Results 1 to 19 of 19
    Junior Member Two Rings
    Mar 28 2014
    edmonton, alberta, canada
    99.5 new project
    I just picked up a 99.5 with 150000kms. It had a bunch of misfire codes so out in new spark plugs. It starts but idles at 500 and if you touch the accelerator it wants to die. Not sure where to look. Has good compression.
    Veteran Member Four Rings Turbo_B5's Avatar
    Oct 09 2012
    abunch of useless shit
    Notnomde Atrebla Adanac
    The engine is an AEB Auto... been sitting since 2011.
    It's not misfire codes it's injector codes.
    Injector1 open circuit
    Injector2 open circuit
    Injector3 open circuit
    Injector 4 open circuit
    Throttle valve controller malfunction
    Sent from my Jailbroken iPhone 6s iOS9.3.3 using Tapashit
    EH F0UR 2001 A4 1.8TqM
    = Parked cause its junk.
    2002 Golf TDI
    = FASTER THEN YOUR B5.
    2018 Suzuki GSX-R750
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    1997 A4 1.8TqM SPORT
    @Turbo_B5
    Established Member Two Rings bwizard's Avatar
    Oct 10 2016
    Colorado Springs, Colorado
    Check the wiring harness sitting for 5years I bet some mice ate wires
    Sent from my S4's talk to text @ a buck thirty
    weekly driver 02 S4 2.7t auto stock
    Wife's 04 A4 1.8t auto stock
    Daughter's 97 A4 AEB Bored to 2.0t K04 sport cams
    My role family tech.
    May 10 2015
    Pittsburgh PA
    Your fuel system is probably all gunked up. I'd replace the fuel filter and dump out any of the old fuel that's sitting in the tank and put in some fresh 91 or 93 for starters.
    Veteran Member Four Rings psiaddict85's Avatar
    Dec 16 2008
    Cleveland OH
    Check the ICM.
    22 []S6 Glacier/Arras
    19 []S4 Quantum/Magma
    16 A6 3.0T S-Line/Glacier
    15 []SQ5 Audi Exclusive/Ibis/Magma RIP
    09 []S5 V8 6MT/Ibis/Magma
    06 A4 2.0TQ StgII+ DTM/Moro
    99.5 A4 1.8T StgIII Silver
    Oct 09 2012
    Quote Originally Posted by psiaddict85 View Post
    Check the ICM.
    Icm will cause misfires of spark. Not injector codes.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Oct 10 2016
    The bad fuel idea is good however the code is for a circuit. That means that when the Ecu performs it's test on the circuitry the "circuit" is "open" and we all know an "open" circuit means a wire is disconnected, bad dirty grounds, terminals etc.
    Oct 10 2016
    Clean battery terminals etc. Make sure Ecu is getting proper voltage, check harness, clean corroded grounds.
    Oct 10 2016
    Plus with the random throttle valve controller malfunction code that is different than the injectors makes no sense . I'm not saying there couldn't be multiple codes nor problems but I bet once you find the bad wires. Both problems will be solved.
    Mar 28 2014
    Unplugged the maf and there was no change in how it ran
    Oct 09 2012
    Lol... He also checked the grounds under the tank. gonna go over this weekend perhaps with a different ecu and see what happens. Go over the harness and all the hidden fuses aswell.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Feb 27 2011
    Winnipeg
    I'd ohm out the injectors, make sure they aren't internally shorted or open. Sounds like the throttle body is bitched too, either it needs an adaptation and if that doesn't work then replacement
    Oct 09 2012
    Quote Originally Posted by seanf86 View Post
    I have a hard time believing that all 4 would be bad. My 97 made it to 311k Kms on most likely original shit, all I know was the ecu was swapped out with a Passat one at some point.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Oct 10 2016
    I agree this is why I believe it to be a wiring issue.
    Mar 28 2014
    ohm'd out the injectors all are reading the same so they check out.
    Mar 28 2014
    Took down the lower panel to check relays and there was a loose relay 32 not sure if it goes somewhere.
    Mar 28 2014
    Mar 28 2014
    well changed out the ecu and no more issues now on to taking care of all the other little things
    Oct 09 2012
    99.5 new project
    Shoved the relay 32 in that slot and no change... Swapped in my 557p ecu and it fixed the problems. He has to change the oil since it has a bunch of water in it. Then test drive.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
