I've been searching but coming up empty. I have an 03' A4 3.0 and it is pissing oil out of the the bank 1 intake cam sprocket. I understand the timing belt has to come off, but I can't find any info anywhere on replacing the seal. I just replaced the timing belt and valve cover gaskets thinking that was the problem, but now I see it is the cam seals. I have the Bentley book, but it does not give the procedure for removing the sprocket and seals. The only info I found was some tech posting in another forum, that it is too complicated for anyone but an Audi tech. (Whatever).
Does anyone have a DIY or the Elsawin write up. My windows based computer has died and I can no longer pull up Elsawin. Thanks
