Results 1 to 21 of 21
    Sep 19 2014
    Newcastle
    Strange sound like a crow stuck under my car
    Yesterday i noticed when off the throttle and i have the windows down i can hear what sounds like crows cackling. I know that sounds mental but every so often i hear this sound it doesnt appear to be coming from the engine bay, no fault codes, i can't see any loose connections either.
    It sounds like its coming more from the rear of the car on the passenger side and I've tried to replicate it but it sounds like it happens around 2,000 rpm. I need to test it more but I'm sure it wasn't there before. Only 2 things i can think of is 1.) stepped tyres or something stuck in the tyre. 2.) something loose under the car since i had the resonator delete 2 weeks back. its really hard to describe but it sounds like a crow or raven following me and it only lasts for a fraction of a second or so.
    im not sure if its the exhaust grating on something or has a loose tie.
    anyone else got ideas or know what it might be?
    Ill try do a video but I've misplaced my go pro (typical)
    it's doing my head in.
    It doesnt happen when applying the brakes either.
    Maybe a crow has set up home under my wheel arches
    Audi S6 C7.5 Avant 2016 Sepang Blue APR Stage 2, Custom Downpipes, Revo RS Intake, X-Pipe & Resonator Delete - 441WHP 528WTQ 551BHP 660 LB FT.
    Mar 29 2014
    Hampshire, UK
    Haven't you just completed the centre box delete?
    Are you sure it's not the rasps and pops your hearing?
    The passenger side (on our cars) is the side with the exhaust valve. Maybe it's flapping, crow style
    John.
    2016 S7 Sepang Blue ///Matrix//Bose//Self Park//Lane Assist//ACC//F&R parking cams//Blackvue DR750//Phone Box//Sunroof//Privacy glass//Carbon mirrors//Neidfaktor Steering wheel//RS Knob//OEM RS Grill//Suntek PPF//De-chromed//Modded Exhaust//Cete ASC v2 installed//APR Stage 3 w/RS7 Turbos and intake pipes + TSU//Eventuri CF intake//Carbon Diffuser
    Gone: 2014 Audi A7Q 3.0 TFSI
    Gone: 2011 Audi A6Q 2.8 TFSI
    Veteran Member Four Rings Djpeaksd's Avatar
    Feb 01 2016
    Encinitas, CA
    Quote Originally Posted by jkwelsh View Post
    John.
    This would be pretty amazing if it was in fact the added pops from his exhaust!
    2021 RS7 Sportback Nardo Grey - Vossen HF3's satin black, lowered via ODIS
    Sep 19 2014
    Newcastle
    John.
    No it's not that. I can hear the pops and bangs this is something else. Just took it to the shop and they said sounds like there are some stones in the exhaust tips. Great. Gonna take it in and get them to check it out
    Sent from my XT1580 using Tapatalk
    Veteran Member Three Rings Ensoniq's Avatar
    Jul 12 2014
    Raleigh NC
    Crow cackling
    I was going to suggest maybe Hillary got stuck under there but I saw her on teevee last night
    2014 Phantom Pearl Black RS7
    2014 Mercedes ML350 4Matic AMG package
    2008 Corvette Z06 (Sold)
    1996 Corvette Collectors Edition (Sold)
    Sep 19 2014
    Newcastle
    Quote Originally Posted by Ensoniq View Post
    Crow cackling
    HAHA! I'm afraid it's even worse and it's Trump. My car grabbed a woman vagina last night and said it was going to build a wall around it.
    Sep 19 2014
    Newcastle
    This is the noise sorry for the poor quality video https://youtu.be/1hMuFcDyow4 sounds like it's coming from the exhaust when I've had someone run the engine and listen outside. Any ideas?
    Active Member Two Rings RingLeader02's Avatar
    Sep 21 2016
    87 fc rx7, 99 dsm gsx, 91 subi impreza, 81 maxim 650
    Lancaster, PA
    Quote Originally Posted by pez81 View Post
    Sure it's not from the front of the car? The only thing I can think of coming from the rear is a suspension component going bad/old, bearing(s) because sh*t rolls down hill meaning one problem you can identify is causing the problem you can, something loose I.e. exhaust hanger, bolt or nut..the vibration around that rpm range might be enough to make something back there do it. I'd double check on how tight everything is and inspect stuff for excessive wear, etc....Troubleshoot thoroughly...eventually you'll find it.
