    Sep 30 2014
    Amhest/NY
    PCV verification
    So if in the future if I need to replace my pcv valve. Which one do I need? My car is a 2009 Audi A4 B8.
    My car currently has the 06H103495J PCV.
    The newer version of this part appears to be 06H103495AE.
    Now my question is since my car has the J revision. Does that mean my ecu has already been flashed by Audi and the front crank seal updated?
    If so can I just go out and buy the AE revision without needing to go to the dealer for the flash and seal update?
    Is my PCV still good? :
    My oil cap has negative pressure on it but heard that is normal.
    Also disconnecting the breather hose (detaching from intake manifold side) and blowing into it, no air comes out. Which I heard is a good sign that the PCV is still good.
    Jun 03 2010
    2010 A4 Quattro, 2017 VW Golf Sportwagen 4motion
    Fort Myers, FL
    You will know when the pcv goes bad, it throws a code and says low oil pressure stop engine now. Here is a video on how to fix it for $30 or less https://youtu.be/dWiq38FShD0
    Jun 04 2016
    A
    My car is a 2012 early facelift A4. it has about 21,747 Miles on the clock.
    My usual mentality is to replace anything that's weak (if its affordable)...
    I did consider replacing my PCV also but I opted the other option. Which was to replace the PVC unit with a catch can bypass.
    Instead of shitty diaphrams which can cause issues later ON, the catchcan bypass comes with a solid billet aluminium that channels the blowby to the oil catch can reservoir.
    But that's up to you.
    Senior Member Two Rings ChicagoDave's Avatar
    Oct 21 2015
    Chicagoland, USA
    I had mine replaced for free under an Audi service campaign. Put in your VIN here and see if you're eligible:
    http://web.audiusa.com/recall/
    2012 A4 Avant - Brilliant Black :: Zisa LED Lighting :: Awesome Floor Mats :: Warning Triangle :: Total Newbie
    Retired - 2002 VW Passat GLX w/ 4Motion :: 14 Years and 202,000 miles
    Retired - 1995 Chevy Impala SS :: 5.7L LT1 V8 :: Dark Cherry Metallic :: Fell apart at 98,000 miles
    Senior Member Two Rings LmG7119's Avatar
    Jun 03 2014
    MNN
    I have 2013 Allroad with 35K miles with 06H103495J. The newer version is 06H103495AE for car.
    I don't think it's broken, but wondering if I should replace it as preventive measures. I'm thinking to go stage 1. Also thinking to upgrade DV to GFB DV+ t9351
    What do you guys think?
