $2,000. Very few guys have this system. It's a Stainless Steel System.
    *MagnaFlow - Valved System, sounds perfect in my opinion. Should have came from factory sounding like this. $1,100!
    There's about 4-5 of us with MagnaFlow, all of us like it. Fitment it perfect and no sag on the mufflers. It's a Stainless Steel System.
    If you decide to upgrade your system, you may need a Valance from a SQ5 if you want nice exhaust tips. I currently have one if your interested. If you look at ECS Tuning for the OEM SQ5 Valance here is the info.......
    8R0807521BL1RR Rear Platinum Gray Valance - $434.10
    8R0807819M1RR Rear Platinum Gray Valance - $126.28
    Plus you will need to get the proper trim for the top part of the Valance which comes in Chrome or Black.
    Jose
    2019 Audi A6 3.0T Glacier White/Black
    2018 Porsche 911 Turbo S Convertible White/Black
    2018 Porsche Cayenne Turbo S White/Black
    Sep 05 2016
    MD
    Quote Originally Posted by jpsjr View Post
    Jose thanks for this info...which part # from MagnaFlow?
    Jason
    EDIT: Just found the MagnaFlow thread
    Jose
    nice post. thanks for information :)
    Jun 12 2015
    CA
    That trim piece is pricey too.
    2015 Q5 3.0T | EPL E85 | APR SC pulley | KI 194mm crank pulley | CTS Turbo intake | AMS Alpha cooler | EC headers | Milltek valvesonic exhaust | KW V3 coilovers | 034 X-brace | 034 Trans mounts | 034 Rear sway bar | 034 ACAs | Girodisc LW front rotors | JHM LW back rotors | HRE P104 21x9.5 | Michelin PSS 285/35/21 | Autotech HPFP
    11.788 @ 115.64mph [ KI 194 / APR 57.73 | 104 | -350 ft. D/A ]
    11.950 @ 113.61mph [ KI 194 / APR 57.73 | E85/91 | +300 ft. D/A ]
    0-60 in 3.71
    Jun 08 2016
    Central NJ
    Quote Originally Posted by drivenagain View Post
    Jason
    Jason, I believe you are going to order a SQ5 one and it should bolt up perfectly. Can anyone confirm this? I ordered on Hottexhaust.com and payed $1,050 shipped.
    Jose
    Jun 08 2016
    Central NJ
    Quote Originally Posted by colby7 View Post
    No shit! I believe the black one goes for $500! Crazy?
    Jose
    Jun 08 2016
    Central NJ
    Like stated, I have a rear Valance with the Hitch Cover if you are interested. I would sell it for $300 shipped if your interested. You will need the trim piece that cost a crazy amount, whether you get black or chrome. PM'me you want it. It's in mint condition!
    Jose
    Jun 08 2016
    Central NJ
    Colby7 I just noticed your running a Milltek on your Q5 3.0T, how does your exhaust sound? Did you change out your Valance to a SQ5? Did you bolt up with a SQ5 system?
    Jose
    Jun 12 2015
    CA
    I'm not a good person to ask about the sound because I also have EC headers so it doesn't sound the same. I bought an SQ5 valence, and painted it black to match the other OEM trim pieces. If you want a Milltek you're going to have to go this route because they don't make an exhaust for the 3.0T Q5.
    0-60 in 3.71
    Jun 08 2016
    Central NJ
    Jason, there's your answer. Thanks Colby7! Forget the sound since he's running eurocode headers but since the motor is basically the same setup as SQ5, the exhaust should fit perfect. Hopefully this all helps.
    Jose
    Veteran Member Four Rings VroomVroom's Avatar
    Jan 03 2007
    SF Bay Area, CA
    Total FWIW: my Magnaflow experience on an SUV.
    Their pricing is awesome, their designs are solid, and the sound....intoxicating. For a while. That packing inside the mufflers breaks down. Obviously how long that takes depends on miles, driving style, etc., but when it does.... the R word. Resonance. And it's bad. From outside, you definitely notice the volume increase, which is cool...but if you're cruising down the highway, that drone will seem like torture.
    I can't speak to AWE or Milltek designs because I haven't really been tempted to pursue an exhaust (show me a system with 4" rolled tips and we can talk!) but I think this is worth considering, especially if you plan go keep your machine for a while. That initial cost savings disappears if you have to replace mufflers and tips.
    --Jerry || 2020 SQ7 Pr, GW/Black/BO (His); 2018 S5 Cab Pr, Daytona/Red (Hers)
    Suspension || H&R Springs - 29001-3; Bilstein B8 Dampers - 24-145985 (F) & 24-145992 (R)
    Wheels & Tires || BBS CI-R - CIR 0501 BPO, 20x10 ET25 Satin Black; Continental DWS06 275/40
    ...Formerly: '16 SQ5 '13 Q53.0T '12 Q5 3.2 '08&'06 A4 Avant 3.2.