    Worse case and I don't recommend this so if something bad happens its on you, not me, get the car in the air and put the rpm load range on the car and see it if does it then. Atleast you could be next to it. Just don't dump the clutch or something good luck
    Sent from my 0PM92 using Audizine mobile app
    Insta: killcharmeloni
    Sep 21 2016
    Lancaster, PA
    One problem you can't identify is causing the problem u can***
    Sep 19 2014
    Newcastle
    Quote Originally Posted by RingLeader02 View Post
    Thanks I'm pretty sure it's the rear passenger side. The car only has 10,000 miles on and is a 2016. Do bearings go so easily? It sounds like metal on metal to me
    Sep 21 2016
    Lancaster, PA
    I've seen some sh*t in my life tbh, anything is possible. It's almost the weekend 100% so delegate some time to inspect it. It's so new it's probably something absolutely silly. If you can't figure it out, the stealership it is
    Sep 19 2014
    Newcastle
    Thanks RingLeader02 rattles and creaky sounds really are a big bug bare for me. I don't keep much in the car for this reason. You're right though it's probably something simple. Enjoy your weekend dude
    Sep 21 2016
    Lancaster, PA
    Broski, if there is any heat shields back there, check em out, thanks and good luck. My dsm's balance shaft belt just broke. One thing after another lol
    Sep 19 2014
    Newcastle
    Ah you know what that would make sense with the heat shield as it has recently been removed. Oh dude that sucks. Feel your pain
    Sep 19 2014
    Newcastle
    So I got a friend to come for a drive with me, he's pretty good with all things cars and we noticed that it only occurs when the exhaust valves are closed and it's the left pipe. We tried many times to replicated and it's between 2-3000rpm it happens when not in dynamic. So looks like a dodgy butterfly valve. What are the options? Cutting in to the muffler to remove the valve seems like a lot of work. Can you keep then open all the time somehow? Or remove then without cutting in to the box? Man if I have to do that I may as well get a new cat back. It's a new car how's this even possible
    Established Member Two Rings DirtyVegasTT's Avatar
    Apr 29 2009
    Vegas
    Why not just take it to the dealer and get it covered under warranty?
    2013 A8L 4.0T
    APR | 22x10.5 Vossen VFS1 | 285/30/22
    Gone - But Not Forgotten
    2007 S6 V10
    APR | Miltek Catback | MSDS Filters | RS6 Grill | LLTek Spoiler | H&R Sport Srpings | 20x9 Hartmann B7 HRS4 | 265/30/20 BFG G-Force
    Mustang Dyno: 342 AWHP, 338 AWTQ - Back then it was pretty good for N/A Audi
    Sep 19 2014
    Newcastle
    Quote Originally Posted by DirtyVegasTT View Post
    Do you know how many things I've done to my car? Taking it back stock will take more time and money than paying myself. I will td1 so fast
    Mar 29 2014
    Hampshire, UK
    The centre delete and X-pipe won't stand you in good stead with the dealer, for an exhaust problem unfortunately.
    Here is the parts diagram for the rear box, http://audi.7zap.com/en/rdw/audi+a6+.../2/253-253089/ #6 is the flap servo.
    I'm thinking it's unlikely to be the crow, sorry flap, erm, fapping How about a dodgy electrical connection or the servo motor. If you can get it on a ramp, that will help with the diagnosis.
    If the servo is not fully operational, the flap may be in an intermittent position, allowing exhaust gasses to flow past, and induce a crowing noise.
    HTH,
    J.
    Established Member Two Rings Roadwarrior's Avatar
    Oct 01 2016
    Atlanta, GA
    guessing heat shield that is touching and vibrating as suggested above. That should be an easy fix if that is the case. Good luck.
    2015 Audi S6- Phantom Black Pearl Effect, Black Interior, Black Alcantara Headliner, Driver Assistance, Night Vision Assistant, Carbon Atlas Inlays, Cold Weather Package, 20" OEM Wheels. Mods- AWE Touring Exhaust, Bel STI R+, ALP Laser Shifter, RS6 Intake. On the way but not installed: Alu Kruez, Sways, End Links and Mounts.
    Senior Member Three Rings Alym's Avatar
    May 08 2012
    Stirling UK
    I've just had my front bearings replaced and that was more of a loud droning noise... Got louder and higher pitched the faster I went! Noise was only evident from 25mph as well..
    Sep 19 2014
    Newcastle
    Had the car in the shop today to remove the front resonators. Very happy it pops and crackles like mad now. Should have done this with the x pipe. Well worth £140.
    The crows have gone too. Just disconnected the rear exhaust flap and that worked. Looks like a loose valve or something but the crows have vacated.
