Results 1 to 8 of 8
Thread: Gas cap help
    Sep 12 2016
    alaska
    Gas cap help
    Hey guys so about a month ago I was filling up the gas tank but this time when I went to remove the nozzle it was stuck. So I went into the gas station and asked if anyone had a tool or an easy way to get it out. So a guy comes out and helps me but for some reason he just rips the damn thing out. On the way home a light came with a blinkng gas station thing. Im pretty sure it normally means your gas cap is open and it wasnt so for the most part i ignored it and moved on. But now a month later im omw home fr school when my check engine light comes on. I code scanned it and it said something about a sensor. Does anyone know which part i should replace?
    Established Member Two Rings 123lilc's Avatar
    Mar 04 2015
    2002 Audi A4 GTX3071R, 2004 Audi S4 Avant 6M/T, 2008 Audi A4 Cabriolet,2018 L5P Duramax
    Champaign, Illinois
    Do you have the code?
    Oct 06 2016
    millsboro de
    Yeah the gas cap has some kind of magnet in it. If it's broken you can get another one for 40$. You must replace that. If the light doesn't go away than maybe take a look at your evap valve. My car is doing that now just don't have the time to get the evap valve. It will run hesistant sometimes if it's evap btw. That should have you all good to go. Good luck lmk how it works.
    Sep 12 2016
    alaska
    Quote Originally Posted by 123lilc View Post
    Crap.. my obd2 broke last month because of my brother and i went to get it scanned at autozone. Ill get back to you with the code tmrw.
    Oct 06 2016
    millsboro de
    It HAS TO BE OEM! Don't cheap out you'll just waste money
    Aug 26 2005
    Besides the magnet in the gas cap, there is an associated reed switch in the filler pipe. When the gas cap is present, installed, the magnet pulls the reed switch contacts apart, turning the warning light OFF. If the reed switch was damaged, then it is not the cap that is faulty.
    Vorsprung durch Technik
    Sep 12 2016
    alaska
    [QUOTE=suffakation;11959912]Yeah the gas cap has some kind of magnet in it. If it's broken you can get another one for 40$. You must replace that. If the light doesn't go away than maybe take a look at your evap valve. My car is doing that now just don't have the time to get the evap valve. It will run hesistant sometimes if it's evap btw. That should have you all good to go. Good luck lmk how it works.
    Thanks ill give it a shot and let you know
    Sep 12 2016
    alaska
    [QUOTE=suffakation;11959912]Yeah the gas cap has some kind of magnet in it. If it's broken you can get another one for 40$. You must replace that. If the light doesn't go away than maybe take a look at your evap valve. My car is doing that now just don't have the time to get the evap valve. It will run hesistant sometimes if it's evap btw. That should have you all good to go. Good luck lmk how it works.]
    Wait so would that just be the magnet or a new gas cap?