    Jun 08 2016
    Central NJ
    Totally understandable, but keep in mind that MagnaFlow states this on their website.......
    QUAD SPLIT REAR EXIT
    Made in the USA and engineered to last, for those seeking increased performance and better economy, MagnaFlow Touring Series Performance Exhaust systems deliver the smooth deep sound you want and the wide-open performance power you need. Our exhaust systems feature straight-through flow designs for the ultimate in unrestricted horsepower and torque for big power while maintaining exhaust efficiency. These systems are an engineered balance of interior and exterior noise levels and are tested against SAE j1169 standards.
    • All Mandrel Bent Tubing
    • 409 Stainless Steel Construction
    • Increased Horsepower and Torque
    • Lifetime Construction Warranty
    • Made in USA
    I guess if you blow it, they cover? MagnaFlow Rep sometimes is on the forum he may answer better?
    Jose
    Deactivated Two Rings
    May 08 2016
    Northern VA
    Exhaust Options
    This is a plentiful amount of information and was something that needed to be put together. I've reviewed, what I think to be, every available option for the S/Q5 platform, and while AWE is definitely my favorite option, I feel for the price, I can build something that will sound just as good for just about half the cost. Currently I have all T304 stainless 2.5" piping for a dual system that will include an X, mid muffler with cutouts, and quad rear resonated exits.
    What most have said about the trim piece is correct - it's a pricy unit. Even for the black trim option. It's hard to find a good deal on one. A friend of mine will be doing a lot of the welding for me and I'm expecting to have something completed by Christmas time.
    With quality materials, mufflers and resonators, in hoping for a nice little rumble. Of course, when I want to make noise, I can flip the cutout open and open it up
    Veteran Member Four Rings ThunderDent's Avatar
    Mar 14 2012
    2010 Ibis R8 Coupe 6MT V10 // 2015 Sepang (Stage I) SQ5 // 2018 Galaxy Q7 (Wifey’s)
    Ona, WV
    I have the MagnaFlow system Jose has.
    It's only an axle back system (which does retain the valves), where the AWE system is Cat back.
    The sound is perfect, and it looks phenomenal.
    I will say in 8th gear running on the interstate, there is drone.
    It's definitely louder than stock. But has a really sweet note to it.
    Not to overbearing. How the SQ should have been from the factory.
    The 8th gear drone is my only negative impression.
    Here's the MagnaFlow exhaust video.
    https://youtu.be/fiw5hmcY2fI
    Current Stable:
    •2010 Audi R8 V10 Ultra Ibis White—Black/White Stitching (6MT)
    [Nemesis/APR/Carbon Fiber/GT/Euro/LMS]
    •2019 Audi RS3 Nardo Gray—Black/Red Stitching (S-Tronic/Daily)
    •2018 Audi Q7 Prestige 3.0T Galaxy Blue—Black (Wife’s Ride)
    •2018 VW Golf S (Daughter’s Ride)
    Past Whips:
    •12 WRX Dark Gray Metallic (6MT) •11 Audi Q5 Ibis White (APR Stg 3) •12 VW GLI Tornado Red (DSG) •16 Audi Q3 Hanian Blue •15 Audi SQ5 Sepang Blue (EPL Stg I) •19 VW GTI SE
    Jun 08 2016
    Central NJ
    Totally agree with Joel with the sound, on the interstate I don't hear that drone coming from the exhaust though. I'm usually doing 85-90 mph and I don't hear it, maybe because I leave it out dynamic mode? Joel do you drive it on dynamic mode 24/7?
    Jose
    Active Member Two Rings SQ5-ER's Avatar
    Apr 13 2016
    Montreal Canada
    Had my AWE about 6 months now and I'm really happy with it. I'd say that for day to day driving (car in "D" and Comfort so the RPMs stay lower) it really isn't much louder in the cabin than with the OEM exhaust. 8th gear highway driving where your RPMs are low, you wouldn't know the difference. When you go hard, its naturally a very different story. Not super loud, but very raspy and guttural. More Maserati than muscle-car.
    Mar 14 2012
    Ona, WV
    Yes, I drive in Dynamnic (100% of the time) and manual (99% of the time).
    I like the gearing to be in my hands. I just can't let my manual past go I guess
    I wanted the valve option so when my wife drives it she can set it to comfort or individual for her and the baby.
    Current Stable:
    Past Whips:
    Registered User Three Rings MagnaFlow's Avatar
    Jan 26 2015
    Oceanside, CA
    Quote Originally Posted by VroomVroom View Post
    Jose
    The packing material we use in our mufflers is a special blend of steel and lava rock, so it's uncommon to hear of them blowing out in the way mufflers with fiberglass packing (cherry bombs, etc.) do. We stand behind all of our exhaust systems and back them with a lifetime warranty, so if you feel that your mufflers are not performing the way that they should, please give our customer service dept a call at 1-800-990-0905!
