Results 1 to 22 of 22
Thread: A7 DSG failure!
    Sep 22 2013
    Norway
    A7 DSG failure!
    Dang here we go!, yellow oil on the garage floor, and "Gearbox failure, you can continue to drive with reduced functionality".
    When it shifts gears it feels like its a worn out clutch in low gears, works ok in easy going traffic.
    Any thoughts?, I can't seem to find similar posts here, but then again, the US version is a "proper automatic" as far as I know.
    |A7|3.0|TFSI|B&O|NightVision|HeadsUp|Led Headlights|
    Veteran Member Four Rings jmeenach's Avatar
    Mar 17 2014
    Los Angeles, CA
    what year? How many km on the car?
    Pedal Responce Team's expedition ace/Banana Responce Team first responder
    2013 B8.5 A4 Quattro. RS grille / 20" 'Flower Petal' reps / AFE / VCDS mods / more to come...
    instagram
    Sep 22 2013
    Norway
    2011 125000km
    All services done.
    Mar 26 2010
    US
    Quote Originally Posted by Soft View Post
    So it is 3.0t DSG dl501, like the b8 s4?
    What year?
    The S6 has the dl511 dsg.
    Mar 26 2010
    US
    I see 2011, that was a year of many b8 s4 DSG failures. There were circuit board issues & other problems on the 2011 DSG .
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by wwhan View Post
    No such thing exists. That was a single typo in Audi literature that got propagated around. There is some speculation that it is a "beefed up" DL501 but there is no proof or details of what if anything was strengthened for the S6/S7 duty.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Mar 29 2014
    Hampshire, UK
    Well l definitely wouldn't drive it if it's dropped it's oil over the floor, regardless of what the DIS display says.
    I would get it picked up and taken to your dealer for diagnosis. If you have regularly had it serviced inside the dealer network, they may be sympathetic.
    I've also seen plenty of these boxes on eBay, if you need to replace.
    2016 S7 Sepang Blue ///Matrix//Bose//Self Park//Lane Assist//ACC//F&R parking cams//Blackvue DR750//Phone Box//Sunroof//Privacy glass//Carbon mirrors//Neidfaktor Steering wheel//RS Knob//OEM RS Grill//Suntek PPF//De-chromed//Modded Exhaust//Cete ASC v2 installed//APR Stage 3 w/RS7 Turbos and intake pipes + TSU//Eventuri CF intake//Carbon Diffuser
    Gone: 2014 Audi A7Q 3.0 TFSI
    Gone: 2011 Audi A6Q 2.8 TFSI
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Low fluid will cause all sorts of problems.
    I hope you haven't driven it much like that.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Mar 26 2010
    US
    Quote Originally Posted by gk1 View Post
    Well The DL511-7Q is listed in the Audi SSP 920223 on the 4.0TT for the S6/S7. It also has a coasting (free wheel) function that the S4 did not have.
    2019 RS5 Sportback
    Mar 26 2010
    US
    There was also a DQ511 10 speed transmssion, which had the freewheel coast mode, but it seems to have been cancelled: http://articles.sae.org/13750/
    and ..... http://www.leftlanenews.com/vw-shelv...ion-89725.html
    "Designated internally as DQ511, the 10-speed is closely based on the current 7-speed DSG (DQ500), which also has a 550-N·m peak torque capability."
    "The DQ511 gearbox would have served as an drop-in alternative to VW's seven-speed DSG, adding extra gears for improved drive-off performance and better fuel efficiency at highway speeds. Fuel consumption is further reduced via engine decoupling while coasting, along with low-friction bearings and special coatings on the gearwheels."
    2019 RS5 Sportback
    Sep 22 2013
    Norway
    It's at the dealership now, they will have a look at it today, will keep you informed.
    I have a nasty feeling this will be expensive!
    Sep 22 2013
    Norway
    Update,
    It was a leak it the oil filter holder, around the drainage hole.
    Car is slipping in 1. gear, and needs to take out the gearbox :-(
    Aug 06 2014
    NJ->CO
    Yep, that's the typo I'm referring to. The only existence of the mythical DL511 which has curiously identical specs to the DL501.
    The (free wheel) function you refer to is software function enabled/disabled based on model use and location. It is definitely NOT in use in the US S6.
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Mar 26 2010
    US
    Yep, that's the typo I'm referring to. The only existence of the mythical DL511 with curiously identical specs to the DL501.
    The S6 in sport/dynamic, holds the gear & engine brakes, but in comfort/auto mode, it feels like it is disconnected after letting off the throttle.
    2019 RS5 Sportback
    Aug 06 2014
    NJ->CO
    Perhaps that software was changed for 2016 but I think you are the first to mention it. Or you are just feeling the effect of the lower gear in sport/dynamic since auto/comfort always aspires to be in highest gear possible.
    AFAIK The freewheel function is only enabled if you have drive select mode "economy" I think a few enabled the mode via VCDS but IIRC they did not like the results.
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Veteran Member Four Rings Xtek's Avatar
    Jun 09 2013
    In Economy the DSG acts very oddly. If you are coasting/braking and try to accelerate there is nothing, nothing BAM hard hit. Almost like there was a ton of driveline slack. However, I can easily get 20+ MPG in Economy if that's my goal. Just been driving in Comfort instead.
    - Chad
    2014 S6 Estoril Blue - APR Stage 1, AWE Exhaust
    I have USB HEX+CAN VAG-COM cable, if you need mods let me know.
    Sep 22 2013
    Norway
    So how much will a Mechatronic and or clutchpac set me back ?
    And how big a job is it to take out the box?
    Smells costly..
    Sep 22 2013
    Norway
    Needs clutchpac, 2k for the pac,
    5k for the job!
    Mar 29 2014
    Hampshire, UK
    5k for the job!
    Are these dealer prices?
    You should be able to find a good independent who can do this much cheaper, maybe even repair/overhaul the unit.
    Sep 22 2013
    Norway
    Quote Originally Posted by jkwelsh View Post
    Yes dealer pricing, looking for an alternative.
    I could go on holiday to Germany for a few days, probably half price there...
    I don't understand it can be 5K for the work, that equals a week of work here in Norway. assuming 124 ich dollars / hour.
    Veteran Member Four Rings MileMan402's Avatar
    Mar 14 2012
    PHL | BOS | SEA
    In the US, the first DSG service is at 35k. I'm guessing it's every 35k miles after that so you should have had your second DSG service recently? Are you sure they didn't leave a drain plug loose?
    2014 S6 - SOLD
    2016 Focus RS - SOLD
    2012 Wrangler Unlimited
    Sep 22 2013
    Norway
    Quote Originally Posted by MileMan402 View Post
    It was this one that had cracked at the bottom
