Results 1 to 17 of 17
    Feb 04 2016
    London
    How easy is it to drop a S5 v8 fsi engine into my b6?
    Contemplating pulling my engine out and doing a whole lot of work to it. I mean a shitload. But it could be easier to drop the S5 fsi lump into it. Can it be done? What's involved?
    May 20 2010
    Anything is possible with unlimited time and money. Any thought onto the supercharged V6 instead? You'd definitely be able to achieve higher power and torque, I think.
    Feb 04 2016
    London
    Yeah but it's not a v8 😝
    I'm aiming for the most cost effective solution.
    I have my gearbox in pieces due to a crunching 3rd. However everything appears be ok. A lot of wear, but nothing that stands out. The cost of replacing all the synchros is £600 alone. After including most of the bits I need for the engine, the total comes to £2k - just for parts! This is getting ridiculous. Thank fuck I do all the work myself.
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    Youd have to re do fuel and ecu system. Its possible, been looking into that option for my friends car. Def cheaper option than rs4 engine.
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
    Veteran Member Four Rings dsgray16's Avatar
    Jun 11 2013
    I just finished the RS4 fsi swap.. there is nothing easy or cheap about it. Still working out kinks in communication between car systems and engine. It's doable, but it's a major undertaking and shouldn't be entered into lightly. Come up with a budget and then double it.
    Events: Time to register for Avantoberfest 2018!: www.avantoberfest.com
    Instagram: Audisport_Wagon
    Cars: Full B7 RS4 Avant swap http://www.audizine.com/forum/showth...S4-Avant-Build
    B7 RS4 sedan in Phantom Black - just a clean OEM+ daily driver
    Veteran Member Three Rings jmcS4's Avatar
    Nov 16 2013
    q7 tdi+, b5 s4, r56 mcs
    Lower NH
    Quote Originally Posted by Hooblah View Post
    The new S5's are the V6 supercharged engines. The older S5's are V8's which is what the OP is referring to
    >04' S4, Nitrous
    >01.5' S4 dps, tune
    >12' Q7 TDI S-Line Plus
    >R56 Mini S w/jcw aero kit
    Veteran Member Four Rings TarlCabot's Avatar
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    Quote Originally Posted by jmcS4 View Post
    is the older S5 front timing belt or rear chain like ours ?
    PAST
    2004 Audi (B6) S4 4.2L
    2006 Audi (B7) S4 4.2L 25th Anniversary Special Edition #167
    Current
    2015 Audi (B8.5) A4 2.0T P+ Sline ECS-Luft-Technik Intake System/Air Scoop v2/Silicone Intake Tract Set with turbo muffler delete, GFB DV+ VTA Performance Blow-Off Valve, JHM FMIC/ECU and TCU (Automatic 8 Tip Quattro) Stage 2 tunes. Cosmetic RS4 Honeycomb Mesh Front Grille and Fog Light Vent Grilles
    Aug 09 2012
    Bay Area
    Quote Originally Posted by TarlCabot View Post
    I would assume they all went to timing chain. Only on the 4 cylinders I know they still have timing belts but even those have all but gone away too. Would it be safe to assume the S5's (V8) motor is almost based off/identical/same to the RS4's motor?
    Veteran Member Three Rings S4NIK8's Avatar
    Jun 09 2009
    RS6 6 speed
    Somewhere Cold
    S5 with a v8 is a chain engine. the 2.0t in 2009 and newer cars are chain engines.
    Feb 04 2016
    London
    Ok looks like there are 2 varieties of fsi. The standard one which is in the s5 and the q7, then the high revving one in the rs4 and r8. The one in the s5 and q7 have 4v heads, whereas the s4 has a 5v head.
    If there's too much work involved then I'll probably give it a miss. Cba with all the aggro seeing as winter is approaching and it's my daily as well.
    May 20 2010
    If that was a quip to me, then yes, I'm quite aware of that. Hence why I asked about the blown V6.
    Nov 16 2013
    Lower NH
    Not trying to be a dick. OP did state a V8 fsi. I was trying to help. No issues here. Honestly a blown V6 would be a awesome swap in these cars but $$$$$ I bet
    Sent from my iPhone using Tapatalk Pro
    >04' S4, Nitrous
    >01.5' S4 dps, tune
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    Quote Originally Posted by S4NIK8 View Post
    TY good to know :)
    PAST
    Current
    Nov 16 2013
    Lower NH
    Jeez really?? I hope it doesn't have the same issues as the b6/b7 s4 engines
    >04' S4, Nitrous
    >01.5' S4 dps, tune
    May 20 2010
    Yeah, sorta came off that way. OP also said "contemplating" so I asked if he had thought about the blown V6. Water under the bridge.
    Jun 09 2009
    RS6 6 speed
    Somewhere Cold
    The FSI engines have guides that are mostly metal and much less likely to experience failure, even if the composite layer broke off the aluminum guide I don't think that would allow enough slop for timing to jump.
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    Nope. The V8 S5 suffers from the same/similar issues as the RS4. The PCV/oil separator sucks oil into the intake manifold causing a lot of carbon buildup that doesn't allow the correct amount of air into the cylinder and fouls the fuel injectors. Otherwise very solid reliable engine with forged internals, not as good of a material as the RS4s but still forged.