    Mar 14 2012
    Ona, WV
    Great to hear!
    I'm loving my MagnaFlow setup!
    Current Stable:
    Past Whips:
    Jun 08 2016
    Central NJ
    Quote Originally Posted by MagnaFlow View Post
    Great to know! Thanks for chiming in. Absolutely loving my exhaust, only complaint? BLACK EXHAUST TIPS!
    Jose
    Dec 20 2011
    Calgary
    Still debating my own exhaust set up, currently looking at the MF 12468 and lopping off the mid muffler before the exhausts. Would that be the correct part to replace? I've been looking up vids of the S4/S5 with the resonated X-Pipe, assuming it would sound somewhat similar. I'm wondering if this would be a good fit for my budget setup before jumping the gun and doing the full MF Catback.
    Thoughts gents?
    Veteran Member Four Rings buggravy's Avatar
    Jun 25 2016
    Mountain bikes and snowboards
    Calabasas, CA
    Jose
    Just got mine put on yesterday, and really like it so far. I powder coated the tips, and I think I prefer the look with no logo over having black tips from the factory.
    '23 S4 Prestige - Chronos Grey
    '21 Q5 P+ - Glacier White (wife's)
    SOLD: 21 S4 - Mythos Black
    SOLD: '19 SQ5 - Quantum Gray
    TOTALED: 21 SQ5 - Ultra Blue
    SOLD: '19 e-tron - Typhoon Gray
    SOLD: '16 SQ5 - Sepang Blue w/Black Optics
    IG: @gravysq5
    Jan 09 2009
    1of50
    I have had my Magnaflow for a couple months now and after 3 long distance road trips, longest being 7 hours....there is definitely some highway drone even when it's not set on dynamic when going 80+, but it's not that bad. BUT for my daily commute to work everyday, it's set @ dynamic and I LOVE the sound! The tips do get black in about 2 days for me, but they are very easy to clean. Install was cake and took minimal effort to get them perfectly centered. All you need to do is play with the hangers a bit and tighten down the o-ring clamp so that it will stay centered.
    Mar 14 2012
    Ona, WV
    Here is couple of pics of it installed and the ADS electric valve assembly mount that is part of it.
    Current Stable:
    Past Whips:
    Stage 2 Banner Advertiser Four Rings Josh/AWE's Avatar
    Feb 08 2012
    Horsham, PA
    Quote Originally Posted by SQ5-ER View Post
    Glad you're loving it!
    The OEM-like in-cabin experience is thanks to our proprietary drone-canceling solution, 180 Technology® -- sophisticated when you want it, quiet when you need it. It was specifically tuned for the 8-speed Tiptronic® trans.
    All of our systems are handcrafted from T304 stainless equalling zero rust. Others use 409 grade stainless, which will rust, more slowly than non-stainless... but it will rust (ferrous material is what causes rust, and ferrous material is also magnetic. A magnet will stick to 409 grade, a magnet will not stick to 304 stainless.)
    Here's a clip for your listening pleasure, OP:
    Otherwise, if you have questions about anything feel free to PM or email me
    Performance Specialist
    AWE-Tuning.com > 1.888.565.2257
    my email > facebook > twitter > instagram > youtube
    Sep 05 2016
    MD
    Quote Originally Posted by Josh/AWE View Post
    Josh will the track kit fit the q5?
    Feb 08 2012
    Horsham, PA
    Not sure what kit you're referring to, I'm afraid
    Sep 05 2016
    MD
    minus the tips, will this fit a Q5? Thanks
    Feb 08 2012
    Horsham, PA
    Negative. Similar in some aspects, but the rear pipes are not applicable to the Q5. Besides, we didn't create a Track Edition for the Q5 for good reason -- it needs 180 Technology® for in-cabin acoustics sake.
    Established Member Two Rings vik0wang's Avatar
    Jun 02 2016
    north california
    Quote Originally Posted by ThunderDent View Post
    any idea how to eliminate 8th gear drone?
    i have milltek exhaust and 8 gear drone is horrible
    VVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVV V
    Mar 14 2012
    Ona, WV
    Quote Originally Posted by vik0wang View Post
    Yep, run it in M7.
    It's reallly the RPMs man. If you're running 1800-2000, then it's pretty droney.
    If you keep it 2200+ your making good music.
    Current Stable:
    Past Whips:
    Jun 02 2016
    north california
    Yep, run it in M7.
    Thx bro
    Jan 08 2016
    Los Angeles, California
    Yep, run it in M7.
    That sounds like a design defect if you can't even use 8th gear because the exhaust you bought (in large part for better sound) makes the sound unbearable.
