Results 1 to 11 of 11
    Senior Member Three Rings Prh's Avatar
    Mar 28 2015
    Q5, Land Cruiser 200, John Deere
    Northern VA
    Camshaft Adj. Bank 1 Intake - P052A - Cold-Start Timing not Reached - 2014 S6
    I have been getting an error that is quite random but when it occurs, this happens when starting up the car for the first time on a given day. Dash shows "Do not exceed 4000 rpm" and sometimes the EPC light will come on at the same time or shortly after.
    Fault code:
    10540 - Camshaft Adj. Bank 1 Intake
    P052A 00 [101] - Cold-Start Timing not Reached
    In March/April, I got it a few times and took to Audi dealer. BTW - It has not been easy to reproduce. Flashed back to stock and then waited for around a week for EC to appear again since APR flash back cleared previous EC. Dealer replaced a sensor on Bank 1 (also said they had never seen this before and sensor looked fine but they replaced anyway). Guys at NGP Lorton had also not seen this EC before.
    A few months later it happened again on July 1, 15, 26, Aug 2, 7. Same Bank 1 intake. I cleared EC and in a few cases the "Do not exceed 4000 rpm" and EPC light would go away on it's own after driving for ~ 5-10 mins.
    It hasn't happened since Aug. 7 and then it occurred again today Oct 20. Doesn't seem to be triggered by a variance in outside temperature (Spring, Summer, Fall).
    VAG Com log shows:
    P052A 00 [101] - c
    Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 60040 km
    Date: 2016.10.20
    Time: 07:46:44
    Engine speed: 1299.50 /min
    Normed load value: 13.3 %
    Vehicle speed: 0 km/h
    Coolant temperature: 29 °C
    Intake air temperature: 29 °C
    Ambient air pressure: 1000 mbar
    Voltage terminal 30: 13.782 V
    Unlearning counter according OBD: 40
    Engine status: COENG_RUNNING
    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
    Curious if anyone has any suggestions?
    2014 S6 Black - APR Stage 2 ECU+TCU, APR DP, AWE Exhaust, HRE-FF01, Black Optics, P3, ALP, Escort Redline 360, Blackvue, 034, carbon diffuser, carbon mirror covers, Roc-Euro intake, ECS Tuning sways, H&R lowering module
    Mar 01 2007
    Ducati 1098s, A4, S4
    Fayetteville, NC; Indianapolis
    Did you ever get the issue figured out?
    Built rs6'd VAST tuned
    Mar 28 2015
    Northern VA
    Quote Originally Posted by koolkoreanked View Post
    NO. I have not had it happen lately. Last times were June 27 and July 23 and it went away on it's own after a few minutes. It's usually almost always during the first start after sitting overnight. One thing they may have helped - during my the first start of the day, I wait for the RPM's to drop below 1,000 after initial start, before putting into gear. I then try and avoid any sudden acceleration until engine warms up and RPM light moves to 6500.
    One of the guys at my local performance shop thought it could be a dirty intake filter (dealer replaced this sensor and we are not sure if it has a screen filter or not). I change my oil/filter every 5k. Also make sure it never get's below 1/3 full on the MMI gauge. Wish I had a better answer.
    Active Member One Ring Jamesb9mm's Avatar
    Mar 10 2019
    Did you ever get to the bottom of this error code? I have the same thing going on. Just how you describe it. It comes and goes.
    Mar 26 2010
    US
    Check out this ATU document and the camshaft TSBs: https://static.nhtsa.gov/odi/tsbs/20...50761-9999.pdf
    Look at the manufacturer communications for the TSBs: https://www.nhtsa.gov/vehicle/2014/A...Communications
    https://static.nhtsa.gov/odi/tsbs/20...91274-0699.pdf
    2019 RS5 Sportback
    Dec 05 2019
    TX
    Any update to this problem? Just experienced it on my 2014 S6, however no EPC light and a pending P052A code. Started it up this afternoon and it removed the limit after a minute or so at idle.
    Junior Member Two Rings rodent's Avatar
    Dec 21 2019
    Parker, CO
    I'm getting this SAME code. It doesn't happen all the time. Only on cold starts. I took out the N205 camshaft adjustment valve out, inspected & cleaned it. Condition was fine, no broken screens or anything I could find anything wrong with it. Still got code to come back after another cold start yesterday. This morning, sitting the garage overnight, no code. I did do a fresh oil change and drove the car yesterday. Did some logs yesterday so maybe that helped get some clean oil through it. Not sure.
    I'm going to replace the $150 valve and see if it fixes the problem. If its a timing chain issue, then the engine may have to come out which I'd rather not do.
    Just curious who else had this issue and what they did to fix it.
    Jan 03 2009
    Iowa
    Rodent,
    The first link above seems to cover it pretty well. If the valve (screens) are okay, then it looks like you need to blow out the oil passages. Make sure you are getting enough flow of the valve/adjuster.
    Dec 21 2019
    Parker, CO
    Quote Originally Posted by qcrazy View Post
    Rodent,
    Thanks for the input! Since the fresh oil change, P052A has not come back. I'm not sure what oil the dealer is using is using these days but thats who changed it 3k miles ago. I normally change oil myself but I was lazy when my car was in for something else before I went mod crazy. Just trying to see what the norm is on this and I think its replacing the valve unless there is a issue with the chain tensioner piece as that guide shows. That would NOT be a fun job! Engine out time. Someone else replied in the 4.0t group on FB. It could be my 2013 year had some not so great valves and they've been upgraded in 2015. Thanks again for a being and huge asset to this group!
    quote-
    Done a few sets of intake camshaft adjusters for this issue to fix it. Typically it happens more in colder climates and on the early cars pre 2015.
    If you are looking for the diagnosis. Swap the solenoid to the other bank and ran the camshaft adjustment basic settings and see if and where the fault sets to determine the failure.
    Dec 21 2019
    Parker, CO
    Just wanted to do an update on this in case anyone runs into the same issue. This error code went away for a bit but eventually came back. Only on cold starts. I decided to just order a new valve from FCP. Bingo! Issue fixed. Tried many cold starts and so far, so good. I should have taken a photo of the two but visibly there were minor changes on the new part. I did read they made some revisions to the solenoid.
    Part #:06E109257T
    Car: 2013 S6
    Jun 30 2021
    Midwest
    Quote Originally Posted by rodent View Post
    Part #:06E109257T
    Car: 2013 S6
    Hey, bumping thread -- any issues since you replaced the valve?
