Results 1 to 6 of 6
    Oct 16 2013
    nj
    Popping sound when braking
    Two or three weeks ago I noticed my car would make a popping noise somewhere in the front end when I reversed and then applied the brakes the first time. It would not happen again if I continued to drive in reverse but would happen as soon as i started driving forward and again, only ht first time applying the brakes since changing from reverse to forward. It's as if something is shifting and knocking against something else. Car has about 96,000 miles and the front brakes were changed a few months ago. anyone have any ideas what it could be? Motor mounts, suspension, axles, CV joints?
    Thanks in advance.
    Established Member Two Rings bwizard's Avatar
    Oct 10 2016
    Colorado Springs, Colorado
    Worn bushing in a control arm ,lose bolt , in front suspension, tighten all subframe bolts.
    Sent from my S4's talk to text @ a buck thirty
    weekly driver 02 S4 2.7t auto stock
    Wife's 04 A4 1.8t auto stock
    Daughter's 97 A4 AEB Bored to 2.0t K04 sport cams
    My role family tech.
    Senior Member Two Rings Davidx1994's Avatar
    Feb 02 2015
    2019 Macan, 2015 Jetta TDI, 2009 A4 Avant
    Plainville, CT
    Quote Originally Posted by sadj2885 View Post
    Thanks in advance.
    What brand pads did you go with? I bought my car with aftermarket brake pads and it did the same exact thing when first applying the brake after switching from reverse to drive.
    I just replaced my front pads with TRW pads from Amazon and no more noise. The problem with some brake pads is that their fit isn't perfect and shift against the caliper pins when you switch directions. Had this also happen on my Saab with Akebono pads.
    Oct 16 2013
    nj
    Quote Originally Posted by Davidx1994 View Post
    They actually are Akebono pads, but its been a few months since they were put on and the noise just started a few weeks ago, or at least that's when I started noticing it. Anything I can do to prevent it or should I just get used it to it?
    Feb 02 2015
    Plainville, CT
    There's no way to stop it, but I had no issues with the brakes otherwise.
    Veteran Member Three Rings audinutt's Avatar
    Jan 11 2007
    2001 A8l 2001 A4TQM Avant
    texas
    Maybe fab up a shim?
    Sent from my SM-N900V using Tapatalk
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
